| | Findout shortcut from which script was launched ? Hello, In a VBScript I wish to know if the script was called from a shortcut and if so what is the path of this shortcut. Is this possible ? In case you wish to know, here is why : i have a script which renames files in a folder. Currently i do the renames in the folder where the script itself is situated. I would like this to work also with a shortcut to the script file : the rename should apply to the folder where the shortcut is situated, not the folder where the script file is situated. Any idea ? Thanks a lot Jean-Marie |
| | Re: Findout shortcut from which script was launched ? Jean-Marie wrote: Quote: > In a VBScript I wish to know if the script was called from a shortcut and > if so what is the path of this shortcut. Is this possible ? > > In case you wish to know, here is why : i have a script which renames > files in a folder. > Currently i do the renames in the folder where the script itself is > situated. > I would like this to work also with a shortcut to the script file : the > rename should apply to the folder where the shortcut is situated, not the > folder where the script file is situated. > > Any idea ? by a shortcut, or the location of the shortcut. Wscript.ScriptPath returns the name and path of the script file itself, not any shortcut that launched it. However, objFSO.GetAbsolutePathName(".") returns the current directory. You can modify the "Start in" property of the shortcut so this returns the value you want: Set objFSO = CreateObject("Scripting.FileSystemObject") Wscript.Echo objFSO.GetAbsolutePathName(".") You would need to modify this property of the shortcut for each folder. It actually would not matter where the shortcut is saved. -- Richard Mueller MVP Directory Services Hilltop Lab - http://www.rlmueller.net -- |
| | Re: Findout shortcut from which script was launched ? "jm.almeras" <nospam@xxxxxx> wrote in message news:ecaJQ8czJHA.1716@xxxxxx Quote: > Hello, > > In a VBScript I wish to know if the script was called from a shortcut and > if so what is the path of this shortcut. Is this possible ? Quote: > In case you wish to know, here is why : i have a script which renames > files in a folder. > Currently i do the renames in the folder where the script itself is > situated. > I would like this to work also with a shortcut to the script file : the > rename should apply to the folder where the shortcut is situated, not the > folder where the script file is situated. Then run it by dragging the desired folder onto either the script itself, or a shortcut to the script. /Al Quote: > Any idea ? > > Thanks a lot > > Jean-Marie > |
| | Re: Findout shortcut from which script was launched ? On May 6, 12:15 am, "jm.almeras" <nos...@xxxxxx> wrote: Quote: > In a VBScript I wish to know if the script was called from a shortcut and if > so what is the path of this shortcut. Is this possible ? > > In case you wish to know, here is why : i have a script which renames > files in a folder. Currently i do the renames in the folder where the script > itself is situated. > I would like this to work also with a shortcut to the script file : the > rename should apply to the folder where the shortcut is situated, not the > folder where the script file is situated. if you ask the question in the right way. I have a more complex situation because I want to apply the .vbs script only to the selected files of a given directory. There are two situations. The first, which I never use anymore, is that I have a shortcut. The shortcut needs to know what directory it was started in. But that's not good enough. It actually needs to know what Explorer window is active so for that I had to make a mini .OCX file which uses the winAPI GetForegroundWindowHandle() and then I run through the .windows collection of the Shell.Application object to see if there's a match on the .HWND. Richard Meuller's suggestion probably suffices for your situation. The other thing that I do (independent of the prior paragraph) is to make a change in the registry so that for all .jpg files, I get a context menu item (ie. when I right click) that will execute my script when it's selected. The script gets passed the name of the file that it was started on, from which it knows the directory. Csaba Gabor from Vienna |
| | Re: Findout shortcut from which script was launched ? Thank you Richard, Al, urkec and Csaba for your advice. Richard's solution works but i find it inconvenient, because editing the shortcut property to write the folder path as startin directory is cumbersome (i have tested, it does not work if i put "." as startin property) I took Al's suggestion and introduced the possibility of dropping a folder on the script. It works fine. Also, urkec's idea to put the script in the SendTo Folder is good. |
| | #6 (permalink) |
| | Re: Findout shortcut from which script was launched ? Your answer is interesting to me because i also wish to make it possible to apply the script to selected files. It works with a small number of files which i drop on the script (or its shortcut), but there is a limit : the maximum size of the command line (pity !) I would be interested in knowing what change you make in the registry. But is this solution not equivalent to putting the script in the SendTo Folder and when selecting a file or several, selecting Send To the script in the contextual menu ? Thank you Jean-Marie "Csaba Gabor" <danswer@xxxxxx> a écrit dans le message de news: 32a8e31d-e8f8-4be2-809f-69e170270593@xxxxxx... Quote: > On May 6, 12:15 am, "jm.almeras" <nos...