| | recursion help request hi, I have a vbscript that I can not get to recurs properly. If the user enters '5' for input, the script should end. For ALL other input: invalid data returns to the inputbox (this works), and valid data should execute the corresponding sub-routines, and then return to the inputbox. I am unable to format this so far to get it to do this. I have tried loops and ended up with mostly endless loops. I have also tried to call (a 2nd call) the sub-procedure for the main menu (mainmenu()) at the end of the script, but it simply stops after the previous sub-routines finish. I have also tried to add the mainmenu() call at the end of each sub-routine for option 1thru4 to no avail, it still stops after each sub-routine. The inputbox and the use of subroutines for the selections 1-4 are required, so I can not re-write this entire thing. Any suggestions? the script: __________________________________________________________ Option Explicit Dim fso, objshl, textfile, title, choice, inputtest, program, exitnow Set fso = CreateObject("Scripting.FileSystemObject") Set objshl = CreateObject("WScript.Shell") textfile = "c:\scriptlog.txt" title = "Main Menu - Current Date: " & Date '************************* 'Main Processing Section * '************************* mainmenu() If choice = "1" Then Logfile() Powerpoint() ElseIf choice = "2" then Logfile() Excel() ElseIf choice = "3" Then Viewlogfile() ElseIf choice = "4" then Deletelogfile() End If '******************************************** 'Main Menu for player input and value testing '******************************************** Sub mainmenu() Do Until inputtest = "valid" choice = (InputBox(("1. Run PowerPoint") & vbCrLf & ("2. Run Excel")_ & vbCrLf & ("3. View Log File") & vbCrLf &_ ("4. Delete Log File") & vbCrLf & ("5. Quit") & vbCrLf &_ vbCrLf & vbTab & vbTab & vbTab & "Choose By Number",title)) If choice = "1" Then inputtest = "valid" program = "PowerPoint" ElseIf choice = "2" then inputtest = "valid" program = "Excel" ElseIf choice = "3" Then inputtest = "valid" ElseIf choice = "4" then inputtest = "valid" ElseIf choice = "5" Then WScript.Quit Else MsgBox("Your selection was not valid") End If Loop End Sub '********************************************** 'Create 'start' logfile text for option 1 and 2 '********************************************** Sub Logfile() Dim log If (fso.FileExists(textfile)) Then Set log = fso.OpenTextFile(textfile,8) log.WriteLine "-- -- -- -- -- -- -- -- -- -- -- --" log.WriteLine ((program) & " started on ") & Date log.WriteLine ((program) & " started at ") & Time log.WriteLine "-- -- -- --" log.close Else Set log = fso.OpenTextFile(textfile, 2, "true") log.WriteLine "-- -- -- -- -- -- -- -- -- -- -- --" log.WriteLine ((program) & " started on ") & Date log.WriteLine ((program) & " started at ") & Time log.WriteLine "-- -- -- --" log.close End If End Sub '************************************** 'Process tasks for option '1' selection '************************************** Sub Powerpoint() Dim log objshl.Run "powerpnt.exe",,True Set log = fso.OpenTextFile(textfile, 8) log.WriteLine "PowerPoint stopped on " & Date log.WriteLine "PowerPoint stopped at " & Time log.WriteLine "-- -- -- -- -- -- -- -- -- -- -- --" log.close() End Sub '************************************** 'Process tasks for option '2' selection '************************************** Sub Excel() Dim log objshl.Run "excel.exe",,True Set log = fso.OpenTextFile(textfile, 8) log.WriteLine "Excel stopped on " & Date log.WriteLine "Excel stopped at " & Time log.WriteLine "-- -- -- -- -- -- -- -- -- -- -- --" log.close() End Sub '************************************** 'Process tasks for option '3' selection '************************************** Sub Viewlogfile() Dim output, log Set log = fso.OpenTextFile(textfile, 1) If (fso.FileExists(textfile)) Then output = log.ReadAll log.Close MsgBox output Else MsgBox("The log file does not exist") End If End Sub '************************************** 'Process tasks for option '4' selection '************************************** Sub Deletelogfile() Dim confirm, file If Not (fso.FileExists(textfile)) Then MsgBox "There is no file to delete", 0 Else confirm = MsgBox("Are you sure you wish to delete this?", 4, "Confirm Selection") If confirm = vbYes Then fso.DeleteFile textfile Set file = fso.OpenTextFile(textfile, 2, "true") file.WriteLine "Logfile created on " & Date & " at " & Time file.close End if End If End Sub |
