Vista - "For Each - Next" problem
Old 05-22-2009   #1 (permalink)
lyngsie
Hi All,
I get an "unexpexted Next" error in my script and cannot figure out where it
goes wrong. I've checked all End If's and cannot see that could be the
problem.
The script checks for Adobe versions and upgrade accordingly. If I comment
out the 2 "deep" If's the error goes away.
Can someone help me out?
CODE:
Dim objFSO
Dim objOutFile
Dim sWorkingFileName
Dim strLaunchCmd, errReturn, strUpgrade, strComputer
Const FOR_APPENDING = 8
sWorkingFileName = "%systemroot%\system32\adobe_update.log"
Set objFSO = CreateObject("Scripting.FileSystemObject")
If objFSO.FileExists(sWorkingFileName) Then
Set objOutFile = objFSO.OpenTextFile(sWorkingFileName, FOR_APPENDING)
Else
Set objOutFile = objFSO.CreateTextFile(sWorkingFileName)
End If
strComputer = "."
Set objWMIService = GetObject("winmgmts:" & _
"{impersonationLevel=impersonate}!\\" & strComputer & "\root\cimv2")
Set colSoftware = objWMIService.ExecQuery _
("SELECT * FROM Win32_Product WHERE Name Like 'Adobe %'")
If colSoftware.Count > 0 Then
For Each objSoftware in colSoftware
If InStr(1,objSoftware.Caption,"Adobe Acrobat") <> 0 Then
If InStr(1,objSoftware.Version,"9.0") <> 0 Then
strLaunchCmd = "msiexec.exe /p
\\adserv1\Software\adobe-updates\AcroProStdUpd910_T1T2_incr.msp /qb"
strUpgrade = "Acrobat Pro 9.1.0"
Else If InStr(1,objSoftware.Version,"8.") <> 0 And
objSoftware.Version <> "8.1.5" Then
\\adserv1\Software\adobe-updates\AcrobatUpd815_all_incr.msp /qb"
strUpgrade = "Acrobat Pro 8.1.5"
Else If InStr(1,objSoftware.Version,"7.") <> 0 And
objSoftware.Version <> "7.1.2" Then
\\adserv1\Software\adobe-updates\AcrobatUpd712_all_incr.msp /qb"
strUpgrade = "Acrobat Pro 7.1.2"
Else If InStr(1,objSoftware.Version,"6.") <> 0 Then
MsgBox "Please ask IT-Support to upgrade your Adobe Acrobat"
End If
End If
' Launch upgrades
Set oShell = CreateObject("WScript.Shell")
oShell.CurrentDirectory = "\\adserv1\Software\adobe-updates\"
errReturn = oShell.Run(strLaunchCmd,1,True)
If errReturn = 0 Then
objOutFile.WriteLine "Upgrade was successful. Upgraded from " &
objSoftware.Caption & vbtab & objSoftware.Version & " to version " &
strUpgrade
Else
objOutFile.WriteLine "Upgrade failed - Error #" & errReturn
End if
' Check for 9.1.0 versions and upgrade to 9.1.1
If InStr(objSoftware.Version,"9.1.0") <> 0 Then
\\adserv1\Software\adobe-updates\AcrobatUpd911_all_incr.msp /qb"
End If
If InStr(objSoftware.Caption,"Adobe Reader") <> 0 Then
If InStr(1,objSoftware.Version,"9.") <> 0 And objSoftware.Version
<> "9.1.1" Then
\\adserv1\Software\adobe-updates\AdbeRdrUpd911_all_incr.msp /qb"
strUpgrade = "Acrobat Reader 9.1.1"
\\adserv1\Software\adobe-updates\AdbeRdrUpd815_all_incr.msp /qb"
strUpgrade = "Acrobat Reader 8.1.5"
\\adserv1\Software\adobe-updates\AdbeRdrUpd712_all_incr.msp /qb"
strUpgrade = "Acrobat Reader 7.1.2"
Else If InStr(1,objSoftware.Version,"6.0") <> 0 Then
MsgBox "Please ask IT-Support to upgrade your Adobe Reader"
End If
End If
strUpgrade
Else
End If
Next
End If
Old 05-22-2009   #2 (permalink)
Pegasus [MVP]
Re: "For Each - Next" problem
"lyngsie" <lyngsie@xxxxxx> wrote in message
news:F2501DD8-8B62-4532-929D-762CADAB7DF0@xxxxxx
Quote:
> Hi All,
> it
> problem.
