Vista - Problem using SUM with ADO object
Old 02-11-2009   #1 (permalink)
Scott
What am I doing wrong here? I expect to get the total for all rows in the
column 'TotalItems' of the spreadsheet server.xls but instead I get the
error: "The Microsoft Jet database engine could not find the object
'MailServer'. Make sure the object exists and that you spell its name and
the path name correctly." I do get results when using "SELECT * FROM
MailServer" so it must be the SUM().
Thank you.
dbPath = "C:\desktop\Server.xls"
con.Open "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & dbPath&";Extended
Properties=""Excel 8.0;HDR=Yes;"";"
rs.Open "SELECT Sum('TotalItems') as TotalItems FROM MailServer",con
Old 02-12-2009   #2 (permalink)
Paul
Re: Problem using SUM with ADO object
Scott,
I assume that the MailServer in the SQL is the worksheet name in which case
it should
be written as follows
[MailServer$]
Paul
"Scott" <Scott@xxxxxx> wrote in message
news:514F0722-56A0-4D7A-A1D7-69752C7B158B@xxxxxx
> Thank you.
> dbPath&";Extended
Problem in returning an object from a function VB Script
Object Dock problem Software
Object lifetime/event problem .NET General
Problem with Measure-Object on get-process PowerShell
Adding canonical aliases for Compare-Object, Measure-Object, New-Object PowerShell
