"Benny Pedersen" <b.pedersen@xxxxxx> wrote in message
news:4d59e483-24f0-43c2-84c7-6dec7adb9655@xxxxxxBenny, the information on this page...
http://msdn.microsoft.com/en-us/libr...70(VS.85).aspx
indicates that valid values for iColumn of getDetailsOf method are -1
through 4.
The value of 26 seems to be out of range.
Todd Vargo
(Post questions to group only. Remove "z" to email personal messages)
"Todd Vargo" <tlvargo@xxxxxx> wrote in message
news:OpatJKQlJHA.3868@xxxxxxHi, Todd
> news:4d59e483-24f0-43c2-84c7-6dec7adb9655@xxxxxx>
> through 4.
Things only seem to be something based on what we believe to be the truth.
I think the page you reference is out of date or incomplete or just plain
wrong.
I have attached and listed below a VBScript that explores the Windows OS's
namespaces and the columns that can be displayed when a namespace is opened
as folder on the screen. It pops up two message boxes, and writes a file.
The first message box is a list of all the namespaces and their
corresponding namespace number. The second message box shows that many
namespaces share the same set of columns that windows explorer can display
for those namespaces, and groups those namespaces. The file created by the
script, SpecialFoldersInfo.txt, list those groups and the column headings
for each group. I see column numbers in the 50's.
-Paul Randall
'Go through all the special folders and list all the details
' that can be displayed for the items they may contain.
Option Explicit
Dim i, oShell, oShFolder, sMsg, sNameSpace, iCount
Dim iTemp, sItem, Temp
Dim odSpecFldrs
Set odSpecFldrs = CreateObject("scripting.dictionary")
odSpecFldrs.comparemode = vbTextCompare
Dim odSpecFldrDesc
Set odSpecFldrDesc = CreateObject("scripting.dictionary")
odSpecFldrDesc.comparemode = vbTextCompare
Set oShell = CreateObject("Shell.Application")
'Assuming shell namespaces are numbered from 0 to 255,
' create a dictionary containing keys consisting of an
' alphabetic list of namespace titles followed by a comma
' and the namespace number. For example, there may be
' keys like: Desktop,0 and Desktop,16 and Desktop,25.
For i = 0 To 255
Set oShFolder = oShell.NameSpace(i)
If TypeName(oShFolder) <> "Nothing" Then
odSpecFldrs(i) = oShFolder.Title & "," & i
End If
Next 'i
Temp = SortNet(odSpecFldrs.Items)
odSpecFldrs.RemoveAll
For Each sItem In Temp
odSpecFldrs(sItem) = ""
Next 'sItem
MsgBox "NameSpace Titles and" & vbCrLf & _
vbTab & "Numbers" & vbCrLf & _
Join(odSpecFldrs.Keys, vbCrLf)
'For each of the namespaces, add an array of the
' descriptions available for the items that might be
' in the namespace.
For Each sNameSpace In odSpecFldrs.Keys
odSpecFldrs(sNameSpace) = _
GetDetailDescriptions(Split(sNameSpace, ",")(1))
' If Split(sNameSpace, ",")(1) = 32 Then
' MsgBox "Namespace Title,Number = " & sNameSpace & vbCrLf & _
' "Description Count = " & _
' UBound(odSpecFldrs(sNameSpace)) + 1 & vbCrLf & _
' Join(odSpecFldrs(sNameSpace), vbCrLf)
' End If
Next 'sNameSpace
Dim saBase
saBase = ""
odSpecFldrDesc(Join(odSpecFldrs(sNameSpace), vbCrLf)) = _
odSpecFldrDesc(Join(odSpecFldrs(sNameSpace), vbCrLf)) & _
sNameSpace & " "
Next 'sNameSpace
Dim saDescList
For Each saDescList In odSpecFldrDesc.Keys
sMsg = sMsg & "NameSpace List: " & vbCrLf & _
odSpecFldrDesc(saDescList) & vbCrLf & _
"Field Description List:" & vbCrLf & saDescList & vbCrLf & vbCrLf
Next 'saDescList
fOverWrite "SpecialFoldersInfo.txt", sMsg
MsgBox "Unique Descriptions count = " & odSpecFldrDesc.Count & _
vbCrLf & Join(odSpecFldrDesc.Items, vbCrLf & vbCrLf)
WScript.Quit
Function GetDetailDescriptions(iNameSpace)
'Return an array of the descriptions of the information
' available for the items in a namespace.
