| | BinaryStream.Write ByteArray erroring with Code 800A0BB9, SourceADODB.Stream Hello, I am new to VBScript and am trying to troubleshoot a script. The script is reaching out to a SQLServer database and grabbing some data and trying to drop each record into a file on my local Windows Server 2003 file system. I have been Googling for the solution, but am having no luck. Can someone point to some possible solutions, please? This is the error I am getting: Line: 63 (BinaryStream.Write ByteArray) Char: 5 Error: Arguments are of the wrong type, are out of acceptable range, or are in conflict with one another Code: 800A0BB9 Source: ADODB.Stream option explicit const ADTYPETEXT = 2 const ADOPENKETSET = 1 const ADLOCKOPTIMISTIC = 3 dim oCn dim oRS dim o St set oCn = Wscript.CreateObject("ADODB.Connection") oCn.ConnectionString = "Driver= {SQLServer};Server=<ipaddress>;Database=<dbname>;Uid=<userid>;Pwd=<password>;" oCn.Open set oRs = oCn.execute("EXEC ABC.GetDocumentsByDateRange '10/25/2008', '1/1/2009''") 'wscript.echo(oRs(0)) 'id 'wscript.echo(oRs(1)) ' category 'wscript.echo(oRs(2)) 'type 'wscript.echo(oRs(3)) 'title 'wscript.echo(oRs(4)) 'filename 'wscript.echo(oRs(5)) 'binary 'wscript.echo(oRs(6)) 'date 'wscript.echo(oRs(7)) 'date 'wscript.echo(oRs(8)) 'date 'wscript.echo(oRs(9)) 'short classification 'wscript.echo(oRs(10)) 'long classification while not oRs.eof SaveBinaryData oRs(4), oRs(5), "ABC-" & oRs(1) & "-" & oRs(2) oRs.MoveNext wend oRs.Close oCn.Close Set oRs = Nothing Set oSt = Nothing Set oCn = Nothing wscript.echo("Work Complete") Function SaveBinaryData(Filename,ByteArray,DirName) Const adTypeBinary = 1 Const adSaveCreateOverWrite = 2 dim fso DirName = replace(DirName,"\","") DirName = replace(DirName,"'","") DirName = replace(DirName,"/","") DirName = replace(FileName, "\","") DirName = replace(FileName, "'","") DirName = replace(FileName, "/","") set fso = CreateObject("Scripting.FileSystemObject") if fso.FolderExists("e:\data\" & DirName) = False then fso.CreateFolder("e:\data\" & DirName) end if dim BinaryStream Set BinaryStream = CreateObject("ADODB.Stream") BinaryStream.Type = adTypeBinary BinaryStream.Open BinaryStream.Write ByteArray <== ******this is Line 63, where it's failing BinaryStream.SaveToFile "e:\data\ABC\" & FileName, adSaveCreateOverWrite End Function |
| | Re: BinaryStream.Write ByteArray erroring with Code 800A0BB9, Source ADODB.Stream <thefabulouslb@xxxxxx> wrote in message news:12a8d0e6-8559-43a1-936e-bd7faa2c1661@xxxxxx Quote: > Hello, > > I am new to VBScript and am trying to troubleshoot a script. The > script is reaching out to a SQLServer database and grabbing some data > and trying to drop each record into a file on my local Windows Server > 2003 file system. I have been Googling for the solution, but am > having no luck. Can someone point to some possible solutions, > please? This is the error I am getting: > > Line: 63 (BinaryStream.Write ByteArray) > Char: 5 > Error: Arguments are of the wrong type, are out of acceptable range, > or are in conflict with one another > Code: 800A0BB9 > Source: ADODB.Stream > > option explicit > > const ADTYPETEXT = 2 > const ADOPENKETSET = 1 > const ADLOCKOPTIMISTIC = 3 > > dim oCn > dim oRS > dim o St > > set oCn = Wscript.CreateObject("ADODB.Connection") > oCn.ConnectionString = "Driver= > {SQLServer};Server=<ipaddress>;Database=<dbname>;Uid=<userid>;Pwd=<password>;" > oCn.Open > > set oRs = oCn.execute("EXEC ABC.GetDocumentsByDateRange '10/25/2008', > '1/1/2009''") > 'wscript.echo(oRs(0)) 'id > 'wscript.echo(oRs(1)) ' category > 'wscript.echo(oRs(2)) 'type > 'wscript.echo(oRs(3)) 'title > 'wscript.echo(oRs(4)) 'filename > 'wscript.echo(oRs(5)) 'binary > 'wscript.echo(oRs(6)) 'date > 'wscript.echo(oRs(7)) 'date > 'wscript.echo(oRs(8)) 'date > 'wscript.echo(oRs(9)) 'short classification > 'wscript.echo(oRs(10)) 'long classification > > while not oRs.eof > SaveBinaryData oRs(4), oRs(5), "ABC-" & oRs(1) & "-" & oRs(2) > oRs.MoveNext > wend > > oRs.Close > oCn.Close > Set oRs = Nothing > Set oSt = Nothing > Set oCn = Nothing > wscript.echo("Work Complete") > > Function SaveBinaryData(Filename,ByteArray,DirName) > Const adTypeBinary = 1 > Const adSaveCreateOverWrite = 2 > > dim fso > DirName = replace(DirName,"\","") > DirName = replace(DirName,"'","") > DirName = replace(DirName,"/","") > DirName = replace(FileName, "\","") > DirName = replace(FileName, "'","") > DirName = replace(FileName, "/","") > set fso = CreateObject("Scripting.FileSystemObject") > if fso.FolderExists("e:\data\" & DirName) = False then > fso.CreateFolder("e:\data\" & DirName) > end if > > dim BinaryStream > Set BinaryStream = CreateObject("ADODB.Stream") > > BinaryStream.Type = adTypeBinary > BinaryStream.Open > BinaryStream.Write ByteArray <== ******this is Line 63, > where it's failing > BinaryStream.SaveToFile "e:\data\ABC\" & FileName, > adSaveCreateOverWrite > End Function > > check with UBound that the array is not empty. -- Richard Mueller MVP Directory Services Hilltop Lab - http://www.rlmueller.net -- |
