| | VB script just keeps looping and does not excute the code Here is the code : On Error Resume Next Const ForReading = 1 'Create FSO Set objFSO = CreateObject("Scripting.FileSystemObject") 'Read Text File Set objFile = objFSO.OpenTextFile("U:\Scripts\PST\4fl_segment.txt", ForReading) Set objWMIService = GetObject("winmgmts:" _ & "{impersonationLevel=impersonate}!\\" & strcomputer & "\root\cimv2") Do Until objFile.AtEndOfStream strcomputer = objFile.ReadLine '**************************************** Start Ping ******************************************* Set colItems = objWMIService.ExecQuery _ ("Select * from Win32_PingStatus " & _ "Where Address ='" & strcomputer & "'") 'WScript.Echo strcomputer & " Reply Received" For Each objItem In colItems If objItem.StatusCode = 0 Then '*********************************************************************************************** 'get ost files Set colFiles = objWMIService.ExecQuery _ ("Select Name from CIM_DataFile" _ & " where Drive='C:' and Extension='OST'") 'WScript.Echo "# of files found: " & colFiles.Count For Each objFile in colFiles Wscript.Echo strcomputer Wscript.Echo objFile.Name Next Else Wscript.Echo strcomputer & " No Reply" End If Next Loop objFile.Close It reads the text file but does not excute the 'get ost files. It does work when I use my local machine. Please help me |
| | Re: VB script just keeps looping and does not excute the code "freddy" <freddy@xxxxxx> wrote in message news:80F6CC5B-8FFA-4343-A159-E827347190C3@xxxxxx Quote: > Here is the code : > > On Error Resume Next > Const ForReading = 1 > 'Create FSO > Set objFSO = CreateObject("Scripting.FileSystemObject") > 'Read Text File > Set objFile = objFSO.OpenTextFile("U:\Scripts\PST\4fl_segment.txt", > ForReading) > Set objWMIService = GetObject("winmgmts:" _ > & "{impersonationLevel=impersonate}!\\" & strcomputer & "\root\cimv2") > Do Until objFile.AtEndOfStream > strcomputer = objFile.ReadLine > > '**************************************** Start Ping > ******************************************* > Set colItems = objWMIService.ExecQuery _ > ("Select * from Win32_PingStatus " & _ > "Where Address ='" & strcomputer & "'") > 'WScript.Echo strcomputer & " Reply Received" > For Each objItem In colItems > If objItem.StatusCode = 0 Then > '*********************************************************************************************** > 'get ost files > Set colFiles = objWMIService.ExecQuery _ > ("Select Name from CIM_DataFile" _ > & " where Drive='C:' and Extension='OST'") > 'WScript.Echo "# of files found: " & colFiles.Count > For Each objFile in colFiles > Wscript.Echo strcomputer > Wscript.Echo objFile.Name > Next > Else > Wscript.Echo strcomputer & " No Reply" > End If > Next > Loop > objFile.Close > > It reads the text file but does not excute the 'get ost files. It does > work > when I use my local machine. Please help me an error message to help troubleshooting. A quick glance show that the code redefines objFile. In the loop where you read lines of objFile, the object reference is redefined to be one of the files on a computer. Maybe you can just use a different variable name. -- Richard Mueller MVP Directory Services Hilltop Lab - http://www.rlmueller.net -- |
| Script-based code sample library (HTA) | VB Script | |||
| cannot excute command to open message | Vista mail | |||
| Is there a shorter code to perform this ps1 script ? | PowerShell | |||
| MSBuild script for Getlatest cource code | .NET General | |||
| Help looping a script | PowerShell | |||
