| | Help and feedback with script searching the registry with regular expression Hi Hope someone might help me out, since I'm stuck. I have to search the registry of several computers to find if there is a "PendingFileenameOperation" waiting. After some try and error, I've come up with this solution where I read the registry and add all entries' to an array, and then add each arrayitem to a string. I then intend to search the string for a certain path. If the count is above 0 I have a PendingFileRenameOperation" that requires a reboot. My problem is as follows: 1) Is this the best way to solve this problem 2) I cant get my regular expression to work. The code I've come up with is as follows: Dim objShell dim strPending, strSessionManager , strAllText Dim arrFiles ''array containing files that are being renamed Set objRegEx = CreateObject("VBScript.Regexp") objRegEx.Global = True objRegEx.Pattern = "C:\Norman" ''regular expression finding all entries containing "c:\norman\" strPending = "PendingFileRenameOperations" ''The regkey we're going to read strSessionManager="HKLM\System\CurrentControlSet\Control\Session Manager\" ''the registry Set objShell = CreateObject("WScript.shell") arrFiles=objShell.Regread(strSessionManager & strPending) 'put all entries in registry into the array for each StrFile in arrFiles strAllText= strAllText & " " & strFile ''add all entries into one long string with spaces next set colMatches = objRegEx.Execute(strAllText) if colMatches.count > 0 then ''Do something if there are keys in the given directory that is pending a filerename operation. end if Any feedback would be greatly appreciated. /Regards L. |
| Regular Expression help C# | .NET General | |||
| Regular Expression for ../ | .NET General | |||
| Help with a regular expression | VB Script | |||
| regular expression help | VB Script | |||
| Regular expression notes | PowerShell | |||