| | Re: BinaryStream.Write ByteArray erroring with Code 800A0BB9, SourceADODB.Stream On Apr 8, 9:56*am, "Richard Mueller [MVP]" <rlmueller- nos...@xxxxxx> wrote: Quote: > <thefabulou...@xxxxxx> wrote in message > > news:12a8d0e6-8559-43a1-936e-bd7faa2c1661@xxxxxx > > > > > Quote: > > Hello, Quote: > > I am new to VBScript and am trying to troubleshoot a script. *The > > script is reaching out to a SQLServer database and grabbing some data > > and trying to drop each record into a file on my local Windows Server > > 2003 file system. *I have been Googling for the solution, but am > > having no luck. *Can someone point to some possible solutions, > > please? *This is the error I am getting: Quote: > > Line: *63 * * * * * *(BinaryStream.Write ByteArray) > > Char: *5 > > Error: *Arguments are of the wrong type, are out of acceptable range, > > or are in conflict with one another > > Code: *800A0BB9 > > Source: *ADODB.Stream Quote: > > option explicit Quote: > > const ADTYPETEXT = 2 > > const ADOPENKETSET = 1 > > const ADLOCKOPTIMISTIC = 3 Quote: > > dim oCn > > dim oRS > > dim o St Quote: > > set oCn = Wscript.CreateObject("ADODB.Connection") > > oCn.ConnectionString = "Driver= > > {SQLServer};Server=<ipaddress>;Database=<dbname>;Uid=<userid>;Pwd=<password*>;" > > oCn.Open Quote: > > set oRs = oCn.execute("EXEC ABC.GetDocumentsByDateRange '10/25/2008', > > '1/1/2009''") > > 'wscript.echo(oRs(0)) * 'id > > 'wscript.echo(oRs(1)) * ' category > > 'wscript.echo(oRs(2)) * 'type > > 'wscript.echo(oRs(3)) * 'title > > 'wscript.echo(oRs(4)) * 'filename > > 'wscript.echo(oRs(5)) * 'binary > > 'wscript.echo(oRs(6)) * 'date > > 'wscript.echo(oRs(7)) * 'date > > 'wscript.echo(oRs(8)) * 'date > > 'wscript.echo(oRs(9)) * 'short classification > > 'wscript.echo(oRs(10)) *'long classification Quote: > > while not oRs.eof > > * SaveBinaryData *oRs(4), oRs(5), "ABC-" & oRs(1) & "-" & oRs(2) > > * oRs.MoveNext > > wend Quote: > > oRs.Close > > oCn.Close > > Set oRs = Nothing > > Set oSt = Nothing > > Set oCn = Nothing > > wscript.echo("Work Complete") Quote: > > Function SaveBinaryData(Filename,ByteArray,DirName) > > * Const adTypeBinary = 1 > > * Const adSaveCreateOverWrite = 2 Quote: > > * dim fso > > * DirName = replace(DirName,"\","") > > * DirName = replace(DirName,"'","") > > * DirName = replace(DirName,"/","") > > * DirName = replace(FileName, "\","") > > * DirName = replace(FileName, "'","") > > * DirName = replace(FileName, "/","") > > * set fso = CreateObject("Scripting.FileSystemObject") > > * if fso.FolderExists("e:\data\" & DirName) = False then > > * * *fso.CreateFolder("e:\data\" & DirName) > > * end if Quote: > > * * *dim BinaryStream > > * * *Set BinaryStream = CreateObject("ADODB.Stream") Quote: > > * * *BinaryStream.Type = adTypeBinary > > * * *BinaryStream.Open > > * * *BinaryStream.Write ByteArray * * <== *******this is Line 63, > > where it's failing > > * * *BinaryStream.SaveToFile "e:\data\ABC\" & FileName, > > adSaveCreateOverWrite > > End Function > I would check to make sure that TypeName(oRs(5)) = "Byte()", and if so, > check with UBound that the array is not empty. > > -- > Richard Mueller > MVP Directory Services > Hilltop Lab -http://www.rlmueller.net > --- Hide quoted text - > > - Show quoted text - I have never looked at VBScript before today. How do I check to make sure that TypeName(oRs(5)) = "Byte()"? Could you also explain in more detail about UBound? Are these things I need to look at in SQLServer? Thank you. |
| | Re: BinaryStream.Write ByteArray erroring with Code 800A0BB9, Source ADODB.Stream <thefabulouslb@xxxxxx> wrote in message news:79971d8f-0eb5-4d1d-8cb8-b5d30c52b5eb@xxxxxx On Apr 8, 9:56 am, "Richard Mueller [MVP]" <rlmueller- nos...@xxxxxx> wrote: Quote: > <thefabulou...@xxxxxx> wrote in message > > news:12a8d0e6-8559-43a1-936e-bd7faa2c1661@xxxxxx > > > > > Quote: > > Hello, Quote: > > I am new to VBScript and am trying to troubleshoot a script. The > > script is reaching out to a SQLServer database and grabbing some data > > and trying to drop each record into a file on my local Windows Server > > 2003 file system. I have been Googling for the solution, but am > > having no luck. Can someone point to some possible solutions, > > please? This is the error I am getting: Quote: > > Line: 63 (BinaryStream.Write ByteArray) > > Char: 5 > > Error: Arguments are of the wrong type, are out of acceptable range, > > or are in conflict with one another > > Code: 800A0BB9 > > Source: ADODB.Stream Quote: > > option explicit Quote: > > const ADTYPETEXT = 2 > > const ADOPENKETSET = 1 > > const ADLOCKOPTIMISTIC = 3 Quote: > > dim oCn > > dim oRS > > dim o St Quote: > > set oCn = Wscript.CreateObject("ADODB.Connection") > > oCn.ConnectionString = "Driver= > > {SQLServer};Server=<ipaddress>;Database=<dbname>;Uid=<userid>;Pwd=<password*>;" > > oCn.Open Quote: > > set oRs = oCn.execute("EXEC ABC.GetDocumentsByDateRange '10/25/2008', > > '1/1/2009''") > > 'wscript.echo(oRs(0)) 'id > > 'wscript.echo(oRs(1)) ' category > > 'wscript.echo(oRs(2)) 'type > > 'wscript.echo(oRs(3)) 'title > > 'wscript.echo(oRs(4)) 'filename > > 'wscript.echo(oRs(5)) 'binary > > 'wscript.echo(oRs(6)) 'date > > 'wscript.echo(oRs(7)) 'date > > 'wscript.echo(oRs(8)) 'date > > 'wscript.echo(oRs(9)) 'short classification > > 'wscript.echo(oRs(10)) 'long classification Quote: > > while not oRs.eof > > SaveBinaryData oRs(4), oRs(5), "ABC-" & oRs(1) & "-" & oRs(2) > > oRs.MoveNext > > wend Quote: > > oRs.Close > > oCn.Close > > Set oRs = Nothing > > Set oSt = Nothing > > Set oCn = Nothing > > wscript.echo("Work Complete") Quote: > > Function SaveBinaryData(Filename,ByteArray,DirName) > > Const adTypeBinary = 1 > > Const adSaveCreateOverWrite = 2 Quote: > > dim fso > > DirName = replace(DirName,"\","") > > DirName = replace(DirName,"'","") > > DirName = replace(DirName,"/","") > > DirName = replace(FileName, "\","") > > DirName = replace(FileName, "'","") > > DirName = replace(FileName, "/","") > > set fso = CreateObject("Scripting.FileSystemObject") > > if fso.FolderExists("e:\data\" & DirName) = False then > > fso.CreateFolder("e:\data\" & DirName) > > end if Quote: > > dim BinaryStream > > Set BinaryStream = CreateObject("ADODB.Stream") Quote: > > BinaryStream.Type = adTypeBinary > > BinaryStream.Open > > BinaryStream.Write ByteArray <== ******this is Line 63, > > where it's failing > > BinaryStream.SaveToFile "e:\data\ABC\" & FileName, > > adSaveCreateOverWrite > > End Function > I would check to make sure that TypeName(oRs(5)) = "Byte()", and if so, > check with UBound that the array is not empty. > > -- > Richard Mueller > MVP Directory Services > Hilltop Lab -http://www.rlmueller.net > --- Hide quoted text - > > - Show quoted text - I have never looked at VBScript before today. How do I check to make sure that TypeName(oRs(5)) = "Byte()"? Could you also explain in more detail about UBound? Are these things I need to look at in SQLServer? Thank you. ----------- Your error message indicates an argument of the wrong type. The BinaryStream.Write method expects a byte array, since you specified adTypeBinary. I was suggesting that you make sure that oRs(5), or ByteArray in the function, is datatype Byte(), which is a byte array. I think it can also be Variant(), which is a variant array, as long as each element is an integer in the proper range (say between 0 and 255). In any case, the VBScript function TypeName returns the datatype of any variable reference. In addition, if the variable refers to an array, the UBound function returns the upper bound of the array. For example: ======== set oCn = Wscript.CreateObject("ADODB.Connection") oCn.ConnectionString = "Driver={SQLServer};Server=<ipaddress>;Database=<dbname>;Uid=<userid>;Pwd=<password>;" oCn.Open set oRs = oCn.execute("EXEC ABC.GetDocumentsByDateRange '10/25/2008', '1/1/2009''") while not oRs.eof strType = TypeName(oRs(5).Value) If (strType = "Byte()") Or (strType = "Variant()") Then Wscript.Echo "ID: " & oRs(0).Value & ";" & strType _ & " (" & UBound(oRs(5).Value) & ")" Else Wscript.Echo "ID: " & oRs(0).Value & ";" & strType End If oRs.MoveNext wend ======= The above loops through the rescordset and checks the datatype of the "binary" on every row. -- Richard Mueller MVP Directory Services Hilltop Lab - http://www.rlmueller.net -- |
| | Re: BinaryStream.Write ByteArray erroring with Code 800A0BB9, SourceADODB.Stream On Apr 8, 6:12*pm, "Richard Mueller [MVP]" <rlmueller- nos...@xxxxxx> wrote: Quote: > <thefabulou...@xxxxxx> wrote in message > > news:79971d8f-0eb5-4d1d-8cb8-b5d30c52b5eb@xxxxxx > On Apr 8, 9:56 am, "Richard Mueller [MVP]" <rlmueller- > > > > > > nos...@xxxxxx> wrote: Quote: > > <thefabulou...@xxxxxx> wrote in message Quote: > >news:12a8d0e6-8559-43a1-936e-bd7faa2c1661@xxxxxx Quote: Quote: > > > Hello, Quote: Quote: > > > I am new to VBScript and am trying to troubleshoot a script. The > > > script is reaching out to a SQLServer database and grabbing some data > > > and trying to drop each record into a file on my local Windows Server > > > 2003 file system. I have been Googling for the solution, but am > > > having no luck. Can someone point to some possible solutions, > > > please? This is the error I am getting: Quote: Quote: > > > Line: 63 (BinaryStream.Write ByteArray) > > > Char: 5 > > > Error: Arguments are of the wrong type, are out of acceptable range, > > > or are in conflict with one another > > > Code: 800A0BB9 > > > Source: ADODB.Stream Quote: Quote: > > > option explicit Quote: Quote: > > > const ADTYPETEXT = 2 > > > const ADOPENKETSET = 1 > > > const ADLOCKOPTIMISTIC = 3 Quote: Quote: > > > dim oCn > > > dim oRS > > > dim o St Quote: Quote: > > > set oCn = Wscript.CreateObject("ADODB.Connection") > > > oCn.ConnectionString = "Driver= > > > {SQLServer};Server=<ipaddress>;Database=<dbname>;Uid=<userid>;Pwd=<password**>;" > > > oCn.Open Quote: Quote: > > > set oRs = oCn.execute("EXEC ABC.GetDocumentsByDateRange '10/25/2008', > > > '1/1/2009''") > > > 'wscript.echo(oRs(0)) 'id > > > 'wscript.echo(oRs(1)) ' category > > > 'wscript.echo(oRs(2)) 'type > > > 'wscript.echo(oRs(3)) 'title > > > 'wscript.echo(oRs(4)) 'filename > > > 'wscript.echo(oRs(5)) 'binary > > > 'wscript.echo(oRs(6)) 'date > > > 'wscript.echo(oRs(7)) 'date > > > 'wscript.echo(oRs(8)) 'date > > > 'wscript.echo(oRs(9)) 'short classification > > > 'wscript.echo(oRs(10)) 'long classification Quote: Quote: > > > while not oRs.eof > > > SaveBinaryData oRs(4), oRs(5), "ABC-" & oRs(1) & "-" & oRs(2) > > > oRs.MoveNext > > > wend Quote: Quote: > > > oRs.Close > > > oCn.Close > > > Set oRs = Nothing > > > Set oSt = Nothing > > > Set oCn = Nothing > > > wscript.echo("Work Complete") Quote: Quote: > > > Function SaveBinaryData(Filename,ByteArray,DirName) > > > Const adTypeBinary = 1 > > > Const adSaveCreateOverWrite = 2 Quote: Quote: > > > dim fso > > > DirName = replace(DirName,"\","") > > > DirName = replace(DirName,"'","") > > > DirName = replace(DirName,"/","") > > > DirName = replace(FileName, "\","") > > > DirName = replace(FileName, "'","") > > > DirName = replace(FileName, "/","") > > > set fso = CreateObject("Scripting.FileSystemObject") > > > if fso.FolderExists("e:\data\" & DirName) = False then > > > fso.CreateFolder("e:\data\" & DirName) > > > end if Quote: Quote: > > > dim BinaryStream > > > Set BinaryStream = CreateObject("ADODB.Stream") Quote: Quote: > > > BinaryStream.Type = adTypeBinary > > > BinaryStream.Open > > > BinaryStream.Write ByteArray <== ******this is Line 63, > > > where it's failing > > > BinaryStream.SaveToFile "e:\data\ABC\" & FileName, > > > adSaveCreateOverWrite > > > End Function Quote: > > I would check to make sure that TypeName(oRs(5)) = "Byte()", and if so, > > check with UBound that the array is not empty. Quote: > > -- > > Richard Mueller > > MVP Directory Services > > Hilltop Lab -http://www.rlmueller.net > > --- Hide quoted text - Quote: > > - Show quoted text - > Hi Richard, > > I have never looked at VBScript before today. *How do I check to make > sure that TypeName(oRs(5)) = "Byte()"? *Could you also explain in more > detail about UBound? *Are these things I need to look at in SQLServer? > > Thank you. > > ----------- > > Your error message indicates an argument of the wrong type. The > BinaryStream.Write method expects a byte array, since you specified > adTypeBinary. I was suggesting that you make sure that oRs(5), or ByteArray > in the function, is datatype Byte(), which is a byte array. I think it can > also be Variant(), which is a variant array, as long as each element is an > integer in the proper range (say between 0 and 255). In any case, the > VBScript function TypeName returns the datatype of any variable reference.. > In addition, if the variable refers to an array, the UBound function returns > the upper bound of the array. For example: > ======== > set oCn = Wscript.CreateObject("ADODB.Connection") > oCn.ConnectionString = > "Driver={SQLServer};Server=<ipaddress>;Database=<dbname>;Uid=<userid>;Pwd=<*password>;" > oCn.Open > > set oRs = oCn.execute("EXEC ABC.GetDocumentsByDateRange '10/25/2008', > '1/1/2009''") > > while not oRs.eof > * * strType = TypeName(oRs(5).Value) > * * If (strType = "Byte()") Or (strType = "Variant()") Then > * * * * Wscript.Echo "ID: " & oRs(0).Value & ";" & strType _ > * * * * * * & " (" & UBound(oRs(5).Value) & ")" > * * Else > * * * * Wscript.Echo "ID: " & oRs(0).Value & ";" & strType > * * End If > * * oRs.MoveNext > wend > ======= > The above loops through the rescordset and checks the datatype of the > "binary" on every row. > > -- > Richard Mueller > MVP Directory Services > Hilltop Lab -http://www.rlmueller.net > --- Hide quoted text - > > - Show quoted text - Thank you for explaining in more detail what you were asking me to try. I made the changes to the script using your code, and the result I am getting is a pop-up box that loops through the recordset and displays (example): ID: 27654; Date This leads me to believe that oRs(5) is not a "Byte()", but rather a Date datatype. I have been executing this script weekly for five months straight and never had any problems with it until a few weeks ago. The first thing I did was ask the owners of the SQLServer database if anything on their end had changed that would affect my script, and they said NO. I am going to go check with them again now to verify the columns and order that these columns are being returned to me in my record set. Something must have changed on their end, right??!! Laura |
