Vista - a little problem with .Range(.Cells(2,1),.Cells(2,49)).
Old 03-10-2009   #1 (permalink)
Benny Pedersen
Hi
This work fine:
dim i: for i= 1 to 49: oExcelSheet.cells(2,i)= i: next
With oExcelSheet
.Range("A2:AW2").Font.Size= 8
.Range("A2:AW2").Font.Bold= false
.Range("A2:AW2").Font.Name= "Arial"
.Range("A2:AW2").Font.Color= RGB(0,0,0)
.Range(.Cells(2,1),.Cells(2,49)).select
End With
wScript.quit
BUT after I looped like this:
I then figured out that the line
oExcelSheet.Range("A2:AW2").Font.Size= 8
would make all the 49 values fontsize 8.
Now since it was not obvious that the last
value should be AW2 for column 49, I think
it would be better to use the
oExcelSheet.Range(.Cells(2,1),.Cells(2,49)).select
instead where one only have to specify the upper
left corner, and the lower right corner of the cells retangel.
The problem now is that I can't get a border around the
I tried
.Range(.Cells(2,1),.Cells(2,49)).border= true
and a lot of other syntax but it doesn't make a border ?
Benny
www.fineraw.com
Old 03-10-2009   #2 (permalink)
T Lavedas
Re: a little problem with .Range(.Cells(2,1),.Cells(2,49)).
On Mar 10, 3:21*am, Benny Pedersen <b.peder...@xxxxxx> wrote:
Quote:
> Hi
> This work fine:
> * dim i: for i= 1 to 49: oExcelSheet.cells(2,i)= i: next
> * With oExcelSheet
> * .Range("A2:AW2").Font.Size= 8
> * .Range("A2:AW2").Font.Bold= false
> * .Range("A2:AW2").Font.Name= "Arial"
> * .Range("A2:AW2").Font.Color= RGB(0,0,0)
> * .Range(.Cells(2,1),.Cells(2,49)).select
> * End With
> * wScript.quit
> * for i= 1 to 49: oExcelSheet.cells(2,i)= i: next
> * oExcelSheet.Range("A2:AW2").Font.Size= 8
> * oExcelSheet.Range(.Cells(2,1),.Cells(2,49)).select
> I tried
> * .Range(.Cells(2,1),.Cells(2,49)).border= true
> Bennywww.fineraw.com
I used the Record Macro feature of Excel to provide the information
needed to construct this solution:
Sub Macro1(ULCell, LRCell)
' Macro1 Macro
' Macro recorded 3/10/2009 by Tom Lavedas
Const xlEdgeLeft = 7, xlEdgeRight = 10, xlContinuous =1 _
xlThin = 2, xlThick = 4, xlAutomatic = -4105
With oExcelSheet.Range(ULCell, LRCell)
For i = xlEdgeLeft To xlEdgeRight
With .Borders(i)
.LineStyle = xlContinuous
.Weight = xlThin
.ColorIndex = xlAutomatic
End With
Next
End With
End Sub
It is not the exact macro, far from it, actually. It's just the result
of the information quickly derived from the macro that Excel
provided. It doesn't always work out as easy as this one, but usually
it is faster than trying to search through the arcane Excel (Word/
PowerPoint/Project/Access) document object model(s).
Tom Lavedas
http://there.is.no.more/tglbatch/
Old 03-10-2009   #3 (permalink)
Benny Pedersen
Thanks Tom.
I will try this later today or tomorrow. I have never used an Excel
Macro, etc.,
so I hope I'm able to figure it out for VBS files.
Benny,
PS: Back later...
I maybe have to test this with interior.colorIndex all over the sheet
because
all the cells already have a border. So even if I had found the
correct syntax, I wouldn't be able to
see a border already there. hmm, maybe a thick border would do it...
On Mar 10, 3:07*pm, T Lavedas <tglba...@xxxxxx> wrote:
Quote:
> > Hi
Quote:
> > This work fine:
> > * With oExcelSheet
> > * End With
> > * wScript.quit
> > I tried
> ' Macro1 Macro
> * * * * *xlThin = 2, xlThick = 4, xlAutomatic = -4105
> * * With oExcelSheet.Range(ULCell, LRCell)
> * * For i = xlEdgeLeft To xlEdgeRight
> * * * With .Borders(i)
> * * * * .LineStyle = xlContinuous
> * * * * .Weight = xlThin
> * * * * .ColorIndex = xlAutomatic
> * * * End With
> * * Next
> * * End With
> End Sub
> provided. *It doesn't always work out as easy as this one, but usually
> Tom Lavedas
> ***********http://there.is.no.more/tglbatch/- Hide quoted text -
> - Show quoted text -
Old 03-10-2009   #4 (permalink)
T Lavedas
On Mar 10, 12:46*pm, Benny Pedersen <b.peder...@xxxxxx> wrote:
Quote:
> Thanks Tom.
> Macro, etc.,
> Benny,
> PS: Back later...
