| | "DeleteFolder" not works properly Hello, I'm using the VBscript to delete a folder which contains Read-only files. here's the code, FileName: del.vbs Code: Dim FSO Set FSO = CreateObject("Scripting.FileSystemObject") If ( FSO.FolderExists("C:\GPS8.0") ) Then FSO.DeleteFolder "C:\GPS8.0",True MsgBox "FSO.DeleteFolder C:\GPS8.0\ -OK " ***************** when I manually execute this file, del.vbs,i.e. by double-clicking the del.vbs, it is deleting the folder(with read-only files). But when I trigger this .vbs file from inside a C++ application,say,using run-time library function, system("del.vbs");, it is not. It is emptying the folder but cannot delete the folder. After emptying the folder, I'm getting the Error # 70, Error Description:Permission Denied I'm the logged on user in the PC at this point of time and I 'm part of Adminisrtator's group. Help please. I heard that something like admin rights or privileges needs to be sent to the filesystem object when triggered from C++ application. Thanks, Sudhakar |
| | Re: "DeleteFolder" not works properly "Sudhakar" <Sudhakar@xxxxxx> wrote in message news:B1432178-07E3-4F92-8F31-5E6BC0A43C5A@xxxxxx Quote: > Hello, > > I'm using the VBscript to delete a folder which contains > Read-only files. > > here's the code, > FileName: del.vbs > Code: > Dim FSO > Set FSO = CreateObject("Scripting.FileSystemObject") > If ( FSO.FolderExists("C:\GPS8.0") ) Then > FSO.DeleteFolder "C:\GPS8.0",True > MsgBox "FSO.DeleteFolder C:\GPS8.0\ -OK " > ***************** > when I manually execute this file, del.vbs,i.e. by double-clicking the > del.vbs, it is deleting the folder(with read-only files). > But when I trigger this .vbs file from inside a C++ application,say,using > run-time library function, system("del.vbs");, it is not. > It is emptying the folder but cannot delete the folder. After emptying the > folder, I'm getting the Error # 70, Error Description:Permission Denied > > I'm the logged on user in the PC at this point of time and I 'm part of > Adminisrtator's group. > Help please. > I heard that something like admin rights or privileges needs to be sent to > the filesystem object when triggered from C++ application. > > Thanks, > Sudhakar can do it directly from C++? Having a homogenous C++ would be much cleaner and you would not incur the overhead of invoking the VB Script interpreter. |
| | Re: "DeleteFolder" not works properly "Pegasus [MVP]" wrote: Quote: > > "Sudhakar" <Sudhakar@xxxxxx> wrote in message > news:B1432178-07E3-4F92-8F31-5E6BC0A43C5A@xxxxxx Quote: > > Hello, > > > > I'm using the VBscript to delete a folder which contains > > Read-only files. > > > > here's the code, > > FileName: del.vbs > > Code: > > Dim FSO > > Set FSO = CreateObject("Scripting.FileSystemObject") > > If ( FSO.FolderExists("C:\GPS8.0") ) Then > > FSO.DeleteFolder "C:\GPS8.0",True > > MsgBox "FSO.DeleteFolder C:\GPS8.0\ -OK " > > ***************** > > when I manually execute this file, del.vbs,i.e. by double-clicking the > > del.vbs, it is deleting the folder(with read-only files). > > But when I trigger this .vbs file from inside a C++ application,say,using > > run-time library function, system("del.vbs");, it is not. > > It is emptying the folder but cannot delete the folder. After emptying the > > folder, I'm getting the Error # 70, Error Description:Permission Denied > > > > I'm the logged on user in the PC at this point of time and I 'm part of > > Adminisrtator's group. > > Help please. > > I heard that something like admin rights or privileges needs to be sent to > > the filesystem object when triggered from C++ application. > > > > Thanks, > > Sudhakar > Why would you want to invoke a VB Script file to delete a folder when you > can do it directly from C++? Having a homogenous C++ would be much cleaner > and you would not incur the overhead of invoking the VB Script interpreter. > > Hi , this purpose. PLease help using VBScript Quote: > |
| | Re: "DeleteFolder" not works properly "Sudhakar" <Sudhakar@xxxxxx> wrote in message news:7E51A768-F219-4343-BA65-6E1DBE7BB2A0@xxxxxx Quote: > > > "Pegasus [MVP]" wrote: > Quote: >> >> "Sudhakar" <Sudhakar@xxxxxx> wrote in message >> news:B1432178-07E3-4F92-8F31-5E6BC0A43C5A@xxxxxx Quote: >> > Hello, >> > >> > I'm using the VBscript to delete a folder which contains >> > Read-only files. >> > >> > here's the code, >> > FileName: del.vbs >> > Code: >> > Dim FSO >> > Set FSO = CreateObject("Scripting.FileSystemObject") >> > If ( FSO.FolderExists("C:\GPS8.0") ) Then >> > FSO.DeleteFolder "C:\GPS8.0",True >> > MsgBox "FSO.DeleteFolder C:\GPS8.0\ -OK " >> > ***************** >> > when I manually execute this file, del.vbs,i.e. by double-clicking the >> > del.vbs, it is deleting the folder(with read-only files). >> > But when I trigger this .vbs file from inside a C++ >> > application,say,using >> > run-time library function, system("del.vbs");, it is not. >> > It is emptying the folder but cannot delete the folder. After emptying >> > the >> > folder, I'm getting the Error # 70, Error Description:Permission Denied >> > >> > I'm the logged on user in the PC at this point of time and I 'm part of >> > Adminisrtator's group. >> > Help please. >> > I heard that something like admin rights or privileges needs to be sent >> > to >> > the filesystem object when triggered from C++ application. >> > >> > Thanks, >> > Sudhakar >> Why would you want to invoke a VB Script file to delete a folder when you >> can do it directly from C++? Having a homogenous C++ would be much >> cleaner >> and you would not incur the overhead of invoking the VB Script >> interpreter. >> >> Hi , > for > this purpose. PLease help using VBScript > Script file!) from your C++ application: @echo off echo %date% %time% %UserName% >> c:\test.txt rd /s /q "c:\My Folder\SomeFolder" 1>>c:\test.txt 2>>&1 The log file c:\test.txt will probably tell you what's wrong. |
| MIcrophone's wont work. "Audio not working properly"? | Sound & Audio | |||
| "Provider cannot be found. It may not be properly installed Error --2146824582" | Network & Sharing | |||
| "Could not perform this operation because the default mail client is not properly installed" | Vista General | |||
| Search - Detail View - "Folder" is backwards - can't sort properly | Vista file management | |||
| Works 8.5 in Vista: "Microsoft Works has stopped working" | Vista General | |||