> CODE:
> Dim objFSO
> Dim objOutFile
> Else
> End If
> strComputer = "."
> End If
> End If
> ' Launch upgrades
> strUpgrade
> Else
> End if
> End If
> <> "9.1.1" Then
> End If
> End If
> strUpgrade
> Else
> End If
> Next
> End If
There are two problems with the way you wrote your script:
- You do not use consistent indenting.
- Your code is so long that its structure is impossible to see for a human.
As a rule of thumb, a specific script component should span at most as many
lines as will fit on a screen, same as a paragraph in a printed book should
span than half a page at most. If you break this rule then you will get
lost, as demonstrated in your code.
Below is a modified version of your code. As you see in lines 20-26, there
is a clear structure for your main "If" and "For each" construct. There is
no doubt at all where the "end if" and "next" statements go. Note also:
- I changed several of your "else if" statements to "elseif".
- I did not run your code and I did not check if every variable is declared.
The "Option Explicit" statement will tell you at runtime.
[01] Option Explicit
[02] Dim objFSO, objOutFile, sWorkingFileName, strLaunchCmd,
[03] Dim errReturn, strUpgrade, strComputer
[04] Const FOR_APPENDING = 8
[05]
[06] sWorkingFileName = "%systemroot%\system32\adobe_update.log"
[07] Set objFSO = CreateObject("Scripting.FileSystemObject")
[08]
[09] If objFSO.FileExists(sWorkingFileName) Then
[10] Set objOutFile = objFSO.OpenTextFile(sWorkingFileName, FOR_APPENDING)
[11] Else
[12] Set objOutFile = objFSO.CreateTextFile(sWorkingFileName)
[13] End If
[14]
[15] Set objWMIService = GetObject("winmgmts:" & _
[16] "{impersonationLevel=impersonate}!\\.\root\cimv2")
[17] Set colSoftware = objWMIService.ExecQuery _
[18] ("SELECT * FROM Win32_Product WHERE Name Like 'Adobe %'")
[19]
[20] If colSoftware.Count > 0 Then
[21] For Each objSoftware In colSoftware
[22] CheckAcrobat
[23] LaunchUpgrades
[24] Upgrade91
[25] Next
[26] End If
[27] '----------------------
[28] 'Check Acrobat Upgrades
[29] '----------------------
[30] Sub CheckAcrobat
[31] If InStr(1,objSoftware.Caption,"Adobe Acrobat") <> 0 Then
[32] If InStr(1,objSoftware.Version,"9.0") <> 0 Then
[33] strLaunchCmd = "msiexec.exe /p
[34] strUpgrade = "Acrobat Pro 9.1.0"
[35] ElseIf InStr(1,objSoftware.Version,"8.") <> 0 And
[36] strLaunchCmd = "msiexec.exe /p
[37] strUpgrade = "Acrobat Pro 8.1.5"
[38] ElseIf InStr(1,objSoftware.Version,"7.") <> 0 And
[39] strLaunchCmd = "msiexec.exe /p
[40] strUpgrade = "Acrobat Pro 7.1.2"
[41] ElseIf InStr(1,objSoftware.Version,"6.") <> 0 Then
[42] MsgBox "Please ask IT-Support to upgrade your Adobe Acrobat"
[43] End If
[44] End If
[45] End Sub
[46] '----------------
[47] 'Launch Upgrades
[48] '----------------
[49] Sub LaunchUpgrades
[50] Set oShell = CreateObject("WScript.Shell")
[51] oShell.CurrentDirectory = "\\adserv1\Software\adobe-updates\"
[52] errReturn = oShell.Run(strLaunchCmd,1,True)
