| | How to write a formatted number left-padded right-aligned into a 6-char-wide-column? I would like to write a number from variable myvar into a file. The number should be written in a formatted way in a 6-char width column/field. The output should be right-aligned and a) zero padded b) blank padded Example: say current value = 45 then the line in the file should look like for: a) 000045 b) 45 How can I do this formatting in vbscript? Ken |
| | Re: How to write a formatted number left-padded right-aligned into a 6-char-wide-column? "Ken Tucker" <kenny23@xxxxxx> wrote in message news:49d4627e$0$32666$9b4e6d93@xxxxxx-online.net... Quote: >I would like to write a number from variable myvar into a file. > The number should be written in a formatted way in a 6-char width > column/field. > The output should be right-aligned and > a) zero padded > b) blank padded > > Example: say current value = 45 then the line in the file should look like > for: > > a) > 000045 > > b) > 45 > > How can I do this formatting in vbscript? > > Ken > x = right("000000" & x, 6) y = right(spaces(6) & y, 6) |
| | Re: How to write a formatted number left-padded right-aligned into a6-char-wide-column? Function FormatInteger(a,b) c = cstr(a) n = b - (Len(c) + 1) For i = 0 to n c = "0" & c Next FormatInteger = c End Function Wscript.echo FormatInteger(45,6) |
| | Re: How to write a formatted number left-padded right-aligned intoa 6-char-wide-column? Ken Tucker schrieb: Quote: > I would like to write a number from variable myvar into a file. > The number should be written in a formatted way in a 6-char width column/field. > The output should be right-aligned and > a) zero padded > b) blank padded Sample code: Dim dicFuncs : Set dicFuncs = CreateObject( "Scripting.Dictionary" ) Set dicFuncs( "P" ) = GetRef( "FN_P" ) Set dicFuncs( "G" ) = GetRef( "FN_G" ) Set dicFuncs( "E" ) = GetRef( "FN_E" ) Set dicFuncs( "N" ) = GetRef( "FN_N" ) Dim aTests : aTests = Array( _ Array( 6, 45, 123456, 1234567 ) _ ) Dim aTest For Each aTest In aTests Dim nNum For nNUm = 1 To UBound( aTest ) Wscript.Echo "Width:", aTest( 0 ), "Number:", aTest( nNum ) Dim sFunc For Each sFunc In dicFuncs.Keys() WScript.Echo " " & sFunc _ & ": >" _ & dicFuncs( sFunc )( aTest( nNum ), " ", aTest( 0 ) ) _ & "<" Next Next Next Function FN_P( nInt, sFillChar, nWidth ) FN_P = Right( String( nWidth, sFillChar ) & nInt, nWidth ) End Function Function FN_G( nInt, sFillChar, nWidth ) Dim sInt : sInt = CStr( nInt ) Dim nAdd : nAdd = nWidth - (Len( sInt ) + 1) Dim nIdx For nIdx = 0 To nAdd sInt = sFillChar & sInt Next FN_G = sInt End Function Function FN_E( nInt, sFillChar, nWidth ) Dim sInt : sInt = CStr( nInt ) Dim nAdd : nAdd = nWidth - Len( sInt ) If 0 < nAdd Then sInt = String( nAdd, sFillChar ) & sInt FN_E = sInt End Function Function FN_N( nInt, sFillChar, nWidth ) Dim sFmt : sFmt = "{0," & nWidth & " }"FN_N = DNIPrintF( sFmt, Array( nInt ) ) End Function ' ---------------------------------------------------------------------------- '' DNIPrintF( sFmt, aItems ) - use .NET to sprintf() ' ---------------------------------------------------------------------------- Dim goSB : Set goSB = Nothing Function DNIPrintF2( sFmt, aItems ) If goSB Is Nothing Then Set goSB = CreateObject( "System.Text.StringBuilder" ) Else goSB.Length = 0 End If goSB.AppendFormat_4 sFmt, (aItems) DNIPrintF2 = goSB.ToString() End Function and output: === frmNum: format number ========== Width: 6 Number: 45 P: > 45< G: > 45< E: > 45< N: > 45< Width: 6 Number: 123456 P: >123456< G: >123456< E: >123456< N: >123456< Width: 6 Number: 1234567 P: >234567< ############ here are dragons! ######### G: >1234567< E: >1234567< N: >1234567< === frmNum: 0 done (00:00:01) ====== to show that P's code is dangerous G's code can be made more efficient (no string concatenation) there is lot of potential in the .Net components that can be used from VBScript (But I don't see a way to specify a fill character) |
| Contacts in left column? | Vista mail | |||
| Re: how to count number of certain char within string | PowerShell | |||
| restore left column | Vista mail | |||
| Is there a way to get Format-Wide to sort by column? | PowerShell | |||
| RuntimeType format uses excessively wide name column | PowerShell | |||
