Vista - Find my current drive letter and execute a program from it while i
Old 03-23-2009   #1 (permalink)
Luka1993
HI!
The problem is that when i change the directory to usbletter:\SYSTEM i can't
find a way to execute a program from the source directory where this script
is located.
Thank you in advance.
If this helps, this script was meant to be ran from a CD. Then it would find
the USB and so on.
Sorry for my bad writing, im only 15 and im not a programmer i just want to
edit this script and learn.
Luka
Here is the code: Look at the comments marked with '
Set objFSO = CreateObject("Scripting.FileSystemObject")
Set objShell = CreateObject("Wscript.Shell")
Set colDrives = objFSO.Drives
Set objEnv = objShell.Environment("PROCESS")
objEnv("Year") = Year(now())
objEnv("Month") = Right("0" & Month(now()), 2)
objEnv("Day") = Right("0" & Day(now()), 2)
objEnv("Hour") = Right("0" & Hour(now()), 2)
objEnv("Minute") = Right("0" & Minute(now()), 2)
objEnv("Second") = Right("0" & Second(now()), 2)
For Each objDrive in colDrives
If objFSO.FileExists(objDrive.DriveLetter & ":\usbishere.txt") Then
'find my USB
strPath = objDrive.Driveletter & ":" 'sets the USB letter
sPathSpec = strPath & "\SYSTEM" 'change the path into a path on
the USB
CreateObject("Wscript.Shell").CurrentDirectory = sPathSpec
'now this is where i want to execute a program from the folder this script
is located WHILE in the \SYSTEM folder on the usb.
End If
Next
Old 03-23-2009   #2 (permalink)
Sam Hays
Re: Find my current drive letter and execute a program from it while i
Just to make sure I understand: you want to run a file at the location where
the VBScript is running from - not necessarily on the USBdrive?
If that's the case - the path of the running vbscript can be obtained with
the following script:
lenScriptFullName= len(wscript.scriptfullname)
b = 0
for l = lenScriptFullName to 1 step -1
if b <> 1 then
if mid(Wscript.scriptfullname, l, 1) <> "\" then
a=a+1
else
b=1
end if
end if
next
totrim = len(wscript.scriptfullname) - a
wscript.echo mid(wscript.scriptfullname, 1, totrim)
Good luck sir
Sam
"Luka1993" <Luka1993@xxxxxx> wrote in message
news:0CB252CE-0A69-4C3B-8811-51383D17767F@xxxxxx
Quote:
> HI!
> can't
> script
> is located.
> find
> the USB and so on.
> to
> Luka
> 'find my USB
> on
> the USB
> End If
> Next
Old 03-23-2009   #3 (permalink)
James Whitlow
Quote:
> HI!
> can't
> script
> is located.
Since you are already instantiating 'Scripting.FileSystemObject', use the
'GetParentFolderName' method:
sScriptPath = objFSO.GetParentFolderName(WScript.ScriptFullName)
Old 03-23-2009   #4 (permalink)
Luka1993
Thank you
Thanks to both of you.
Yes, you both understood what i was trying to say but can you tell me where
to put this code and how to use it because im 15 and a beginner :P.
You alredy helped me alot
Thank you!
Old 03-23-2009   #5 (permalink)
Luka1993
Thank you
Thanks! You both understood me.
I tried to put this in the code but i got and error. I am a beginner, so,
what am i doing wrong?
For Each objDrive in objFSO.Drives
If objDrive.IsReady Then
If objFSO.FileExists(objDrive.DriveLetter & ":\flashdrive.txt") Then
sPathSpec = strPath & "\SYSTEM\LOGS"
objShell.Run sScriptPath & "\example.exe"
End If
End If
Next
Old 03-23-2009   #6 (permalink)
James Whitlow
Re: Thank you
news:F67378F9-8DDE-4176-9F3C-5D4F062B30BD@xxxxxx
> End If
> End If
> Next
Change line 18 to: objShell.CurrentDirectory = sPathSpec
I have a question. Why are you changing the current directory of the
script?
Also, are you planning on running this script from a single flash drive or
from many flash drives? If you are using a single flash drive, you could
check for the 'VolumeName' or 'SerialNumber' properties and avoid creating
and then testing for a trigger file.
Old 03-23-2009   #7 (permalink)
Luka1993
Re: Thank you
Hi!
Thank you again.
I am running this script from a CD wich will find a USB that me only will
use. I could use the label to recognise it too but i didnt know how.
The CD finds my USB and goes to USB:\SYSTEM folder and executes
CD:\something.exe.
If you have a better idea for making this file then suggest please
The perfect idea would be:
-get the USB letter from label
-get the CD letter (where my script is)
-go to USB:\SYSTEM
-execute CD:\something.exe
that is what i want actually :S
Old 03-23-2009   #8 (permalink)
Hz
Re: Find my current drive letter and execute a program from it whilei
Sam Hays wrote:
> where the VBScript is running from - not necessarily on the USBdrive?
> with the following script:
> b = 0
> if b <> 1 then
> a=a+1
> else
> b=1
> end if
> end if
> next
a = WScript.ScriptFullName
b = WScript.ScriptName
c = Len(a) - Len(b)
WScript.Echo Left(a, c)
..::[ Hz ]::.
Old 03-24-2009   #9 (permalink)
James Whitlow
Re: Thank you
news:66EACF41-F7F3-4394-903F-E12F1A3EE60A@xxxxxx
Quote:
> Hi!
> Thank you again.
Using either the volume name or the serial number is basically the same.
You would replace:
OLD: If objFSO.FileExists(objDrive.DriveLetter & ":\flashdrive.txt") Then
NEW: If objDrive.VolumeName = "SCRIPTFLASH" Then
You could also use the serial number:
If objDrive.SerialNumber = &H50187D93 Then
You can find it from the command line by typing 'vol {drive letter}' from
a command prompt (ex: vol c. You will see output like:
Volume in drive C has no label.
Volume Serial Number is 5018-7D93
To use it in your script, just remove the dash from the center and prefix
(&H) before it to tell VBScript it is a hexadecimal number.
See above. Use volume label, serial number or, as you have already done,
use a trigger file.
To get the drive letter or path, use the methods of
'Scripting.FileSystemObject'. To get the drive letter of the drive where the
script was launched from:
sScriptDrive = objFSO.GetDriveName(WScript.ScriptFullName)
To get the full path to the script:
Quote:
> -go to USB:\SYSTEM
As you have already done:
As you have already done. I would suggest wrapping the path and filename
in quotes, though:
objShell.Run """" & sScriptPath & "\example.exe" & """"
Without the quote wrapping, your script would fail if there is a space in
any of the folders in the path to the script itself. So, assuming that the
serial number of your flash drive is '5018-7D93', your script could look
like this:
End If
End If
Next
Old 03-24-2009   #10 (permalink)
Luka1993
Re: Thank you
The script is working and i used the serial number, it really is a better
idea
This was exactly what i wanted
Thank you soooo much!!!
How to execute external program from powershell PowerShell
find the current stat and reboot VB Script
find current boot configuration Vista General
Re: cannot execute program in dir with space and argument PowerShell
Execute scripts in current scope? PowerShell