Dim i, sDescription
Dim oShellApp
Set oShellApp = CreateObject("Shell.Application")
Dim oShSpecFolder
Set oShSpecFolder = oShellApp.Namespace(CInt(iNameSpace))
Dim odDescriptions
Set odDescriptions = CreateObject("scripting.dictionary")
odDescriptions.comparemode = vbTextCompare
'Get the descriptions of available info
For i = 0 To 255
sDescription = oShSpecFolder.GetDetailsOf( _
oShSpecFolder.Items, i)
' MsgBox i & vbTab & sDescription & vbTab & _
TypeName(sDescription) & vbTab & isempty(sDescription) & _
vbTab & Len(sDescription)
If sDescription <> "" Then
odDescriptions(sDescription) = sDescription & "," & i
End If
Next
GetDetailDescriptions = SortNet(odDescriptions.Items)
End Function 'GetDetailDescriptions(iNameSpace)
Function SortNet(a1DArray)
Dim i
With CreateObject ("System.Collections.ArrayList")
For i = 0 To UBound(a1DArray)
.Add a1DArray(i)
Next
.Sort()
SortNet = .ToArray
End With
End Function
Sub fOverWrite(sFileName, sText)
With CreateObject("Scripting.FileSystemObject")
On Error Resume Next
.CreateTextFile(sFileName, True, False). _
Write(sText)
If Err Then 'Try Unicode file.
On Error GoTo 0
.CreateTextFile(sFileName, True, True). _
Write(Text)
End If
On Error GoTo 0
End With
End Sub
Paul Randall wrote:news:4d59e483-24f0-43c2-84c7-6dec7adb9655@xxxxxx
> >http://www.elementsvillage.com/forum...445#post442445
> >> We have a problem here
> >>opened>
> > through 4.
> Hi, Todd
> wrong.
> namespaces and the columns that can be displayed when a namespace isthe
> for those namespaces, and groups those namespaces. The file created by<VBScript snipped>
The script returns this message in Windows 98.
E:\GetDetailsOfSpecialFolders.vbs(102, 1) Microsoft VBScript runtime error:
ActiveX component can't create object: 'System.Collections.ArrayList'
System.Collections.ArrayList does not seem to be valid in Windows 98.
BTW, the column information in the linked page is correct for me in Windows
98. Unfortunately, the msdn page does not identify particular OS
information.
Todd Vargo
On Feb 22, 11:19*pm, "Todd Vargo" <tlva...@xxxxxx> wrote:System.Collections.ArrayList is a part of the dot Net framework. I
> Paul Randall wrote:>
> > "Todd Vargo" <tlva...@xxxxxx> wrote in message
> > > "Benny Pedersen" <b.peder...@xxxxxx> wrote in message
> > > Benny, the information on this page...>
> > > through 4.
> > > The value of 26 seems to be out of range.>
> > Hi, Todd
> > wrong.> opened
> > namespaces and the columns that can be displayed when a namespace is> the
> > as folder on the screen. *It pops up two message boxes, and writes a file.
> > corresponding namespace number. *The second message box shows that many
> > for those namespaces, and groups those namespaces. *The file created by>
> > for each group. *I see column numbers in the 50's.
> <VBScript snipped>
> information.
> Todd Vargo
don't know if there is a framework version for Win98.
Tom Lavedas
http://there.is.no.more/tglbatch/
news:%237QrO6WlJHA.5112@xxxxxxHi, Todd,
> Paul Randall wrote:> news:4d59e483-24f0-43c2-84c7-6dec7adb9655@xxxxxx
>> >>> opened>>
>> > through 4.
