| | CDO Problem I'm trying to configure a script for a client so that he can send messages while away from the office. The following batch file works nicely, regardless of his location: @echo off set Sender=me@xxxxxx_isp.com set Host=mail.office_isp.com set User=me@xxxxxx_isp.com set Password=MyPassword set To=me@xxxxxx_isp.com blat.exe test.txt -server %Host% -subject Test -f %Sender% -to %To% -U %User% -PW %password% The following script file works while he is in the office but fails when he is on site: schema = "http://schemas.microsoft.com/cdo/configuration/" Set objEmail = CreateObject("CDO.Message") With objEmail .From = "me@xxxxxx_isp.com" .To = "me@xxxxxx_isp.com" .Subject = "Test Mail" .Textbody = "The quick brown fox" With .Configuration.Fields .Item (schema & "sendusing") = 2 .Item (schema & "smtpserver") = "mail.office_isp.com" .Item (schema & "smtpserverport") = 25 .Item (schema & "smtpauthenticate") = cdoBasic .Item (schema & "sendusername") = "me@xxxxxx_isp.com" .Item (schema & "smtpaccountname") = "me@xxxxxx_isp.com" .Item (schema & "sendpassword") = "MyPassword" End With .Configuration.Fields.Update .Send End With The error message is: The server rejected one or more recipient addresses. The server response was: 554 5.7.1 <82-220-76-236.client_isp.com[82.220.76.236]>: Client host rejected: Access denied Any thoughts as to why the batch file works and the script fails, even though it uses exactly the same parameters? |
| the problem with ndis.sys Blue Screen of Death problem solved? | Vista General | |||
| Re: Windows Mail Attachement Problem and Adobe Player Problem with IE8 | Vista mail | |||
| Multi-select problem in Windows Explorer BIG PROBLEM!!!!!! | Vista General | |||
| Generic McAfee Problem Message in Vista Problem Reports | Vista performance & maintenance | |||
| Vista Upgrade Problem - Windows Explorer Loop problem | Vista installation & setup | |||
