Vista - Weird problem with VBscript.
Old 04-11-2009   #1 (permalink)
Alexis Faren
I have this code that I am using after posting a form:
for each key in request.Form
response.write "Choices for: " & session("UseID") & " Value: " & request.Form(Key) & " left " & UCase(left(Key,3)) & "<BR>" (I have this for debugging)
If UCase(left(Key,3)) = "GRP" Then
intCount = intCount + 1
(I do other 'real processing' here, I removed it for brevity)
End if
Next
Essentially it checks to see if the KEY is a radio button group.
This is the output:
Choices for: Robert Value: Andy left GRP
Choices for: Robert Value: Rhonda left GRP
Choices for: Robert Value: Submit Form! left BTN
Choices for: Robert Value: Harry left GRP
Choices for: Robert Value: 25 left TXT
Choices for: Robert Value: Alexis left GRP
Should not be displaying (OR selecting) BTN or TXT. In tct (as far as I know, the Ucase statement should check for this.
I've checked my form (which hasn't change in months) and just can't find the problem.
I can't see the error, hopefully a younger set of eyes can see it.
Thanks Alexis
Old 04-11-2009   #2 (permalink)
Bob Barrows
Re: Weird problem with VBscript.
> this for debugging)
> End if
> Next
> This is the output:
Why not? You have no code to prevent the data from being written to response
.... All you are doing with the If statement is deciding whether or not to
increment that intCount variable.
You showed the output ... what was the expected output?
A better place for this question might have .inetserver.asp.general
PS. You can remove the name for the submit button to prevent it from being
included in the Request.
Microsoft MVP - ASP/ASP.NET - 2004-2007
Please reply to the newsgroup. This email account is my spam trap so I
don't check it very often. If you must reply off-line, then remove the
"NO SPAM"
Old 04-11-2009   #3 (permalink)
Alexis Faren
Thanks Bob, that's obviously what I missed. I put it where it belongs and
now I get the output I was expecting.
Also, thanks for the tip about the Submit Button.
Alexis
"Bob Barrows" <reb01501@xxxxxx> wrote in message
news:%23wBjfwtuJHA.2248@xxxxxx
>> this for debugging)
>> End if
>> Next
>> This is the output:
> response ... All you are doing with the If statement is deciding whether
> or not to increment that intCount variable.
> "NO SPAM"
Weird - Very weird annoying problem General Discussion
weird problem Vista General
weird problem Vista performance & maintenance
Weird Problem Vista mail
