| | How to insert an entry at first position of a Scripting.Dictionary ? When I create a Scripting.Dictionary with a command like Set objLines = CreateObject("Scripting.Dictionary") I can later add entries at the end with a command objLines.Add strLine, True But what if I want to insert them at the first position (and shift the existing lines one position to the end). A similar question applies to ArrayLists: Set arrList = CreateObject("System.Collections.ArrayList") How can I achieve an insert at the first position for this Object? Thomas |
| | Re: How to insert an entry at first position of aScripting.Dictionary ? On Mar 16, 3:06*am, t.lebre...@xxxxxx (Thomas Lebrecht) wrote: Quote: > When I create a Scripting.Dictionary with a command like > > Set objLines = CreateObject("Scripting.Dictionary") > > I can later add entries at the end with a command > > objLines.Add strLine, True > > But what if I want to insert them at the first position (and shift the existing lines > one position to the end). > > A similar question applies to ArrayLists: > > Set arrList = CreateObject("System.Collections.ArrayList") > > How can I achieve an insert at the first position for this Object? > > Thomas that a fundamental purpose of a dictionary is to make such an action unnecessary. Rather, the Key is used to address items in the dictionary, irrespective of their relative position in it. Without a clearer understanding of the exact objective, the best I can say is that the dictionary will need to be rebuilt. That is, temporary arrays of keys and items would need to be made from the current state of the dictionary, the dictionary emptied, the new first items added and then the arrays of keys and items added back in. This might be fine for simple lists, but would get slower and slower as the dictionary grew. Sorting an ArrayList might provide what you need, if a suitable index arrangement can be constructed, but more information about the details of your problem and objective are needed, at least as far as I am concerned. Tom Lavedas *********** http://there.is.no.more/tglbatch/ |
| | Re: How to insert an entry at first position of a Scripting.Dictionary? Thomas Lebrecht wrote: Quote: > When I create a Scripting.Dictionary with a command like > > Set objLines = CreateObject("Scripting.Dictionary") > > I can later add entries at the end with a command > > objLines.Add strLine, True > > But what if I want to insert them at the first position (and shift the existing lines > one position to the end). > > A similar question applies to ArrayLists: > > Set arrList = CreateObject("System.Collections.ArrayList") > > How can I achieve an insert at the first position for this Object? > > Thomas > Const adUseClient = 3 Const adOpenStatic = 3 Const adLockBatchOptimistic = 4 Const adInteger = 3 Const adVarChar = 200 Const adDate = 7 Const adTypeBinary = 1 Set oRs = Server.CreateObject("ADODB.Recordset") oRs.ActiveConnection = Nothing oRs.CursorLocation = adUseClient oRs.CursorType = adOpenStatic oRs.Fields.Append "Name", adVarChar, 255 oRs.Fields.Append "Size", adInteger oRs.Fields.Append "Description", adVarChar, 255 oRs.Open oRs.AddNew oRs(0) = "Anything.txt" oRs(1) = 100 oRs(2) = "Anything really" oRs.Sort = "Name" ' "Name DESC" for descending sort -- ..::[ Hz ]::. |
| | Re: How to insert an entry at first position of a Scripting.Dictionary ? "T Lavedas" <tglbatch@xxxxxx> wrote in message news:c871ea76-ce32-4779-93bc-5f33d0b27928@xxxxxx On Mar 16, 3:06 am, t.lebre...@xxxxxx (Thomas Lebrecht) wrote: Quote: > When I create a Scripting.Dictionary with a command like > > Set objLines = CreateObject("Scripting.Dictionary") > > I can later add entries at the end with a command > > objLines.Add strLine, True > > But what if I want to insert them at the first position (and shift the > existing lines > one position to the end). > > A similar question applies to ArrayLists: > > Set arrList = CreateObject("System.Collections.ArrayList") > > How can I achieve an insert at the first position for this Object? > > Thomas that a fundamental purpose of a dictionary is to make such an action unnecessary. Rather, the Key is used to address items in the dictionary, irrespective of their relative position in it. Without a clearer understanding of the exact objective, the best I can say is that the dictionary will need to be rebuilt. That is, temporary arrays of keys and items would need to be made from the current state of the dictionary, the dictionary emptied, the new first items added and then the arrays of keys and items added back in. This might be fine for simple lists, but would get slower and slower as the dictionary grew. Sorting an ArrayList might provide what you need, if a suitable index arrangement can be constructed, but more information about the details of your problem and objective are needed, at least as far as I am concerned. Tom Lavedas *********** http://there.is.no.more/tglbatch/ ------------------- Entries in a dictionary object have no order. Likewise, items in a recordset have no order, unless the recordset is sorted. -- Richard Mueller MVP Directory Services Hilltop Lab - http://www.rlmueller.net -- |
| | RE: How to insert an entry at first position of a Scripting.Dictionary Thomas, I think that everybody thinks: Why is Thomas using a scripting directory and codes like it is VB6 or VBA?" Can you describe your problem so that you can get an answer in a truly managed code way? Cor "Thomas Lebrecht" wrote: Quote: > When I create a Scripting.Dictionary with a command like > > Set objLines = CreateObject("Scripting.Dictionary") > > I can later add entries at the end with a command > > objLines.Add strLine, True > > But what if I want to insert them at the first position (and shift the existing lines > one position to the end). > > A similar question applies to ArrayLists: > > Set arrList = CreateObject("System.Collections.ArrayList") > > How can I achieve an insert at the first position for this Object? > > Thomas > > |
