Vista - Need help with extracting 4 digits from the directory/folder name
Old 02-13-2009   #1 (permalink)
sa
I have a variable folderP set to various paths values. I need to
extract the 2nd, 3rd, 4th and 5th charcters from it as explained with
an example below.
Here's the code i use:
folderP=Application.PrimaryDirectory
For Ex.
folderP is set to C:\temp\21070Ax12K7. I need the 1070 from that
value.
Another Ex.
folderP set to Z:\NPBDArchive\PCDesign\ajackr\21062Axp22k745 - in
this case I need to extract the value 1062.
Also the primary directory names always start with a 2 followed by 4
digits and then an A. Is there a good way to get these values.
Thanks
Vista x86 program folder not showing in directory Vista file management
When I minimize a folder, it shows whole directory Vista General
Missing 2 digits on product key sticker Vista installation & setup
How do I change de directory for my user folder?? Vista General
Moving a directory / file from 1 location to another folder Vista file management
