Vista - Need Help With Script To List and Delete Printers
Old 04-14-2009   #1 (permalink)
Christopher Beard
We are migrating from one print server to another and the printers from the
old print server still exist on the client PCs and I want to delete them.
What I am trying to do is write a script to do the following on the client
PCs:
1. List the user's printers
2. Pipe that list into an array
3. Search the array for printers starting with \\OLDPRINTSERVER
4. Delete those printers
I know how to list printers and delete printers, can someone help with the
rest? Thank you in advance!
Christopher
Old 04-14-2009   #2 (permalink)
Alex K. Angelopoulos
Re: Need Help With Script To List and Delete Printers
Post if you need more, but you actually have something that is _very_ simple
to do using VBScript's Filter function. From the docs, the prototype for it
is this:
Filter(InputStrings, Value[, Include[, Compare]])
where InputStrings is an array; Value is the value you're searching for that
should be contained in those strings; Include is a boolean, true (default)
for returning only items containing the string, and false for only returning
items NOT containing it; and Compare is vbBinaryCompare (or 0, for caseful
comparison) or vbTextCompare (or 1, for case-insensitive comparison).
Here's a demo.
printers = Array("\\OLDPRINTSERVER\ptr1", "\\newprintserver\ptr1", _
"\\oldprintserver\ptr2", "\\oldprintserver\ptr3", _
"\\newprintserver\ptr1")
Oldprinters = Filter(printers, "\\OLDPRINTSERVER\", true, vbTextCompare)
for each oldprinter in oldprinters
WScript.Echo oldprinter
next
Filter has limited use in many circumstances since it does simple
comparison, but it works well for this since the \\<name>\ form anchors a
unique string.
"Christopher Beard" <ChristopherBeard@xxxxxx> wrote in
message news:0CB742E6-1E06-4D4C-9823-2B7373A8B445@xxxxxx
> the
> PCs:
> Christopher
Old 04-14-2009   #3 (permalink)
And out of curiosity, what technique are you using to remove the printers?
> the
> PCs:
> Christopher
Old 04-15-2009   #4 (permalink)
Christopher Beard
I'm going to try to use a basic VBScript printer delete like below. Thanks
for your help! I'll try this and let you know how it goes.
objNetwork.RemovePrinterConnection "printername"
> > the
> > PCs:
> > Christopher
Old 04-16-2009   #5 (permalink)
XP
I wanted to create a script to do the same action as the OP.
I have a script that will query the local computer and delete all network printers on the machine (see below). I don't want to delete all network printers, but instead want to delete all of the printers from \\DC1. How could I rework this script to include the filter above?
strComputer = "."
Set objWMIService = GetObject("winmgmts:\\" & strComputer & "\root\cimv2")
Set colInstalledPrinters = objWMIService.ExecQuery _
("Select * From Win32_Printer Where Network = True")
For Each objPrinter in colInstalledPrinters
objPrinter.Delete_
Next
Old 04-16-2009   #6 (permalink)
Christopher Beard
Aisak,
I'm having a bit of trouble making this work. If I figure it out, I'll let
you know.
Christopher
"Aisak" wrote:
Quote:
> I wanted to write a script using the same method as the OP.
> What would a full script to remove all printers from \\OldServer be
> using objNetwork.RemovePrinterConnection as the deletion method. The
> above example confused me a little on how to create the filter to be
> only printers from \\OldServer and how you would then pipe that into the
> RemovePrinterConnection.
> Aisak
Cannont delete printers - no jobs pending! Vista print fax & scan
Printers Won't Remove/Delete Vista print fax & scan
Adding fax modem to printers list Vista print fax & scan
is there any script to get a list of COM Objects in a computer? PowerShell
list of printers... PowerShell
