Vista - problem with running script remotely - ODBC connection - ORACLE DB
Old 03-20-2009   #1 (permalink)
esska
I wrote script which connect to oracle 10. It works locally, but when
I try to run this remotely I get error that connection can't be done.
I try to use driver for Oraclecilen
I have client at different machine. When I try to add driver paramter
in ODBC connection I receieve error:
Provider for ODBC Drivers: [Microsoft][ODBC Driver Manager] Data
source name no
t found and no default driver specified
the erros is in this line: connection.Open connectionString
I tried everything to run this by SCOM.
The script is below:
' Parameters that should be passed to this script
' 1 st - User name for database
' 2 nd - Password
' 3 rd - FileFlag
' 4 th - sth
' 5 th - sth
Set collArg = WScript.Arguments
If collArg.Count < 5 Then 'brak argumentow
Set WshShell = WScript.CreateObject("WScript.Shell")
strCommand = "eventcreate /T Informtion /SO XXXX /ID 123 /L
Application /D " & _
Chr(34) & "Script '" & Wscript.ScriptName & "' has wrong number
of parameters."& Chr(34)
WshShell.Run strCommand
Else ' ok
Dim User, Password, BackupFlag, a, b
User = collArg(0)
Password = collArg(1)
BackupFlag = collArg(2)
a= CInt(collArg(3))
b= CInt(collArg(4))
Set fs = CreateObject("Scripting.FileSystemObject")
If fs.FileExists(file) Then
else
'Dim connectionString: connectionString =
"dsn=ORACLE;uid=XXXX;pwd=XXXX"
"server=FQDN;dsn=ORACLE;uid=XXX;pwd=XXXX"
Dim connection: Set connection = CreateObject("ADODB.Connection")
Dim rows: Set rows = CreateObject("ADODB.Recordset")
Set connectionString = Nothing
Set connection = Nothing
End If
End If
any idea?
Old 03-20-2009   #2 (permalink)
esska
Re: problem with running script remotely - ODBC connection - ORACLEDB
the error is:
The connection cannot be used to perform this operation. It is either
closed or invalid in this context. ADODB.Recordset
any idea?
Old 03-20-2009   #3 (permalink)
gimme_this_gimme_that
You need to register your Oracle database with ODBC and test it there
to see if it connects.
How to login any Windows Machine remotely using script VB Script
Script to install application remotely on a windows machine VB Script
odbc connection Microsoft Office
Oracle ODBC driver and Vista Vista General
I have a problem creating a ODBC connection to a Foxpro Database!! Vista file management
