| | How to combine/return multiple values from a sql query Hi guys. I've been stuck on this for a while as a newb, so please forgive me in advance. Any help would be very appreciated. I wrote a little script to query a sql server database. Everything works except the fact that more than one recordset can be returned, and each record can have more than one "Standard". How can I get the multiple values of this field for each record and string them into one element/field (this is for transmitting to FileNet with XML code). Set objConn = CreateObject("ADODB.Connection") strConnection = "Driver={SQL Server};SERVER=test;Database=mydb;UID=AppUID;PWD=pwd" objConn.Open strConnection Set objRS=CreateObject("ADODB.Recordset") strSQLQuery = "SELECT a.TestNumber, a.MTE, a.Cust_MTE, a.Manufacturer, a.Model, a.Serial, " & _ "a.Description, a.CustomerName, a.CustomerType, a.Technician, a.Inspector, a.CalDate, a.DueDate, " & _ "a.AsFoundCode, a.AsReturnCode, a.PO_Number, a.CompletedDate, a.CustomerID, a.Vendor, " & _ "a.QCApprovedBy, a.QCApprovedDate, b.CalProcedure, b.Rev_No, c.STAND_ID " & _ "FROM LIMS_Cal_StandardsUsed AS c RIGHT JOIN (LIMS_Assets_CalProcsDef AS b " & _ "INNER JOIN LIMS_CalRecord AS a ON b.MTE_PUI = a.MTE_PUI) ON c.TNPUI = a.PUI " & _ "WHERE (((a.TestNumber)='" & strPDFNumber & "'))" objRS.Open strSQLQuery, objConn if objRS.EOF then Dim fso1, tf Set fso1 = CreateObject("Scripting.FileSystemObject") Set tf = fso1.OpenTextFile("\\chaclsgfp1\apps\MudCats\ErrorLog.txt", ForAppending, True) tf.WriteLine ("Error finding record in database: " & strPDFNumber & " " & strDate) tf.close Err.Clear end if 'Take the names from the recordset strTestNumber = objRS(0) strMTE = objRS(1) strCustMTE = objRS(2) strSerial = objRS(5) strCustType = objRS(8) strCalDate = objRS(11) strDueDate = objRS(12) strInstruction = objRS(21) strStandard = objRS(23) if strStandard = "" Then strStandard = "NONE" end if XML Portion - Each record returned from the query above can have more than one Standard. 'idmDocMvCustom2 - Reference with DocElem.appendChild(Request.createElement("property")) .setAttribute "label", "Reference (M)" .appendChild(Request.createElement("value")).text = strCalDate .appendChild(Request.createElement("value")).text = strStatus .appendChild(Request.createElement("value")).text = strInstruction .appendChild(Request.createElement("value")).text = strStandard .appendChild(Request.createElement("value")).text = strTestNumber .appendChild(Request.createElement("value")).text = strCustMTE .appendChild(Request.createElement("value")).text = strSerial .appendChild(Request.createElement("value")).text = strCustType .appendChild(Request.createElement("value")).text = "Calibrated By: " & strInspector end with |
| | Re: How to combine/return multiple values from a sql query "Holly" <excyauseme@xxxxxx> wrote in message news:57d44437-55b0-415f-8909-33c2602d9190@xxxxxx Quote: > Hi guys. > I've been stuck on this for a while as a newb, so please forgive me in > advance. > Any help would be very appreciated. > > I wrote a little script to query a sql server database. > Everything works except the fact that more than one recordset can be > returned, and each record can have more than one "Standard". How can > I get the multiple values of this field for each record and string > them into one element/field (this is for transmitting to FileNet with > XML code). > > Set objConn = CreateObject("ADODB.Connection") > strConnection = "Driver={SQL > Server};SERVER=test;Database=mydb;UID=AppUID;PWD=pwd" > > objConn.Open strConnection > > Set objRS=CreateObject("ADODB.Recordset") > > strSQLQuery = "SELECT a.TestNumber, a.MTE, a.Cust_MTE, a.Manufacturer, > a.Model, a.Serial, " & _ > "a.Description, a.CustomerName, a.CustomerType, a.Technician, > a.Inspector, a.CalDate, a.DueDate, " & _ > "a.AsFoundCode, a.AsReturnCode, a.PO_Number, a.CompletedDate, > a.CustomerID, a.Vendor, " & _ > "a.QCApprovedBy, a.QCApprovedDate, b.CalProcedure, b.Rev_No, > c.STAND_ID " & _ > "FROM LIMS_Cal_StandardsUsed AS c RIGHT JOIN (LIMS_Assets_CalProcsDef > AS b " & _ > "INNER JOIN LIMS_CalRecord AS a ON b.MTE_PUI = a.MTE_PUI) ON c.TNPUI = > a.PUI " & _ > "WHERE (((a.TestNumber)='" & strPDFNumber & "'))" > > objRS.Open strSQLQuery, objConn > > if objRS.EOF then > Dim fso1, tf > Set fso1 = CreateObject("Scripting.FileSystemObject") > Set tf = fso1.OpenTextFile("\\chaclsgfp1\apps\MudCats\ErrorLog.txt", > ForAppending, True) > tf.WriteLine ("Error finding record in database: " & strPDFNumber & " > " & strDate) > tf.close > Err.Clear > end if > > 'Take the names from the recordset > strTestNumber = objRS(0) > strMTE = objRS(1) > strCustMTE = objRS(2) > strSerial = objRS(5) > strCustType = objRS(8) > strCalDate = objRS(11) > strDueDate = objRS(12) > strInstruction = objRS(21) > strStandard = objRS(23) > > if strStandard = "" Then > strStandard = "NONE" > end if > > XML Portion - Each record returned from the query above can have more > than one Standard. > > 'idmDocMvCustom2 - Reference > with DocElem.appendChild(Request.createElement("property")) > .setAttribute "label", "Reference (M)" > .appendChild(Request.createElement("value")).text = strCalDate > .appendChild(Request.createElement("value")).text = strStatus > .appendChild(Request.createElement("value")).text = strInstruction > .appendChild(Request.createElement("value")).text = strStandard > .appendChild(Request.createElement("value")).text = strTestNumber > .appendChild(Request.createElement("value")).text = strCustMTE > .appendChild(Request.createElement("value")).text = strSerial > .appendChild(Request.createElement("value")).text = strCustType > .appendChild(Request.createElement("value")).text = "Calibrated By: > " & strInspector > end with joins several tables, but you get one recordset, with possibly many rows. However, you only read the first row. You need to loop through all of the rows. I don't know how you want to combine the results from all rows, but in the example below I concatenate values into one string for each field: ======== ' Read each row of the recordset Do Until objRS.EOF ' Read values from this row. strTestNumber = strTestNumber & "," & objRS(0) strMTE = strMTE & "," & objRS(1) strCustMTE = strCustMTE & "," & objRS(2) strSerial = strSerial & "," & objRS(5) strCustType = strCustType & "," & objRS(8) strCalDate = strCalDate & "," & objRS(11) strDueDate = strDueDate & "," & objRS(12) strInstruction = strInstruction & "," & objRS(21) strStandard = strStandard & "," & objRS(23) ' Move to the next row. objRS.MoveNext Loop ' Clean up. objRS.Close ======== Actually, I prefer referring to fields by name rather than some index number. For example: ========== ' Read each row of the recordset Do Until objRS.EOF ' Read values from this row. strTestNumber = strTestNumber & "," & objRS.Fields("TestNumber").Value strMTE = strMTE & "," & objRS.Fields("MTE").Value strCustMTE = strCustMTE & "," & objRS.Fields("Cust_MTE").Value strSerial = strSerial & "," & objRS.Fields("Serial").Value strCustType = strCustType & "," & objRS.Fields("CustomerType").Value strCalDate = strCalDate & "," & objRS.Fields("CalDate").Value strDueDate = strDueDate & "," & objRS.Fields("DueDate").Value strInstruction = strInstruction & "," & objRS.Fields("CalProcedure").Value strStandard = strStandard & "," & objRS.Fields("STAND_ID").Value ' Move to the next row. objRS.MoveNext Loop ' Clean up. objRS.Close ========= You could add code to remove (or prevent) the leading comma in each string. You get the idea. -- Richard Mueller MVP Directory Services Hilltop Lab - http://www.rlmueller.net -- |
| Return values from functions | PowerShell | |||
| Query user id return computer name | PowerShell | |||
| Query csv and return all entries within last x days | VB Script | |||
| Associative Array - how to return mapped values? | PowerShell | |||
| function return values, console output | PowerShell | |||
