Vista - Batch file problem
Old 05-02-2009   #1 (permalink)
Vista Ultimate x64
Batch file problem
Hi, I just created a batch file which does what I need it to perfecly. I just need one other thing in it so that I can keep track of when (date and time) it is run. Is there a command I can use that will be able to post the time and date it was opened everytime it is run, in a folder or better, a text file of my choice?
Thanks
Old 05-02-2009   #2 (permalink)
Pegasus [MVP]
Re: Batch file problem
"Miltzi" <guest@xxxxxx-email.com> wrote in message
news:cfa70ffdf9c20990528a7829a264ada4@xxxxxx-gateway.com...
> Thanks
> Miltzi
Sure is - try this:
@echo off
echo %date% %time% %UserName% %ComputerName% >> c:\Miltzi.log
{Your code goes here}
Old 05-02-2009   #3 (permalink)
Vista Ultimate x64
Quote  Quote: Originally Posted by Pegasus [MVP] View Post
> Thanks
> Miltzi
Sure is - try this:
@echo off
Perfect!!! Thanks so much
Batch-file not working: PATH-problem? Vista General
vista batch file problem Vista General
batch file help Vista General
Batch file Vista file management
batch file calling exe file problem Vista security