| | Re: recursion help request "Vgolfmaster" <Vgolfmaster@xxxxxx> wrote in message news:811E3A53-97D6-4C04-AD36-F3C6D1FDC10C@xxxxxx Quote: > > hi, > > I have a vbscript that I can not get to recurs properly. If the user > enters > '5' for input, the script should end. For ALL other input: invalid data > returns to the inputbox (this works), and valid data should execute the > corresponding sub-routines, and then return to the inputbox. I am unable > to > format this so far to get it to do this. I have tried loops and ended up > with > mostly endless loops. I have also tried to call (a 2nd call) the > sub-procedure for the main menu (mainmenu()) at the end of the script, but > it > simply stops after the previous sub-routines finish. I have also tried to > add > the mainmenu() call at the end of each sub-routine for option 1thru4 to no > avail, it still stops after each sub-routine. > > The inputbox and the use of subroutines for the selections 1-4 are > required, > so I can not re-write this entire thing. Any suggestions? > > the script: > > __________________________________________________________ > Option Explicit > > Dim fso, objshl, textfile, title, choice, inputtest, program, exitnow > > Set fso = CreateObject("Scripting.FileSystemObject") > Set objshl = CreateObject("WScript.Shell") > textfile = "c:\scriptlog.txt" > title = "Main Menu - Current Date: " & Date > > '************************* > 'Main Processing Section * > '************************* > > mainmenu() > > If choice = "1" Then > Logfile() > Powerpoint() > ElseIf choice = "2" then > Logfile() > Excel() > ElseIf choice = "3" Then > Viewlogfile() > ElseIf choice = "4" then > Deletelogfile() > End If > > '******************************************** > 'Main Menu for player input and value testing > '******************************************** > Sub mainmenu() > Do Until inputtest = "valid" > choice = (InputBox(("1. Run PowerPoint") & vbCrLf & ("2. Run Excel")_ > & vbCrLf & ("3. View Log File") & vbCrLf &_ > ("4. Delete Log File") & vbCrLf & ("5. Quit") & vbCrLf &_ > vbCrLf & vbTab & vbTab & vbTab & "Choose By > Number",title)) > > If choice = "1" Then > inputtest = "valid" > program = "PowerPoint" > ElseIf choice = "2" then > inputtest = "valid" > program = "Excel" > ElseIf choice = "3" Then > inputtest = "valid" > ElseIf choice = "4" then > inputtest = "valid" > ElseIf choice = "5" Then > WScript.Quit > Else MsgBox("Your selection was not valid") > End If > Loop > End Sub > > '********************************************** > 'Create 'start' logfile text for option 1 and 2 > '********************************************** > Sub Logfile() > Dim log > If (fso.FileExists(textfile)) Then > Set log = fso.OpenTextFile(textfile,8) > log.WriteLine "-- -- -- -- -- -- -- -- -- -- -- --" > log.WriteLine ((program) & " started on ") & Date > log.WriteLine ((program) & " started at ") & Time > log.WriteLine "-- -- -- --" > log.close > Else > Set log = fso.OpenTextFile(textfile, 2, "true") > log.WriteLine "-- -- -- -- -- -- -- -- -- -- -- --" > log.WriteLine ((program) & " started on ") & Date > log.WriteLine ((program) & " started at ") & Time > log.WriteLine "-- -- -- --" > log.close > End If > End Sub > > '************************************** > 'Process tasks for option '1' selection > '************************************** > Sub Powerpoint() > Dim log > objshl.Run "powerpnt.exe",,True > Set log = fso.OpenTextFile(textfile, 8) > log.WriteLine "PowerPoint stopped on " & Date > log.WriteLine "PowerPoint stopped at " & Time > log.WriteLine "-- -- -- -- -- -- -- -- -- -- -- --" > log.close() > End Sub > > '************************************** > 'Process tasks for option '2' selection > '************************************** > Sub Excel() > Dim log > objshl.Run "excel.exe",,True > Set log = fso.OpenTextFile(textfile, 8) > log.WriteLine "Excel stopped on " & Date > log.WriteLine "Excel stopped at " & Time > log.WriteLine "-- -- -- -- -- -- -- -- -- -- -- --" > log.close() > End Sub > > '************************************** > 'Process tasks for option '3' selection > '************************************** > Sub Viewlogfile() > Dim output, log > Set log = fso.OpenTextFile(textfile, 1) > If (fso.FileExists(textfile)) Then > output = log.ReadAll > log.Close > MsgBox output > Else > MsgBox("The log file does not exist") > End If > End Sub > > '************************************** > 'Process tasks for option '4' selection > '************************************** > Sub Deletelogfile() > Dim confirm, file > If Not (fso.FileExists(textfile)) Then > MsgBox "There is no file to delete", 0 > Else > confirm = MsgBox("Are you sure you wish to delete this?", 4, "Confirm > Selection") > If confirm = vbYes Then > fso.DeleteFile textfile > Set file = fso.OpenTextFile(textfile, 2, "true") > file.WriteLine "Logfile created on " & Date & " at " & Time > file.close > End if > End If > End Sub until the user selects to quit. There must be several ways to do this, but I remove the code before the Subs (except the call to mainmenu), then I would revise Sub mainmenu as follow: =========== Sub mainmenu() inputtest = "valid" Do Until inputtest = "quit" choice = (InputBox(("1. Run PowerPoint") _ & vbCrLf & ("2. Run Excel") _ & vbCrLf & ("3. View Log File") _ & vbCrLf & ("4. Delete Log File") _ & vbCrLf & ("5. Quit") _ & vbCrLf & vbCrLf _ & vbTab & vbTab & vbTab & "Choose By Number",title)) Select Case choice Case "1" Logfile() Powerpoint() Case "2" Logfile() Excel() Case "3" Viewlogfile() Case "4" Deletelogfile() Case "5" inputtest = "quit" Case Else MsgBox("Your selection was not valid") End Select Loop End Sub ======== This worked for me. -- Richard Mueller MVP Directory Services Hilltop Lab - http://www.rlmueller.net -- |
| | Re: recursion help request "Vgolfmaster" <Vgolfmaster@xxxxxx> wrote in message news:811E3A53-97D6-4C04-AD36-F3C6D1FDC10C@xxxxxx Quote: > > hi, > > I have a vbscript that I can not get to recurs properly. If the user > enters > '5' for input, the script should end. For ALL other input: invalid data > returns to the inputbox (this works), and valid data should execute the > corresponding sub-routines, and then return to the inputbox. I am unable > to > format this so far to get it to do this. I have tried loops and ended up > with > mostly endless loops. I have also tried to call (a 2nd call) the > sub-procedure for the main menu (mainmenu()) at the end of the script, but > it > simply stops after the previous sub-routines finish. I have also tried to > add > the mainmenu() call at the end of each sub-routine for option 1thru4 to no > avail, it still stops after each sub-routine. > > The inputbox and the use of subroutines for the selections 1-4 are > required, > so I can not re-write this entire thing. Any suggestions? > > the script: you expect a defined set of input response from the user, the program cries out for a "Case Select" construct rather than a nested if-then-elseif set of statements. Here is the main part of your program again. Please note that I did not review or test the remainder of the code. '************************* 'Main Processing Section * '************************* mainmenu() Do Select Case choice Case 1 program = "PowerPoint" Logfile() Powerpoint() Case 2 program = "Excel" Logfile() Excel() Case 3 Viewlogfile() Case 4 Deletelogfile() Case Else WScript.quit End Select Loop '******************************************** 'Main Menu for player input and value testing '******************************************** Sub mainmenu() Do choice = (InputBox(_ ("1. Run PowerPoint") & VbCrLf & _ ("2. Run Excel") & VbCrLf & _ ("3. View Log File") & VbCrLf &_ ("4. Delete Log File") & VbCrLf & _ ("5. Quit") & VbCrLf & VbCrLf & vbTab & vbTab & vbTab & _ "Choose By Number",title)) if IsNumeric(choice) then if (choice > 0) and (choice < 6) then Exit Do MsgBox("Your selection was not valid") Loop End Sub |
| | Re: recursion help request Thanks Richard, I agree, recursion was the wrong term. I modified the script using your advice and some other input I got, and it is now working! Thanks much "Richard Mueller [MVP]" wrote: Quote: > > "Vgolfmaster" <Vgolfmaster@xxxxxx> wrote in message > news:811E3A53-97D6-4C04-AD36-F3C6D1FDC10C@xxxxxx Quote: > > > > hi, > > > > I have a vbscript that I can not get to recurs properly. If the user > > enters > > '5' for input, the script should end. For ALL other input: invalid data > > returns to the inputbox (this works), and valid data should execute the > > corresponding sub-routines, and then return to the inputbox. I am unable > > to > > format this so far to get it to do this. I have tried loops and ended up > > with > > mostly endless loops. I have also tried to call (a 2nd call) the > > sub-procedure for the main menu (mainmenu()) at the end