| | Modify string based on a specific character I would very much like to change a string in case a certain character in that string exists. I want my script to read the string untill it finds that specific character and if it finds it, I want my script to remove everything to the right of that character including the character itself. The character in question is a middle score. So let's say I have the following string: "Carlos-Santana" I would like the output to be: "Carlos" If I have the following string: "CarlosSantana" I want the output to be: "CarlosSantana" So the string should be modified only in case the middle score exists in the string. I can use the Replace Function but how would I specify in vbscript to remove everything up to a certain character. Do I first have to count the number of characters up to that certain character? Thanks! |
| | Re: Modify string based on a specific character C Wilson schrieb: Quote: > I would very much like to change a string in case a certain character in that > string exists. I want my script to read the string untill it finds that > specific character and if it finds it, I want my script to remove everything > to the right of that character including the character itself. > The character in question is a middle score. > > So let's say I have the following string: > > "Carlos-Santana" > > I would like the output to be: "Carlos" > > If I have the following string: > > "CarlosSantana" > > I want the output to be: "CarlosSantana" > > So the string should be modified only in case the middle score exists in the > string. > > I can use the Replace Function but how would I specify in vbscript to remove > everything up to a certain character. Do I first have to count the number of > characters up to that certain character? > > Thanks! a RegExp. As VBScript has a function to find the possition a substring (needle) in a string (haystack) - Instr() - you don't have to read the haystack character by character. Start with this: Dim sNeedle : sNeedle = "-" Dim aTests : aTests = Array( _ "" _ , "no minus in here" _ , "Carlos-Santana" _ , "CarlosSantana" _ , "- minus in front" _ , "minustail -" _ , "alle-voegel-sind-schon-da" _ , "alle - voegel - sind - schon - da" _ ) Dim sTest For Each sTest in aTests WScript.Echo "|" & sTest & "|" Dim nPos : nPos = InStr( sTest, sNeedle ) If 0 < nPos Then sTest = Left( sTest, nPos - 1 ) WScript.Echo "|" & sTest & "|" WScript.Echo Next output: === removeFromChar: remove right part of string from (incl.) char === || || |no minus in here| |no minus in here| |Carlos-Santana| |Carlos| |CarlosSantana| |CarlosSantana| |- minus in front| || |minustail -| |minustail | |alle-voegel-sind-schon-da| |alle| |alle - voegel - sind - schon - da| |alle | === removeFromChar: 0 done (00:00:00) =============================== to check if InStr() works for you and whether special cases (e.g. blanks) need further treatment. |
| | Re: Modify string based on a specific character "ekkehard.horner" <ekkehard.horner@xxxxxx> wrote in message news:4a06c682$0$32665$9b4e6d93@xxxxxx-online.net... Quote: >C Wilson schrieb: Quote: >> I would very much like to change a string in case a certain character in >> that string exists. I want my script to read the string untill it finds >> that specific character and if it finds it, I want my script to remove >> everything to the right of that character including the character itself. >> The character in question is a middle score. >> >> So let's say I have the following string: >> >> "Carlos-Santana" >> >> I would like the output to be: "Carlos" >> >> If I have the following string: >> >> "CarlosSantana" I want the output to be: "CarlosSantana" >> >> So the string should be modified only in case the middle score exists in >> the string. >> >> I can use the Replace Function but how would I specify in vbscript to >> remove everything up to a certain character. Do I first have to count the >> number of characters up to that certain character? >> >> Thanks! > As you search for a specific needle (character) there is no need for > a RegExp. As VBScript has a function to find the possition a substring > (needle) in a string (haystack) - Instr() - you don't have to read > the haystack character by character. Start