Vista - Extracting drive, path, filebasename WITH string functions and NOT system function ???
Old 04-01-2009   #1 (permalink)
Thomas Lebrecht
Recently I asked here for functions to extract the individual
parts (drive, path, filebase and extension) from a string like:
myfile="D:\aaa\bbb\ccc\ddd.txt"
I was told to use built-in functions like:
Set objFSO = CreateObject("Scripting.FileSystemObject")
Set objFile = objFSO.GetFile(strFile)
Set objFolder = objFile.ParentFolder
Wscript.Echo "Filename : " & objFile.Name
Wscript.Echo "Path : " & objFile.ParentFolder
But the big disadvantage here is that the file MUST exist.
But what if the filenamestring is passed as parameter and tells which log file should be created
(in the future). At the moment of processing the logfile does not exist yet.
So all the built-in funtion don't work and I get an error.
I must use some string manipulation functions like:
Wscript.Echo "Path : " & Left(strFile, InstrRev(strFile, "\"))
But how can I extract similarly filebase name ("ddd"), extension ("txt"),
filename ("ddd.txt") and drive ("D:") with string search and copy functions?
Thomas
Old 04-01-2009   #2 (permalink)
Pegasus [MVP]
Re: Extracting drive, path, filebasename WITH string functions and NOT system function ???
"Thomas Lebrecht" <t.lebrecht@xxxxxx> wrote in message
news:49d328f1$0$30236$9b4e6d93@xxxxxx-online.net...
> yet.
> functions?
> Thomas
To extract the file name, use the "mid" function in order to extract all
characters after the right-most backslash. InstrRev(strFile, "\") will help
you locate it.
To extract the file extension, use the "mid" function in order to extract
all characters after the right-most full stop. InstrRev(strFile, ".") will
help you locate it.
Old 04-01-2009   #3 (permalink)
Steve
> log file should be created (in the future). At the moment of
> ("txt"),
> functions?
Paul Randall's reply to your original post explained that the
FileSystemObject object has methods to parse a string to extract the
information. You really should download the scripting help file
(script56.chm) if it's not already on your system.
Wscript.Echo "Filename : " & objFSO.GetFileName(myfile)
Wscript.Echo "Path : " & objFSO.GetParentFolderName(myfile)
Wscript.Echo "File basename : " & objFSO.GetBaseName(myfile)
Wscript.Echo "Extension : " & objFSO.GetExtensionName(myfile)
Wscript.Echo "Drive : " & objFSO.GetDriveName(myfile)
As the documentation says: (Honestly, install the docs!) the methods
work only on the provided path string. They do not attempt to resolve
the path, nor check for the existence of the specified path.
Steve
When a man wants to murder a tiger he calls it sport; when the tiger
wants to murder him he calls it ferocity. -George Bernard Shaw
Old 04-01-2009   #4 (permalink)
Pegasus [MVP]
"Steve" <cerberus40@xxxxxx> wrote in message
news:eRg268qsJHA.5912@xxxxxx
>> ("txt"),
>> functions?
> Steve
If the file in question does not exist then the OP will not be able to
create an object based on the file name. As he correctly says, this will
prevent him from extracting the various file name components using FSO
methods. He must use string manipulation techniques, as he suspected.
Old 04-01-2009   #5 (permalink)
Armin Zingler
Recently I told you, NOT to post vbscript questions to the VB.net group. I
tell you again, now.
Armin
Old 04-01-2009   #6 (permalink)
Michael Williams
"Armin Zingler" <az.nospam@xxxxxx> wrote in message
news:Od0T0grsJHA.3928@xxxxxx
Quote:
> Recently I told you [Thomas Lebrecht], NOT to post vbscript
> questions to the VB.net group. I tell you again, now.
Why not? It's got "vb" in its name, so it's fair game ;-) At least that's
what the various dotnet evangelists such as the idiot McCarthy tell us when
we ask people not to post vb.net questions to the class Visual Basic group!
Mike
Old 04-01-2009   #7 (permalink)
T Lavedas
Re: Extracting drive, path, filebasename WITH string functions andNOT system function ???
On Apr 1, 5:57*am, "Pegasus [MVP]" <n...@xxxxxx> wrote:
Quote:
> "Steve" <cerberu...@xxxxxx> wrote in message
Quote:
> >> Wscript.Echo "Filename * * * * *: " & objFile.Name
> >> Wscript.Echo "Path * * * * * * *: " & objFile.ParentFolder
Quote:
Quote:
Quote:
Quote:
> >> Wscript.Echo "Path * * * * * * *: " & Left(strFile, InstrRev(strFile,
Quote:
> >> ("txt"),
> >> functions?
Quote:
> > *Set objFSO = CreateObject("Scripting.FileSystemObject")
> > *Wscript.Echo "Filename * * * : " & objFSO.GetFileName(myfile)
> > *Wscript.Echo "Path * * * * * : " & objFSO.GetParentFolderName(myfile)
> > *Wscript.Echo "File basename *: " & objFSO.GetBaseName(myfile)
> > *Wscript.Echo "Extension * * *: " & objFSO.GetExtensionName(myfile)
> > *Wscript.Echo "Drive * * * * *: " & objFSO.GetDriveName(myfile)
Quote:
> > Steve
I believe you're assertion is incorrect. No file needs to exist to
use FSO to *parse strings* that look like file paths. (Which is what
the OP states is his objective.) Because the path does not exist does
not limit the ability to parse it. IMHO, the practicalities of using
the parsed information is another issue, entirely. The trick, as
Steve's examples illustrate, is to use the appropriate FSO parsing
methods, as opposed to trying to access the non-existent file's
properties. There is a difference.
Tom Lavedas
http://there.is.no.more/tglbatch/
Old 04-01-2009   #8 (permalink)
Pegasus [MVP]
"T Lavedas" <tglbatch@xxxxxx> wrote in message
news:ea0c50b8-6fae-456a-adb8-f009c77b5f94@xxxxxx
Quote:
Quote:
Quote:
Quote:
> >> ("txt"),
> >> functions?
Quote:
> > Steve
Tom Lavedas
Sounds good but how exactly would you do it? The following script fails as
expected:
Set oFSO = CreateObject("Scripting.FileSystemObject")
Set oFile = oFSO.GetFile("c:\SomePath\Some File.txt")
WScript.Echo oFile.Path, oFile.Name, oFile.Type
And how would you get the file extension as opposed to the file type?
Old 04-01-2009   #9 (permalink)
Paul Randall
> yet.
> functions?
> Thomas
Hi, Thomas
As I said in my previous post, the names of the FSO path parsing methods
start with GET and end with NAME. These methods take strings as arguments
and return strings as results. The FSO does not care whether the path
actually exists.
GetAbsolutePathName
GetBaseName
GetDriveName
GetExtensionName
GetFileName
GetParentFolderName
The FSO path-parsing methods are also happy to parse strings that are
similar to file paths, such as URLs. In my experience, it treats forward
and back slashes the same.
-Paul Randall
Old 04-01-2009   #10 (permalink)
Paul Randall
"Pegasus [MVP]" <news@xxxxxx> wrote in message
news:%23ZHAYDusJHA.1212@xxxxxx
>> >> ("txt"),
>> >> functions?
Quote:
>> > Steve
> Tom Lavedas
> expected:
Don't GetFile; GetFileName
-Paul Randall
Create a path string VB Script
Extracting drive, path filebasename or extension from complete filename? VB Script
Re: Extracting the last char from the string VB Script
Sub String / Trim functions PowerShell
