| | Difference between a domain group and a local group Richard Mueller made this comment about his AddToGroup.vbs script: --- A quick comment. Rather than maintaining a list of users, you could create a domain group. Make the users members of the domain group, then make the domain group a member of the local group on each computer. The machine local group is altered once, then thereafter the list is maintained by altering the domain group membership. --- What is the difference between a domain group and a local group. Could someone provide a longer version of this quick comment? Thanks. |
| | Re: Difference between a domain group and a local group Nevermind. The idea behind AddToGroup.vbs was to add users to a computer's local group and creating a domain group to manage membership was the tip. Got it. |
| | Re: Difference between a domain group and a local group <gimme_this_gimme_that@xxxxxx> wrote in message news:c010b1ed-1691-487b-b071-359b63d5168b@xxxxxx Quote: > Richard Mueller made this comment about his AddToGroup.vbs script: > > --- > A quick comment. Rather than maintaining a list of users, > you could create a domain group. Make the users members of > the domain group, then make the domain group a member of > the local group on each computer. The machine local group > is altered once, then thereafter the list is maintained by > altering the domain group membership. > --- > > What is the difference between a domain group and a local group. controller. A domain group is defined on all of the domain controllers in a domain. Of course, a domain group can be Universal, domain global, or domain local, whereas a computer local group can only be local. Quote: > Could someone provide a longer version of this quick comment? question is the local administrators group and that you had a group of domain users who were all to be given administrator access to the computers in question, you would create a domain global group in the same domain in which the user accounts exist. You would then add the users to this group. Then on each computer you would add the above mentioned domain group as a member of the local administrators group. I don't know if that is longer or shorter, however, managing groups this way is a very common activity for administrators. But this has nothing to do with scripting, per se, so perhaps you should spend some time in an active directory newsgroup to pick up on this aspect of your problem. /Al |
| | Re: Difference between a domain group and a local group Thanks Al. I learned something from your post. |
| "add domain group to local group" stopped working | VB Script | |||
| add a global group to a domain local group | VB Script | |||
| Add domain group to local group question | VB Script | |||
| Add NT 4 Domain User to Local Adminstrators Group | Vista account administration | |||
| adding a domain user to the local group | PowerShell | |||