> because
Quote:
Quote:
> > > Hi
Quote:
Quote:
> > > This work fine:
> > > * With oExcelSheet
> > > * End With
> > > * wScript.quit
> > > I tried
> > ' Macro1 Macro
> > * * * End With
> > * * Next
> > * * End With
> > End Sub
Quote:
> > Tom Lavedas
> > ***********http://there.is.no.more/tglbatch/-Hide quoted text -
I just noticed that this statement is missing a comma ...
It should read ...
Const xlEdgeLeft = 7, xlEdgeRight = 10, xlContinuous =1, _
Tom Lavedas
Old 03-11-2009   #5 (permalink)
Benny Pedersen
Thanks - After I saw your code, it now worked at once in first
experiment like this:
.Range(.Cells(5,2),.Cells(5,9)).borders.lineStyle= 1
.Range(.Cells(5,2),.Cells(5,9)).borders.weight= 3
The "i" in the border syntax (round brackets) in
".borders(i)" also worked... I then tried the Macro stuff.
Hmm - in other words, I would now see
the Const Values if I modified the macro (Alt+F8), and wrote this:
Dim i: i= 0
i= i +1: Range("A" & i).FormulaR1C1= "const xlNone= " & xlNone
i= i +1: Range("A" & i).FormulaR1C1= "const xlMedium= " & xlMedium
Then I just had to copy those cells over to the VBS file. Tom, I bet
you didn't told me that, because you already knew that
I would be able to figure that out meself
Benny,
PS: Yesterday, I shot an ugly fish. Here:
http://www.elementsvillage.com/forum...002#post446002
On Mar 10, 6:30*pm, T Lavedas <tglba...@xxxxxx> wrote:
Quote:
> > Thanks Tom.
> > Macro, etc.,
Quote:
> > Benny,
> > PS: Back later...
> > because
Quote:
Quote:
Quote:
> > > > Hi
Quote:
Quote:
> > > > This work fine:
> > > > * With oExcelSheet
> > > > * End With
> > > > * wScript.quit
> > > > I tried
Quote:
Quote:
> > > ' Macro1 Macro
> > > * * * End With
> > > * * Next
> > > * * End With
> > > End Sub
Quote:
Quote:
> > > Tom Lavedas
> > > ***********http://there.is.no.more/tglbatch/-Hidequoted text -
> It should read ...
> Tom Lavedas
Old 03-12-2009   #6 (permalink)
Benny Pedersen
Hey, the make macro possibility is very smart. Most (maybe all) the
syntax we used in VBS files written in Notepad, can be executed
in the macro instead The only bad thing about the Microsoft Visual
Basic Editor is that it transform msgBox to uppercase MsgBox, etc...,
and the macro is gone when the sheet is closed.
Sub Makro1()
Cells.Select
Selection.Clear
With Selection.Interior
.ColorIndex = 2: .Pattern = xlSolid
End With
Range("C3:F8").Select
Dim i
With Selection.Borders(i)
.Weight = xlMedium
End With
Next
For i = xlDiagonalDown To xlDiagonalUp + 2
Selection.Borders(i + (i > 6) * -4).LineStyle = xlNone
MsgBox "value " & i + (i > 6) * -4, 4096, "info"
Next
End With
Range("A1").Select
End Sub
> * .Range(.Cells(5,2),.Cells(5,9)).borders.lineStyle= 1
> * .Range(.Cells(5,2),.Cells(5,9)).borders.weight= 3
> * Dim i: i= 0
> * i= i +1: Range("A" & i).FormulaR1C1= "const xlNone= " & xlNone
> * i= i +1: Range("A" & i).FormulaR1C1= "const xlMedium= " & xlMedium
> Benny,
> PS: Yesterday, I shot an ugly fish. Here:http://www.elementsvillage.com/forum...002#post446002
Quote:
Quote:
> > > Thanks Tom.
> > > Macro, etc.,
Quote:
Quote:
> > > Benny,
> > > PS: Back later...
> > > because
Quote:
Quote:
Quote:
Quote:
> > > > > Hi
Quote:
Quote:
> > > > > This work fine:
> > > > > * With oExcelSheet
> > > > > * End With
> > > > > * wScript.quit
> > > > > I tried
Quote:
Quote:
> > > > ' Macro1 Macro
> > > > * * * End With
> > > > * * Next
> > > > * * End With
> > > > End Sub
Quote:
Quote:
> > > > Tom Lavedas
> > > > ***********http://there.is.no.more/tglbatch/-Hidequotedtext -
Quote:
> > It should read ...
Quote:
> > Tom Lavedas
Quote:
> > - Show quoted text -- Hide quoted text -
Initial value in ListView cells? .NET General
Coloring the cells and text in Excel 7 Microsoft Office
Variable Height cells in a table .NET General
How to get in a vbs script the sum of values of a Excel cells in a certain range? VB Script
Re: Brain Cells - Just FYI Vista General