of the script, but > > it > > simply stops after the previous sub-routines finish. I have also tried to > > add > > the mainmenu() call at the end of each sub-routine for option 1thru4 to no > > avail, it still stops after each sub-routine. > > > > The inputbox and the use of subroutines for the selections 1-4 are > > required, > > so I can not re-write this entire thing. Any suggestions? > > > > the script: > > > > __________________________________________________________ > > Option Explicit > > > > Dim fso, objshl, textfile, title, choice, inputtest, program, exitnow > > > > Set fso = CreateObject("Scripting.FileSystemObject") > > Set objshl = CreateObject("WScript.Shell") > > textfile = "c:\scriptlog.txt" > > title = "Main Menu - Current Date: " & Date > > > > '************************* > > 'Main Processing Section * > > '************************* > > > > mainmenu() > > > > If choice = "1" Then > > Logfile() > > Powerpoint() > > ElseIf choice = "2" then > > Logfile() > > Excel() > > ElseIf choice = "3" Then > > Viewlogfile() > > ElseIf choice = "4" then > > Deletelogfile() > > End If > > > > '******************************************** > > 'Main Menu for player input and value testing > > '******************************************** > > Sub mainmenu() > > Do Until inputtest = "valid" > > choice = (InputBox(("1. Run PowerPoint") & vbCrLf & ("2. Run Excel")_ > > & vbCrLf & ("3. View Log File") & vbCrLf &_ > > ("4. Delete Log File") & vbCrLf & ("5. Quit") & vbCrLf &_ > > vbCrLf & vbTab & vbTab & vbTab & "Choose By > > Number",title)) > > > > If choice = "1" Then > > inputtest = "valid" > > program = "PowerPoint" > > ElseIf choice = "2" then > > inputtest = "valid" > > program = "Excel" > > ElseIf choice = "3" Then > > inputtest = "valid" > > ElseIf choice = "4" then > > inputtest = "valid" > > ElseIf choice = "5" Then > > WScript.Quit > > Else MsgBox("Your selection was not valid") > > End If > > Loop > > End Sub > > > > '********************************************** > > 'Create 'start' logfile text for option 1 and 2 > > '********************************************** > > Sub Logfile() > > Dim log > > If (fso.FileExists(textfile)) Then > > Set log = fso.OpenTextFile(textfile,8) > > log.WriteLine "-- -- -- -- -- -- -- -- -- -- -- --" > > log.WriteLine ((program) & " started on ") & Date > > log.WriteLine ((program) & " started at ") & Time > > log.WriteLine "-- -- -- --" > > log.close > > Else > > Set log = fso.OpenTextFile(textfile, 2, "true") > > log.WriteLine "-- -- -- -- -- -- -- -- -- -- -- --" > > log.WriteLine ((program) & " started on ") & Date > > log.WriteLine ((program) & " started at ") & Time > > log.WriteLine "-- -- -- --" > > log.close > > End If > > End Sub > > > > '************************************** > > 'Process tasks for option '1' selection > > '************************************** > > Sub Powerpoint() > > Dim log > > objshl.Run "powerpnt.exe",,True > > Set log = fso.OpenTextFile(textfile, 8) > > log.WriteLine "PowerPoint stopped on " & Date > > log.WriteLine "PowerPoint stopped at " & Time > > log.WriteLine "-- -- -- -- -- -- -- -- -- -- -- --" > > log.close() > > End Sub > > > > '************************************** > > 'Process tasks for option '2' selection > > '************************************** > > Sub Excel() > > Dim log > > objshl.Run "excel.exe",,True > > Set log = fso.OpenTextFile(textfile, 8) > > log.WriteLine "Excel stopped on " & Date > > log.WriteLine "Excel stopped at " & Time > > log.WriteLine "-- -- -- -- -- -- -- -- -- -- -- --" > > log.close() > > End Sub > > > > '************************************** > > 'Process tasks for option '3' selection > > '************************************** > > Sub Viewlogfile() > > Dim output, log > > Set log = fso.OpenTextFile(textfile, 1) > > If (fso.FileExists(textfile)) Then > > output = log.ReadAll > > log.Close > > MsgBox output > > Else > > MsgBox("The log file does not exist") > > End If > > End Sub > > > > '************************************** > > 'Process tasks for option '4' selection > > '************************************** > > Sub Deletelogfile() > > Dim confirm, file > > If Not (fso.FileExists(textfile)) Then > > MsgBox "There is no file to delete", 0 > > Else > > confirm = MsgBox("Are you sure you wish to delete this?", 4, "Confirm > > Selection") > > If confirm = vbYes Then > > fso.DeleteFile textfile > > Set file = fso.OpenTextFile(textfile, 