| | Need help to retrieve ACL from FileSystem in csv Hi everybody I'm doing to re-build my Active directory and all servers substructure and for this end i look for vbs or powershell script can export ACL to CSV or TXT file google my freind found several links to do it but for each case: there is CSV in bad format or script stops when occurs an acces denied error. there is somebody have a script to do it with error less? Thank you for your help, and sorry for the langage i'm aware that my english isn't very well. Lyes |
| Compatibility Filesystem | Vista General | |||
| filesystem error | Vista performance & maintenance | |||
| WPD filesystem error | Vista hardware & devices | |||
| filesystem | Vista security | |||
