Vista - Run command problem in vbs
Old 02-07-2009   #1 (permalink)
Tcs
I only want the setup.exe to run if the version of the LDISCN32.EXE
file <> "8.70.8.22". On the machine on which I have been testing
this, I KNOW the version IS "8.70.8.22". So...it should NOT run. But
EVERY time I try to run this...it executes the setup.exe.
What am I doing wrong? Am I not checking the version correctly?
Or...???
Thanks in advance,
Tom
' Checks the version of ldiscn32.exe and cranks up sp6 install if the
rev is <> sp6
strComputer = "."
Set objWMIService = GetObject("winmgmts:" _
& "{impersonationLevel=impersonate}!\\" & strComputer &
"\root\cimv2")
Set colFiles = objWMIService.ExecQuery _
("Select * from CIM_Datafile Where name = 'C:\\Program
Files\\LANDesk\\LDClient\\LDISCN32.EXE'")
For Each objFile in colFiles
If objFile.Version <> "8.70.8.22" Then
WScript.Echo _
"Made it to the execution partion..."
strCmd = "%comspec% /c csccmd
\\LDSVR001\LANDesk\LD87-SP6-Client\setup.exe -S"
Set objShell = CreateObject("Wscript.Shell")
intReturn = objShell.Run(strCmd, 2, True)
Wscript.Echo "Return code: " & CStr(intReturn)
End If
Next
Old 02-08-2009   #2 (permalink)
urkec
RE: Run command problem in vbs
> Or...???
> Thanks in advance,
> Tom
> rev is <> sp6
> strComputer = "."
> "\root\cimv2")
> WScript.Echo _
> End If
> Next
It is possible that objFile.Version doesn't contain what you expect. Try to
check it before the comparison:
strComputer = "."
& "{impersonationLevel=impersonate}!\\" _
& strComputer & "\root\cimv2")
("Select * from CIM_Datafile " & _
"Where name = 'C:\\Program Files\\LANDesk\\LDClient\\LDISCN32.EXE'")
WScript.Echo objFile.Version
WScript.Echo "Made it to the execution partion..."
End If
Next
urkec
Old 02-08-2009   #3 (permalink)
Al Dunbar
Re: Run command problem in vbs
"Tcs" <someone@xxxxxx> wrote in message
news:3ncso49q9v7h2e4j9ashuqgv6ikpp38pbt@xxxxxx
> Or...???
I do not know for sure, but it could be that there is some difference in
data types that is causing this problem. I'd suggest that you see what the
typename and vartype functions have to say about objFile.Version and
"8.70.8.22", to see if they are the same. If not, then I'd convert one or
both to the same type. It might just be, for example, that .Version returns
an array.
/Al
Quote:
> Thanks in advance,
> Tom
> rev is <> sp6
> strComputer = "."
> "\root\cimv2")
> WScript.Echo _
> End If
> Next
Old 02-08-2009   #4 (permalink)
ekkehard.horner
To merge urkec's and Al Dunbar's advice:
WScript.Echo objFile.Name _
, objFile.Version _
, ">" & objFile.Version & "<" _
, TypeName( objFile.Version )
For me, TypeName( objFile.Version ) returns: "String"
Old 02-08-2009   #5 (permalink)
Tcs
Thanks guys.
I thought that I had checked...sufficiently. Obviously, I was wrong.
Seems that the string contains two spaces on the end, following the
'22'.
Script works properly now. I appreciate the help.
Tom
On Sun, 08 Feb 2009 20:23:05 +0100, "ekkehard.horner"
> , objFile.Version _
Old 02-08-2009   #6 (permalink)
Al Dunbar
news:4qnuo4150628n1qeqb80t8ohbar70kubgl@xxxxxx
Quote:
> Thanks guys.
You're welcome,
> '22'.
Ah, the old "invisible" trailing whitespace - kills you every time. It is
always a problem that you will not see this when you display a string
variable - unless you bracket it somehow, as in "[" & variable & "]". The
"=" and "<>" comparison operators do not include an implicit "close enough
is close enough", and generally look for an exact match.
Like most scripts, it always worked - it was just doing something you did
not intend! ;-)
/Al
Quote:
> Tom
>> , objFile.Version _
Re: Problem with Command Interpreter Vista General
Problem with get-command PowerShell
Command completion problem. PowerShell