| | #6 (permalink) |
| | Re: How to insert an entry at first position of aScripting.Dictionary ? On Mar 16, 8:25*pm, "Richard Mueller [MVP]" <rlmueller- nos...@xxxxxx> wrote: Quote: > "T Lavedas" <tglba...@xxxxxx> wrote in message > > news:c871ea76-ce32-4779-93bc-5f33d0b27928@xxxxxx > On Mar 16, 3:06 am, t.lebre...@xxxxxx (Thomas Lebrecht) wrote: > > > Quote: > > When I create a Scripting.Dictionary with a command like Quote: > > Set objLines = CreateObject("Scripting.Dictionary") Quote: > > I can later add entries at the end with a command Quote: > > objLines.Add strLine, True Quote: > > But what if I want to insert them at the first position (and shift the > > existing lines > > one position to the end). Quote: > > A similar question applies to ArrayLists: Quote: > > Set arrList = CreateObject("System.Collections.ArrayList") Quote: > > How can I achieve an insert at the first position for this Object? Quote: > > Thomas > Can you explain why you want/need to do this, since it is my belief > that a fundamental purpose of a dictionary is to make such an action > unnecessary. *Rather, the Key is used to address items in the > dictionary, irrespective of their relative position in it. > > Without a clearer understanding of the exact objective, the best I can > say is that the dictionary will need to be rebuilt. *That is, > temporary arrays of keys and items would need to be made from the > current state of the dictionary, the dictionary emptied, the new first > items added and then the arrays of keys and items added back in. *This > might be fine for simple lists, but would get slower and slower as the > dictionary grew. > > Sorting an ArrayList might provide what you need, if a suitable index > arrangement can be constructed, but more information about the details > of your problem and objective are needed, at least as far as I am > concerned. > > Tom Lavedas > ***********http://there.is.no.more/tglbatch/ > > ------------------- > > Entries in a dictionary object have no order. Likewise, items in a recordset > have no order, unless the recordset is sorted. > > -- > Richard Mueller > MVP Directory Services > Hilltop Lab -http://www.rlmueller.net > -- true. That is what my first statement was trying to convey. However, in a practical sense they have the order in which the data is 'added' to the set. Witness the fact that the conversion of items and keys to arrays results in the elements being in that order in each of the arrays. For example, ... Set objList = CreateObject("Scripting.Dictionary") objList.Add "One", 1 objList.Add "Three", 3 objList.Add "Two", 2 arrKeys = objList.Keys arrItems = objList.Items wsh.echo Join(arrKeys, vbTab), vbNewline & Join(arrItems, vbTab) If your point was that the OP was confused about the purpose and use of a dictionary object, I would agree. Again, that is exactly what I was trying to get across. If that's not your point, you'll need to explain, because I'm too dense to understand it. Tom Lavedas *********** http://there.is.no.more/tglbatch/ |
| | #7 (permalink) |
| | Re: How to insert an entry at first position of a Scripting.Dictionary? Oh, I think what you mean now. The text on a page in a book needs to be in a certain order. Sorting it would make it unreadable. I think this is what you want: '############################################################################### '# Run it using CScript '# '# Code by Hz - 2009 '############################################################################### Dim oAl Set oAl = CreateObject("System.Collections.ArrayList") oAl.Add "First line" oAl.Add "Second line" oAl.Add "Third line" oAl.Add "Fifth line" Show oAl '# Insert at the specified index (zero based) oAl.Insert 3, "Fourth line" Show oAl Set oAl = Nothing Sub Show(ByVal inArr) Dim OutText For Each Item In inArr OutText = OutText & " " & Item Next Trim(OutText) WScript.Echo OutText End Sub -- ..::[ Hz ]::. |
| | #8 (permalink) |
| | Re: How to insert an entry at first position of a Scripting.Dictionary? I was too quick to post my code. Here is a better version --------------------------- '############################################################################### '# Run it using CScript '# '# Code by Hz - 2009 '############################################################################### Option Explicit Dim oAl Set oAl = CreateObject("System.Collections.ArrayList") oAl.Add "First line" oAl.Add "Second line" oAl.Add "Third line" oAl.Add "Fifth line" Show oAl oAl.Insert 3, "Fourth line" Show oAl Set oAl = Nothing Sub Show(ByVal inArr) Dim OutText, Item For Each Item In inArr WScript.Echo Item Next WScript.Echo End Sub --------------------------- Output: Quote: >cscript.exe //nologo "C:\Users\Hz\Documents\Programming\ArrayList 2.vbs" Second line Third line Fifth line First line Second line Third line Fourth line Fifth line Quote: >Exit code: 0 ..::[ Hz ]::. |
| | #9 (permalink) |
| | Re: How to insert an entry at first position of a Scripting.Dictionary? Hz wrote: Quote: > Oh, I think what you mean now. The text on a page in a book needs to be > in a certain order. Sorting it would make it unreadable. The textLINES on a page in a book needs to be in a certain order. Sorting them would make it unreadable. -- ..::[ Hz ]::. |
| Windows Mail - How Do I Edit or Delete Entry in User Dictionary | Vista mail | |||
| Dictionary<TKey,TValue> as a Dictionary key in C# 2.0 | .NET General | |||
| UK Dictionary | Live Mail | |||
| CD Insert/Jewel Case Insert Maker ignored? | Vista music pictures video | |||