2, "true") > > file.WriteLine "Logfile created on " & Date & " at " & Time > > file.close > > End if > > End If > > End Sub > I wouldn't call this recursion, but you want to keep running in the loop > until the user selects to quit. There must be several ways to do this, but I > remove the code before the Subs (except the call to mainmenu), then I would > revise Sub mainmenu as follow: > =========== > Sub mainmenu() > inputtest = "valid" > Do Until inputtest = "quit" > choice = (InputBox(("1. Run PowerPoint") _ > & vbCrLf & ("2. Run Excel") _ > & vbCrLf & ("3. View Log File") _ > & vbCrLf & ("4. Delete Log File") _ > & vbCrLf & ("5. Quit") _ > & vbCrLf & vbCrLf _ > & vbTab & vbTab & vbTab & "Choose By Number",title)) > > Select Case choice > Case "1" > Logfile() > Powerpoint() > Case "2" > Logfile() > Excel() > Case "3" > Viewlogfile() > Case "4" > Deletelogfile() > Case "5" > inputtest = "quit" > Case Else > MsgBox("Your selection was not valid") > End Select > Loop > End Sub > ======== > This worked for me. > > -- > Richard Mueller > MVP Directory Services > Hilltop Lab - http://www.rlmueller.net > -- > > > |
| | Re: recursion help request Thanks as well Pegasus, Looks like you and Richard both had me led in the right direction - sorry that you both spent time on this and duplicated the effort but I'll gladly take more feedback as compared to none any day! "Pegasus [MVP]" wrote: Quote: > > "Vgolfmaster" <Vgolfmaster@xxxxxx> wrote in message > news:811E3A53-97D6-4C04-AD36-F3C6D1FDC10C@xxxxxx Quote: > > > > hi, > > > > I have a vbscript that I can not get to recurs properly. If the user > > enters > > '5' for input, the script should end. For ALL other input: invalid data > > returns to the inputbox (this works), and valid data should execute the > > corresponding sub-routines, and then return to the inputbox. I am unable > > to > > format this so far to get it to do this. I have tried loops and ended up > > with > > mostly endless loops. I have also tried to call (a 2nd call) the > > sub-procedure for the main menu (mainmenu()) at the end of the script, but > > it > > simply stops after the previous sub-routines finish. I have also tried to > > add > > the mainmenu() call at the end of each sub-routine for option 1thru4 to no > > avail, it still stops after each sub-routine. > > > > The inputbox and the use of subroutines for the selections 1-4 are > > required, > > so I can not re-write this entire thing. Any suggestions? > > > > the script: > Your specification does not require a recursion - it requires a loop. Since > you expect a defined set of input response from the user, the program cries > out for a "Case Select" construct rather than a nested if-then-elseif set of > statements. Here is the main part of your program again. Please note that I > did not review or test the remainder of the code. > > '************************* > 'Main Processing Section * > '************************* > mainmenu() > > Do > Select Case choice > Case 1 > program = "PowerPoint" > Logfile() > Powerpoint() > Case 2 > program = "Excel" > Logfile() > Excel() > Case 3 > Viewlogfile() > Case 4 > Deletelogfile() > Case Else > WScript.quit > End Select > Loop > > '******************************************** > 'Main Menu for player input and value testing > '******************************************** > Sub mainmenu() > Do > choice = (InputBox(_ > ("1. Run PowerPoint") & VbCrLf & _ > ("2. Run Excel") & VbCrLf & _ > ("3. View Log File") & VbCrLf &_ > ("4. Delete Log File") & VbCrLf & _ > ("5. Quit") & VbCrLf & VbCrLf & vbTab & vbTab & vbTab & _ > "Choose By Number",title)) > if IsNumeric(choice) then if (choice > 0) and (choice < 6) then Exit Do > MsgBox("Your selection was not valid") > Loop > End Sub > > > |
| | #6 (permalink) |
| | Re: recursion help request "Vgolfmaster" <Vgolfmaster@xxxxxx> wrote in message news:26DD2FF5-6533-44F9-A31E-E593E2615E0B@xxxxxx Quote: > Thanks as well Pegasus, > > Looks like you and Richard both had me led in the right direction - sorry > that you both spent time on this and duplicated the effort but I'll gladly > take more feedback as compared to none any day! your post at much the same time. |
| RE: file rename with folder recursion | PowerShell | |||
| Xml, Recursion and Base64 | PowerShell | |||
| Xml and Recursion | PowerShell | |||
| Xml, recursion and Ôase64 | PowerShell | |||
| How do I limit subfolder recursion? | VB Script | |||