| | #6 (permalink) |
| | Re: BinaryStream.Write ByteArray erroring with Code 800A0BB9, Source ADODB.Stream <thefabulouslb@xxxxxx> wrote in message news:60c334d9-fcb7-4efa-b754-9b6de5222c71@xxxxxx On Apr 8, 6:12 pm, "Richard Mueller [MVP]" <rlmueller- <<.. Snip Hi again Richard, Thank you for explaining in more detail what you were asking me to try. I made the changes to the script using your code, and the result I am getting is a pop-up box that loops through the recordset and displays (example): ID: 27654; Date This leads me to believe that oRs(5) is not a "Byte()", but rather a Date datatype. I have been executing this script weekly for five months straight and never had any problems with it until a few weeks ago. The first thing I did was ask the owners of the SQLServer database if anything on their end had changed that would affect my script, and they said NO. I am going to go check with them again now to verify the columns and order that these columns are being returned to me in my record set. Something must have changed on their end, right??!! Laura --------- Yes, something seems to have changed. If the field is datatype Date, that would account for your error. I assume GetDocumentsByDateRange is a stored procedure. Possibly that has been recently modified. For example, if a return value was added or deleted from the recordset, the binary value may no longer be the sixth value (the first is oRs(0)). It might be oRs(4) or oRs(6). Simply changing the order of the values returned by GetDocumentsByDateRange would cause this. Or a field in the database table could have been modified so the datatype is different. You are retrieving values from the recordset by index number. For example, oRs(5) refers to the sixth column (field) in the recordset. I generally refer to fields by name, using syntax similar to oRs.Fields("FieldName").Value. This way the order of the fields doesn't matter. The name of the field is less likely to change, plus it helps indicate what the value is. Someone could have modified the stored procedure to change the order of the values returned, or added a value, thinking this was a minor change that would not affect anyone. As long as nothing else changed, your program would still work if you referred to fields by name. You would need to be told the field names, or be able to view the stored procedure. -- Richard Mueller MVP Directory Services Hilltop Lab - http://www.rlmueller.net -- |
| | #7 (permalink) |
| | Re: BinaryStream.Write ByteArray erroring with Code 800A0BB9, SourceADODB.Stream On Apr 8, 6:12*pm, "Richard Mueller [MVP]" <rlmueller- nos...@xxxxxx> wrote: Quote: > <thefabulou...@xxxxxx> wrote in message > > news:79971d8f-0eb5-4d1d-8cb8-b5d30c52b5eb@xxxxxx > On Apr 8, 9:56 am, "Richard Mueller [MVP]" <rlmueller- > > > > > > nos...@xxxxxx> wrote: Quote: > > <thefabulou...@xxxxxx> wrote in message Quote: > >news:12a8d0e6-8559-43a1-936e-bd7faa2c1661@xxxxxx Quote: Quote: > > > Hello, Quote: Quote: > > > I am new to VBScript and am trying to troubleshoot a script. The > > > script is reaching out to a SQLServer database and grabbing some data > > > and trying to drop each record into a file on my local Windows Server > > > 2003 file system. I have been Googling for the solution, but am > > > having no luck. Can someone point to some possible solutions, > > > please? This is the error I am getting: Quote: Quote: > > > Line: 63 (BinaryStream.Write ByteArray) > > > Char: 5 > > > Error: Arguments are of the wrong type, are out of acceptable range, > > > or are in conflict with one another > > > Code: 800A0BB9 > > > Source: ADODB.Stream Quote: Quote: > > > option explicit Quote: Quote: > > > const ADTYPETEXT = 2 > > > const ADOPENKETSET = 1 > > > const ADLOCKOPTIMISTIC = 3 Quote: Quote: > > > dim oCn > > > dim oRS > > > dim o St Quote: Quote: > > > set oCn = Wscript.CreateObject("ADODB.Connection") > > > oCn.ConnectionString = "Driver= > > > {SQLServer};Server=<ipaddress>;Database=<dbname>;Uid=<userid>;Pwd=<password**>;" > > > oCn.Open Quote: Quote: > > > set oRs = oCn.execute("EXEC ABC.GetDocumentsByDateRange '10/25/2008', > > > '1/1/2009''") > > > 'wscript.echo(oRs(0)) 'id > > > 'wscript.echo(oRs(1)) ' category > > > 'wscript.echo(oRs(2)) 'type > > > 'wscript.echo(oRs(3)) 'title > > > 'wscript.echo(oRs(4)) 'filename > > > 'wscript.echo(oRs(5)) 'binary > > > 'wscript.echo(oRs(6)) 'date > > > 'wscript.echo(oRs(7)) 'date > > > 'wscript.echo(oRs(8)) 'date > > > 'wscript.echo(oRs(9)) 'short classification > > > 'wscript.echo(oRs(10)) 'long classification Quote: Quote: > > > while not oRs.eof > > > SaveBinaryData oRs(4), oRs(5), "ABC-" & oRs(1) & "-" & oRs(2) > > > oRs.MoveNext > > > wend Quote: Quote: > > > oRs.Close > > > oCn.Close > > > Set oRs = Nothing > > > Set oSt = Nothing > > > Set oCn = Nothing > > > wscript.echo("Work Complete") Quote: Quote: > > > Function SaveBinaryData(Filename,ByteArray,DirName) > > > Const adTypeBinary = 1 > > > Const adSaveCreateOverWrite = 2 Quote: Quote: > > > dim fso > > > DirName = replace(DirName,"\","") > > > DirName = replace(DirName,"'","") > > > DirName = replace(DirName,"/","") > > > DirName = replace(FileName, "\","") > > > DirName = replace(FileName, "'","") > > > DirName = replace(FileName, "/","") > > > set fso = CreateObject("Scripting.FileSystemObject") > > > if fso.FolderExists("e:\data\" & DirName) = False then > > > fso.CreateFolder("e:\data\" & DirName) > > > end if Quote: Quote: > > > dim BinaryStream > > > Set BinaryStream = CreateObject("ADODB.Stream") Quote: Quote: > > > BinaryStream.Type = adTypeBinary > > > BinaryStream.Open > > > BinaryStream.Write ByteArray <== ******this is Line 63, > > > where it's failing > > > BinaryStream.SaveToFile "e:\data\ABC\" & FileName, > > > adSaveCreateOverWrite > > > End Function Quote: > > I would check to make sure that TypeName(oRs(5)) = "Byte()", and if so, > > check with UBound that the array is not empty. Quote: > > -- > > Richard Mueller > > MVP Directory Services > > Hilltop Lab -http://www.rlmueller.net > > --- Hide quoted text - Quote: > > - Show quoted text - > Hi Richard, > > I have never looked at VBScript before today. *How do I check to make > sure that TypeName(oRs(5)) = "Byte()"? *Could you also explain in more > detail about UBound? *Are these things I need to look at in SQLServer? > > Thank you. > > ----------- > > Your error message indicates an argument of the wrong type. The > BinaryStream.Write method expects a byte array, since you specified > adTypeBinary. I was suggesting that you make sure that oRs(5), or ByteArray > in the function, is datatype Byte(), which is a byte array. I think it can > also be Variant(), which is a variant array, as long as each element is an > integer in the proper range (say between 0 and 255). In any case, the > VBScript function TypeName returns the datatype of any variable reference.. > In addition, if the variable refers to an array, the UBound function returns > the upper bound of the array. For example: > ======== > set oCn = Wscript.CreateObject("ADODB.Connection") > oCn.ConnectionString = > "Driver={SQLServer};Server=<ipaddress>;Database=<dbname>;Uid=<userid>;Pwd=<*password>;" > oCn.Open > > set oRs = oCn.execute("EXEC ABC.GetDocumentsByDateRange '10/25/2008', > '1/1/2009''") > > while not oRs.eof > * * strType = TypeName(oRs(5).Value) > * * If (strType = "Byte()") Or (strType = "Variant()") Then > * * * * Wscript.Echo "ID: " & oRs(0).Value & ";" & strType _ > * * * * * * & " (" & UBound(oRs(5).Value) & ")" > * * Else > * * * * Wscript.Echo "ID: " & oRs(0).Value & ";" & strType > * * End If > * * oRs.MoveNext > wend > ======= > The above loops through the rescordset and checks the datatype of the > "binary" on every row. > > -- > Richard Mueller > MVP Directory Services > Hilltop Lab -http://www.rlmueller.net > --- Hide quoted text - > > - Show quoted text - their Binary column. I cleaned up my script a little bit, referencing the columns by their actual names. The script started to run fine, pulled about 3,000+ records (of maybe 100,000 records), dropping them into my local folder, "e:\data\ABC\", as expected, but then crashed again with the same error I was originally getting (now on Line 51). Any ideas what might now be the problem? Error: Line: 51 (BinaryStream.Write ByteArray) Char: 5 Error: Arguments are of the wrong type, are out of acceptable range, or are in conflict with one another Code: 800A0BB9 Source: ADODB.Stream New code: option explicit const ADTYPETEXT = 2 const ADOPENKETSET = 1 const ADLOCKOPTIMISTIC = 3 dim oCn dim oRS dim o St set oCn = Wscript.CreateObject("ADODB.Connection") oCn.ConnectionString = "Driver= {SQLServer};Server=<ipaddress>;Database=<dbname>;Uid=<userid>;Pwd=<password* Quote: >;" set oRs = oCn.execute("EXEC ABC.GetDocumentsByDateRange '10/25/2008', '1/1/2009''") 'wscript.echo(oRs(0)) 'ID (BIGINT) 'wscript.echo(oRs(1)) 'Document_Category (NVARCHAR(50)) 'wscript.echo(oRs(2)) 'Document_Type (NVARCHAR(50)) 'wscript.echo(oRs(3)) 'Document_Name (NVARCHAR(100)) 'wscript.echo(oRs(4)) 'Document_FileName (NVARCHAR(100)) 'wscript.echo(oRs(5)) 'Binary_Content (IMAGE) 'wscript.echo(oRs(6)) 'Document_DateOfInformation (DATETIME) 'wscript.echo(oRs(7)) 'Document_DateUploaded (DATETIME) 'wscript.echo(oRs(8)) 'Document_DateLastUpdated (DATETIME) 'wscript.echo(oRs(9)) 'Classification_Short (NVARCHAR(50)) 'wscript.echo(oRs(10)) 'Classification_Long (NVARCHAR(50)) while not oRs.eof SaveBinaryData oRs.Fields("Document_FileName").Value, oRs.Fields ("Binary_Content").Value oRs.MoveNext wend oRs.Close oCn.Close Set oRs = Nothing Set oSt = Nothing Set oCn = Nothing wscript.echo("Work Complete") Function SaveBinaryData(Filename,ByteArray,DirName) Const adTypeBinary = 1 Const adSaveCreateOverWrite = 2 dim BinaryStream Set BinaryStream = CreateObject("ADODB.Stream") BinaryStream.Type = adTypeBinary BinaryStream.Open BinaryStream.Write ByteArray BinaryStream.SaveToFile "e:\data\ABC\" & FileName, adSaveCreateOverWrite End Function |
