| | RSOP Planning mode - Provider load failure. I am having trouble performing RSOP Planning mode in a VB script. When I try to perform it, I get the error "Provider Load Failure" I am using a domain admin account to run it on an XP client (domain member). However, when I run the GPMC RSOP Planning on the same machine, and using the same information, no error. I can also run the script on a DC with no error. Here is the code - any suggestions??? strComputer = "cn=xp1,ou=Desktops,dc=testdom" Set objLocator = CreateObject("WbemScripting.SWbemLocator") Set objCon = objLocator.ConnectServer(".", "root\rsop", null, null, null, null, 0, null) Set objProvider = objCon.Get("RsopPlanningModeProvider") objProvider.RsopCreateSession 0, strComputer, Null, Null, Null, Null, Null, Null, Null, Null, ns, hr, ei Error occurs on the last line. Any advice appreciated. |
| | Re: RSOP Planning mode - Provider load failure. D'oh - fixed my own problem. The first parameter in the ConnectServer method is the computer which will conduct the RSOP planning function. Of course, this needs to be a Domain Controller. That's why the script worked when executing on the DC. "Wake-Up-Jeff" <artvandal8@xxxxxx> wrote in message news:%23iA3VmBtJHA.248@xxxxxx Quote: >I am having trouble performing RSOP Planning mode in a VB script. > When I try to perform it, I get the error "Provider Load Failure" > I am using a domain admin account to run it on an XP client (domain > member). > However, when I run the GPMC RSOP Planning on the same machine, and using > the same information, no error. > I can also run the script on a DC with no error. > > Here is the code - any suggestions??? > > strComputer = "cn=xp1,ou=Desktops,dc=testdom" > Set objLocator = CreateObject("WbemScripting.SWbemLocator") > Set objCon = objLocator.ConnectServer(".", "root\rsop", null, null, null, > null, 0, null) > Set objProvider = objCon.Get("RsopPlanningModeProvider") > objProvider.RsopCreateSession 0, strComputer, Null, Null, Null, Null, > Null, Null, Null, Null, ns, hr, ei > > Error occurs on the last line. > Any advice appreciated. > > |
| Package Load Failure | .NET General | |||
| RSOP Planning Security problem | VB Script | |||
| 0x80041013 Provider Load Failure on restore point script | Vista performance & maintenance | |||
| Power failure during set-up - Vista won't load | Vista installation & setup | |||
| Stationary Load Failure | Vista mail | |||