>> Hi, Todd
>> truth.
>> wrong.
>> OS's
>> file.
>> display
>> for those namespaces, and groups those namespaces. The file created by> <VBScript snipped>
> error:
> Windows
> information.
Tom is right. My simple array sort routine requires Dot Net. It uses one
of the few scriptable dot net objects.
The sorting was for my convenience. Just delete or comment out the sorting
routine and change the lines that use it.
For example, change:
to:
GetDetailDescriptions = odDescriptions.Items
Similar changes must be made in some other places.
On this system:
W98SE
4.10.2222 A
IE 5.50.4807.2300 Update Versions:; SP2;
I get the following in my SpecialFoldersInfo.txt. The maximum column number
is less than 4 in most namespaces, but the favorites goes up to 7.
NameSpace List:
Desktop,0 Internet Explorer,1
NameSpace List:
Programs,2 My Documents,5 StartUp,7 Recent,8 SendTo,9 Start Menu,11
Desktop,16 NetHood,19 Fonts,20 ShellNew,21 Start Menu,22 Programs,23
StartUp,24 Desktop,25 Application Data,26 PrintHood,27 StartUp,29 StartUp,30
Favorites,31 Temporary Internet Files,32 Cookies,33
Name,0
Size,1
Type,2
Modified,3
NameSpace List:
Control Panel,3
Name,0
Description,1
NameSpace List:
Printers,4
Name,0
Documents,1
Status,2
Comment,3
NameSpace List:
Favorites,6
Name,0
Size,1
Type,2
Modified,3
Last Visited,4
Last Modified,5
# of Visits,6
Status,7
NameSpace List:
Recycle Bin,10
Name,0
Original Location,1
Date Deleted,2
Type,3
Size,4
NameSpace List:
My Computer,17
Name,0
Type,1
Total Size,2
Free Space,3
NameSpace List:
Network Neighborhood,18
Name,0
Comment,1
NameSpace List:
History,34
Time Period,0
T Lavedas wrote:Just for the sake of completeness, there are (at least)
> I don't know if there is a framework version for Win98.
three Net Frameworks which are compatible with win98.
- v1.0.2204
- v1.0.3705
- v1.1.4322
Although I must confess that (as far as I am concerned)
there is not one "all-purpose" net framework for win98.
I find that v1.1.4322 works well with the (free) vbc
"command line" vb.Net compiler and regasm to make (interop)
COM objects for use with wsh/vbs scripting. OTOH, I find
that v1.0.2204 works best with microsoft's regular
"command line" compiler (cl) to compile C or C++ code...
As one may surmise, I did not purchase visual studio.
Rather, I just used the free compilers that came with the
net framework downloads. And it is a bit of a hassle to
revise autoexec.bat (to adjust PATH, LIB, and INCLUDE)
to bring in the version of net framework that works best
with my current project.
And now for the "bad news". I strongly suspect that you
will find it extremely difficult if not impossible to ever
find these downloads currently, as microsoft has said
"sayanora" and good riddance (as far as ms was concerned,
but not me) to win98.
cheers, jw
____________________________________________________________
You got questions? WE GOT ANSWERS!!! ..(but, no guarantee
the answers will be applicable to the questions)
| Similar Threads | ||||
| "This program cannot display the web page" in WMP11 Album Info? | vistar | Software | 9 | 26 Aug 2008 |
| Can't get rid of "Info Icon" pop-up "This program cannot display.. | MEL652 | Vista General | 0 | 05 Feb 2008 |
| Performance Info and Tools: "page failed to load." | uvbogden | Vista performance & maintenance | 0 | 28 Aug 2007 |
| Any info on "SBEServer" issue in Windows Vista's Media Center? | Albert | Vista music pictures video | 0 | 18 Aug 2007 |
| Info: I am creating a "Powershell Information Blogging Central Project" | Brandon Shell | PowerShell | 29 | 26 Jan 2007 |