| | #8 (permalink) |
| | Re: BinaryStream.Write ByteArray erroring with Code 800A0BB9, SourceADODB.Stream On Apr 9, 2:50*pm, "Richard Mueller [MVP]" <rlmueller- nos...@xxxxxx> wrote: Quote: > <thefabulou...@xxxxxx> wrote in message > > news:60c334d9-fcb7-4efa-b754-9b6de5222c71@xxxxxx > On Apr 8, 6:12 pm, "Richard Mueller [MVP]" <rlmueller- > > <<.. Snip > > Hi again Richard, > > Thank you for explaining in more detail what you were asking me to > try. *I made the changes to the script using your code, and the result > I am getting is a pop-up box that loops through the recordset and > displays (example): *ID: 27654; Date > > This leads me to believe that oRs(5) is not a "Byte()", but rather a > Date datatype. *I have been executing this script weekly for five > months straight and never had any problems with it until a few weeks > ago. *The first thing I did was ask the owners of the SQLServer > database if anything on their end had changed that would affect my > script, and they said NO. *I am going to go check with them again now > to verify the columns and order that these columns are being returned > to me in my record set. *Something must have changed on their end, > right??!! > > Laura > --------- > > Yes, something seems to have changed. If the field is datatype Date, that > would account for your error. I assume GetDocumentsByDateRange is a stored > procedure. Possibly that has been recently modified. For example, if a > return value was added or deleted from the recordset, the binary value may > no longer be the sixth value (the first is oRs(0)). It might be oRs(4) or > oRs(6). Simply changing the order of the values returned by > GetDocumentsByDateRange would cause this. Or a field in the database table > could have been modified so the datatype is different. > > You are retrieving values from the recordset by index number. For example, > oRs(5) refers to the sixth column (field) in the recordset. I generally > refer to fields by name, using syntax similar to > oRs.Fields("FieldName").Value. This way the order of the fields doesn't > matter. The name of the field is less likely to change, plus it helps > indicate what the value is. Someone could have modified the stored procedure > to change the order of the values returned, or added a value, thinking this > was a minor change that would not affect anyone. As long as nothing else > changed, your program would still work if you referred to fields by name. > You would need to be told the field names, or be able to view the stored > procedure. > > -- > Richard Mueller > MVP Directory Services > Hilltop Lab -http://www.rlmueller.net > -- |
| | #9 (permalink) |
| | Re: BinaryStream.Write ByteArray erroring with Code 800A0BB9, SourceADODB.Stream On Apr 9, 4:43*pm, thefabulou...@xxxxxx wrote: Quote: > On Apr 9, 2:50*pm, "Richard Mueller [MVP]" <rlmueller- > > > > nos...@xxxxxx> wrote: Quote: > > <thefabulou...@xxxxxx> wrote in message Quote: > >news:60c334d9-fcb7-4efa-b754-9b6de5222c71@xxxxxx > > On Apr 8, 6:12 pm, "Richard Mueller [MVP]" <rlmueller- Quote: > > <<.. Snip Quote: > > Hi again Richard, Quote: > > Thank you for explaining in more detail what you were asking me to > > try. *I made the changes to the script using your code, and the result > > I am getting is a pop-up box that loops through the recordset and > > displays (example): *ID: 27654; Date Quote: > > This leads me to believe that oRs(5) is not a "Byte()", but rather a > > Date datatype. *I have been executing this script weekly for five > > months straight and never had any problems with it until a few weeks > > ago. *The first thing I did was ask the owners of the SQLServer > > database if anything on their end had changed that would affect my > > script, and they said NO. *I am going to go check with them again now > > to verify the columns and order that these columns are being returned > > to me in my record set. *Something must have changed on their end, > > right??!! Quote: > > Laura > > --------- Quote: > > Yes, something seems to have changed. If the field is datatype Date, that > > would account for your error. I assume GetDocumentsByDateRange is a stored > > procedure. Possibly that has been recently modified. For example, if a > > return value was added or deleted from the recordset, the binary value may > > no longer be the sixth value (the first is oRs(0)). It might be oRs(4) or > > oRs(6). Simply changing the order of the values returned by > > GetDocumentsByDateRange would cause this. Or a field in the database table > > could have been modified so the datatype is different. Quote: > > You are retrieving values