@xxxxxx> wrote: Quote: >> In a VBScript I wish to know if the script was called from a shortcut and >> if >> so what is the path of this shortcut. Is this possible ? >> >> In case you wish to know, here is why : i have a script which renames >> files in a folder. Currently i do the renames in the folder where the >> script >> itself is situated. >> I would like this to work also with a shortcut to the script file : the >> rename should apply to the folder where the shortcut is situated, not the >> folder where the script file is situated. > This is a slippery problem, but it does have a solution... > if you ask the question in the right way. I have a more > complex situation because I want to apply the .vbs > script only to the selected files of a given directory. > > There are two situations. The first, which I never use > anymore, is that I have a shortcut. The shortcut needs > to know what directory it was started in. But that's > not good enough. It actually needs to know what > Explorer window is active so for that I had to make > a mini .OCX file which uses the winAPI > GetForegroundWindowHandle() and then I run through > the .windows collection of the Shell.Application > object to see if there's a match on the .HWND. > Richard Meuller's suggestion probably suffices > for your situation. > > The other thing that I do (independent of the prior > paragraph) is to make a change in the registry > so that for all .jpg files, I get a context > menu item (ie. when I right click) that will > execute my script when it's selected. The > script gets passed the name of the file > that it was started on, from which it knows > the directory. > > Csaba Gabor from Vienna |
| | #7 (permalink) |
| | Re: Findout shortcut from which script was launched ? On May 8, 12:02 pm, "jm.almeras" <nos...@xxxxxx> wrote: Quote: > Your answer is interesting to me because i also wish to make it possible to > apply the script to selected files. It works with a small number of files > which i drop on the script (or its shortcut), but there is a limit : the > maximum size of the command line (pity !) In HKCR\*\shell\ place: Cmd (REG_SZ): &Cmd window in this directory Then make a subkey: In HKCR\*\shell\Cmd\ place command (REG_SZ): cmd /K cd "%0\.." & title Context Menu Cmd Window & mode con lines=60 cols=100 or cmd "c:\phplib\Context Cmd window.lnk" If you do the second one (which is preferable for me) my Context Cmd window.lnk shortcut has the following properties set: under General: Context Cmd window under Shortcut: Target: %windir%\system32\cmd.exe Shortcut key: None Run: Normal window under Options: Cursor size: Small Display options: Window Edit options: QuickEdit mode, Insert mode under Layout: Screen buffer size: Width: 90, Height: 300 Window size: Width: 90, Height: 70 Window position: Let system position window If you have a custom editor you like, you could do something like: \HKCR\*\shell\Edit2: &Edit (with emacs) \HKCR\*\shell\Edit2\command: C:\Program Files\emacs\bin\runemacs.exe - geometry 155x59 "%1" For a specific file type it's a bit more involved. Let's say .jpg Go to \HKCR\.jpg\(Default) and see the value listed there. It's jpegfile Now make \HKCR\jpegfile\shell\Resize: Res&ize \HKCR\jpegfile\shellResize\command: c:\phpdir\php-win.exe "C:\Photo \Util\Resize.php" "%1" %* That %0 and %1 are the file that you are right clicking on. The quotes (") are because of possible spaces in file names %* means any remaining arguments Quote: > I would be interested in knowing what change you make in the registry. But > is this solution not equivalent to putting the script in the SendTo Folder > and when selecting a file or several, selecting Send To the script in the > contextual menu ? Quote: > Thank you > > Jean-Marie > > "Csaba Gabor" <dans...@xxxxxx> a écrit dans le message de news: > 32a8e31d-e8f8-4be2-809f-69e170270...@xxxxxx > Quote: > > On May 6, 12:15 am, "jm.almeras" <nos...@xxxxxx> wrote: Quote: > >> In a VBScript I wish to know if the script was called from a shortcut and > >> if > >> so what is the path of this shortcut. Is this possible ? Quote: Quote: > >> In case you wish to know, here is why : i have a script which renames > >> files in a folder. Currently i do the renames in the folder where the > >> script > >> itself is situated. > >> I would like this to work also with a shortcut to the script file : the > >> rename should apply to the folder where the shortcut is situated, not the > >> folder where the script file is situated. Quote: > > This is a slippery problem, but it does have a solution... > > if you ask the question in the right way. I have a more > > complex situation because I want to apply the .vbs > > script only to the selected files of a given directory. Quote: > > There are two situations. The first, which I never use > > anymore, is that I have a shortcut. The shortcut needs > > to know what directory it was started in. But that's > > not good enough. It actually needs to know what > > Explorer window is active so for that I had to make > > a mini .OCX file which uses the winAPI > > GetForegroundWindowHandle() and then I run through > > the .windows collection of the Shell.Application > > object to see if there's a match on the .HWND. > > Richard Meuller's suggestion probably suffices > > for your situation. Quote: > > The other thing that I do (independent of the prior > > paragraph) is to make a change in the registry > > so that for all .jpg files, I get a context > > menu item (ie. when I right click) that will > > execute my script when it's selected. The > > script gets passed the name of the file > > that it was started on, from which it knows > > the directory. Quote: > > Csaba Gabor from Vienna |
| script to create shortcut on user desktop | PowerShell | |||
| IE8 Beta1 Launched | Vista News | |||
| Script Host Client launched from Windows Service | Vista security | |||
| Creating a shortcut for Powershell script | PowerShell | |||
| When new MS keyboards will be launched? | Vista hardware & devices | |||