with this: > > Dim sNeedle : sNeedle = "-" > Dim aTests : aTests = Array( _ > "" _ > , "no minus in here" _ > , "Carlos-Santana" _ > , "CarlosSantana" _ > , "- minus in front" _ > , "minustail -" _ > , "alle-voegel-sind-schon-da" _ > , "alle - voegel - sind - schon - da" _ > ) > Dim sTest > For Each sTest in aTests > WScript.Echo "|" & sTest & "|" > Dim nPos : nPos = InStr( sTest, sNeedle ) > If 0 < nPos Then sTest = Left( sTest, nPos - 1 ) > WScript.Echo "|" & sTest & "|" > WScript.Echo > Next Dim nPos : nPos = InStr( sTest, sNeedle ) If 0 < nPos Then sTest = Left( sTest, nPos - 1 ) with this line: if sTest <> "" then sTest = split(sTest,"-")(0) and got identical results. One person's way to skin a cat is not another's... ;-) /Al Quote: > > output: > > === removeFromChar: remove right part of string from (incl.) char === > || > || > > |no minus in here| > |no minus in here| > > |Carlos-Santana| > |Carlos| > > |CarlosSantana| > |CarlosSantana| > > |- minus in front| > || > > |minustail -| > |minustail | > > |alle-voegel-sind-schon-da| > |alle| > > |alle - voegel - sind - schon - da| > |alle | > > === removeFromChar: 0 done (00:00:00) =============================== > > to check if InStr() works for you and whether special cases (e.g. blanks) > need further treatment. > > |
| | Re: Modify string based on a specific character All the birds are already there? Shoot! I missed it! I like the way you explain things. I am learning this stuff and your explanations are helpful! Cary "ekkehard.horner" <ekkehard.horner@xxxxxx> wrote in message news:4a06c682$0$32665$9b4e6d93@xxxxxx-online.net... Quote: >C Wilson schrieb: Quote: >> I would very much like to change a string in case a certain character in >> that string exists. I want my script to read the string untill it finds >> that specific character and if it finds it, I want my script to remove >> everything to the right of that character including the character itself. >> The character in question is a middle score. >> >> So let's say I have the following string: >> >> "Carlos-Santana" >> >> I would like the output to be: "Carlos" >> >> If I have the following string: >> >> "CarlosSantana" I want the output to be: "CarlosSantana" >> >> So the string should be modified only in case the middle score exists in >> the string. >> >> I can use the Replace Function but how would I specify in vbscript to >> remove everything up to a certain character. Do I first have to count the >> number of characters up to that certain character? >> >> Thanks! > As you search for a specific needle (character) there is no need for > a RegExp. As VBScript has a function to find the possition a substring > (needle) in a string (haystack) - Instr() - you don't have to read > the haystack character by character. Start with this: > > Dim sNeedle : sNeedle = "-" > Dim aTests : aTests = Array( _ > "" _ > , "no minus in here" _ > , "Carlos-Santana" _ > , "CarlosSantana" _ > , "- minus in front" _ > , "minustail -" _ > , "alle-voegel-sind-schon-da" _ > , "alle - voegel - sind - schon - da" _ > ) > Dim sTest > For Each sTest in aTests > WScript.Echo "|" & sTest & "|" > Dim nPos : nPos = InStr( sTest, sNeedle ) > If 0 < nPos Then sTest = Left( sTest, nPos - 1 ) > WScript.Echo "|" & sTest & "|" > WScript.Echo > Next > > output: > > === removeFromChar: remove right part of string from (incl.) char === > || > || > > |no minus in here| > |no minus in here| > > |Carlos-Santana| > |Carlos| > > |CarlosSantana| > |CarlosSantana| > > |- minus in front| > || > > |minustail -| > |minustail | > > |alle-voegel-sind-schon-da| > |alle| > > |alle - voegel - sind - schon - da| > |alle | > > === removeFromChar: 0 done (00:00:00) =============================== > > to check if InStr() works for you and whether special cases (e.g. blanks) > need further treatment. > > |
| read text file - but starting at a specific point (not the very first character of the very first line) | VB Script | |||
| Replace Nth character in a string | VB Script | |||
| Getting a combined string based upon similar reference values | PowerShell | |||
| Cannot delete/view/modify specific filetype | Vista performance & maintenance | |||
| How do I escape the wildcard character in a path string? | PowerShell | |||