from the recordset by index number. For example, > > oRs(5) refers to the sixth column (field) in the recordset. I generally > > refer to fields by name, using syntax similar to > > oRs.Fields("FieldName").Value. This way the order of the fields doesn't > > matter. The name of the field is less likely to change, plus it helps > > indicate what the value is. Someone could have modified the stored procedure > > to change the order of the values returned, or added a value, thinking this > > was a minor change that would not affect anyone. As long as nothing else > > changed, your program would still work if you referred to fields by name. > > You would need to be told the field names, or be able to view the stored > > procedure. Quote: > > -- > > Richard Mueller > > MVP Directory Services > > Hilltop Lab -http://www.rlmueller.net > > --- Hide quoted text - > - Show quoted text - folks deleted their Binary column, but then re-added it when I went to talk to them. So the columns are back in place like they were to begin with before this problem started appearing. |
| | #10 (permalink) |
| | Re: BinaryStream.Write ByteArray erroring with Code 800A0BB9, Source ADODB.Stream <thefabulouslb@xxxxxx> wrote in message news:1c869c4c-c2ac-451c-976f-d4bc17e7f899@xxxxxx Quote: Quote: >>... Snip. their Binary column. I cleaned up my script a little bit, referencing the columns by their actual names. The script started to run fine, pulled about 3,000+ records (of maybe 100,000 records), dropping them into my local folder, "e:\data\ABC\", as expected, but then crashed again with the same error I was originally getting (now on Line 51). Any ideas what might now be the problem? Error: Line: 51 (BinaryStream.Write ByteArray) Char: 5 Error: Arguments are of the wrong type, are out of acceptable range, or are in conflict with one another Code: 800A0BB9 Source: ADODB.Stream New code: option explicit const ADTYPETEXT = 2 const ADOPENKETSET = 1 const ADLOCKOPTIMISTIC = 3 dim oCn dim oRS dim o St set oCn = Wscript.CreateObject("ADODB.Connection") oCn.ConnectionString = "Driver= {SQLServer};Server=<ipaddress>;Database=<dbname>;Uid=<userid>;Pwd=<password* Quote: >;" set oRs = oCn.execute("EXEC ABC.GetDocumentsByDateRange '10/25/2008', '1/1/2009''") 'wscript.echo(oRs(0)) 'ID (BIGINT) 'wscript.echo(oRs(1)) 'Document_Category (NVARCHAR(50)) 'wscript.echo(oRs(2)) 'Document_Type (NVARCHAR(50)) 'wscript.echo(oRs(3)) 'Document_Name (NVARCHAR(100)) 'wscript.echo(oRs(4)) 'Document_FileName (NVARCHAR(100)) 'wscript.echo(oRs(5)) 'Binary_Content (IMAGE) 'wscript.echo(oRs(6)) 'Document_DateOfInformation (DATETIME) 'wscript.echo(oRs(7)) 'Document_DateUploaded (DATETIME) 'wscript.echo(oRs(8)) 'Document_DateLastUpdated (DATETIME) 'wscript.echo(oRs(9)) 'Classification_Short (NVARCHAR(50)) 'wscript.echo(oRs(10)) 'Classification_Long (NVARCHAR(50)) while not oRs.eof SaveBinaryData oRs.Fields("Document_FileName").Value, oRs.Fields ("Binary_Content").Value oRs.MoveNext wend oRs.Close oCn.Close Set oRs = Nothing Set oSt = Nothing Set oCn = Nothing wscript.echo("Work Complete") Function SaveBinaryData(Filename,ByteArray,DirName) Const adTypeBinary = 1 Const adSaveCreateOverWrite = 2 dim BinaryStream Set BinaryStream = CreateObject("ADODB.Stream") BinaryStream.Type = adTypeBinary BinaryStream.Open BinaryStream.Write ByteArray BinaryStream.SaveToFile "e:\data\ABC\" & FileName, adSaveCreateOverWrite End Function ------------ Now we know the datatype in the field "Binary_Content" is correct and the function works to write the values, at least most of the time. Instead the same error is raised when we get to a particular row of the recordset. The best theory (I can think of) is that the problem row has no value assigned for that field. We should be able to check if the value is Null. If the value is Null, we can skip the Write and SaveToFile methods, or even write some text instead. For example, the following only writes to the file if there is a value: Function SaveBinaryData(Filename,ByteArray,DirName) Const adTypeBinary = 1 Const adSaveCreateOverWrite = 2 dim BinaryStream If (IsNull(ByteArray) = False) Then Set BinaryStream = CreateObject("ADODB.Stream") BinaryStream.Type = adTypeBinary BinaryStream.Open BinaryStream.Write ByteArray BinaryStream.SaveToFile "e:\data\ABC\" & FileName, adSaveCreateOverWrite End If End Function -- Richard Mueller MVP Directory Services Hilltop Lab - http://www.rlmueller.net -- |
| how to get powershell to write to event log or write a log file? | PowerShell | |||
| Anyone know how to write code for 1 username, multiple possiblepasswords? | VB Script | |||
| Clients erroring out when contacting WSUS Server -- they just happen to be syprepped VHDs. | Virtual Server | |||
| The disk is write-protected. Remove the write-protection or... | Vista General | |||
| Non-erroring way to test for alias existence? | PowerShell | |||