[53] If errReturn = 0 Then
[54] objOutFile.WriteLine "Upgrade was successful. Upgraded from " & _
[55] objSoftware.Caption & vbTab & objSoftware.Version & " to version "
& strUpgrade
[56] Else
[57] objOutFile.WriteLine "Upgrade failed - Error #" & errReturn
[58] End If
[59] End Sub
[60] '-------------------
[61] 'Launch 9.1 Upgrades
[62] '-------------------
[63] Sub Upgrade91
[64] If InStr(objSoftware.Version,"9.1.0") <> 0 Then
[65] strLaunchCmd = "msiexec.exe /p
[66] End If
[67]
[68] If InStr(objSoftware.Caption,"Adobe Reader") <> 0 Then
[69] If InStr(1,objSoftware.Version,"9.") <> 0 And objSoftware.Version
<> "9.1.1" Then
[70] strLaunchCmd = "msiexec.exe /p
[71] strUpgrade = "Acrobat Reader 9.1.1"
[72] ElseIf InStr(1,objSoftware.Version,"8.") <> 0 And
[73] strLaunchCmd = "msiexec.exe /p
[74] strUpgrade = "Acrobat Reader 8.1.5"
[75] ElseIf InStr(1,objSoftware.Version,"7.") <> 0 And
[76] strLaunchCmd = "msiexec.exe /p
[77] strUpgrade = "Acrobat Reader 7.1.2"
[78] ElseIf InStr(1,objSoftware.Version,"6.0") <> 0 Then
[79] MsgBox "Please ask IT-Support to upgrade your Adobe Reader"
[80] End If
[81] End If
[82]
[83] errReturn = oShell.Run(strLaunchCmd,1,True)
[84] If errReturn = 0 Then
[85] objOutFile.WriteLine "Upgrade was successful. Upgraded from " & _
[86] objSoftware.Caption & vbTab & objSoftware.Version & " to version "
& strUpgrade
[87] Else
[88] objOutFile.WriteLine "Upgrade failed - Error #" & errReturn
[89] End If
[90] End Sub
Old 05-23-2009   #3 (permalink)
lyngsie
Thanks for your help. The final script became this:
Option Explicit
Dim objFSO , objFile, strLaunchCmd, objWMIService, colSoftware, objSoftware
Dim errReturn, strUpgrade, strComputer, strFilePath, objShell
' Setup log file ----------
strFilePath = "C:\Windows\system32\adobe_update.log"
'On Error Resume Next
If objFSO.FileExists(strFilePath) Then
Set objFile = objFSO.OpenTextFile(strFilePath, FOR_APPENDING)
Else
Set objFile = objFSO.CreateTextFile(strFilePath)
End If
Set objShell = CreateObject("WScript.Shell")
strLaunchCmd = "none"
CheckAcrobat
CheckReader
Next
Cleanup
End If
'Acrobat Upgrades
Sub CheckAcrobat
ElseIf InStr(1,objSoftware.Version,"8.") <> 0 And objSoftware.Version <>
"8.1.5" Then
ElseIf InStr(1,objSoftware.Version,"7.") <> 0 And objSoftware.Version <>
"7.1.2" Then
End If
UpgradeAdobe
'Upgrade 9.1.0 -> 9.1.1 .................
If InStr(1,objSoftware.Version,"9.1.0") Or strUpgrade = "Acrobat Pro 9.1.0"
Then
strUpgrade = "Acrobat 9.1.0 -> 9.1.1"
UpgradeAdobe
End If
End If
End Sub
'Check Reader
Sub CheckReader
If InStr(1,objSoftware.Version,"9.") <> 0 And objSoftware.Version <> "9.1.1"
Then
"8.1.5" Then
"7.1.2" Then
End If
UpgradeAdobe
End If
End Sub
'Upgrade Adobe Apps
Sub UpgradeAdobe
If strLaunchCmd <> "none" Then
objFile.WriteLine "Upgrade to " & strUpgrade & " " & "Started at: " & Date &
" : " & Time
errReturn = objShell.Run(strLaunchCmd,1,True)
objFile.WriteLine "Upgrade was successful. Upgraded from " & _
objSoftware.Caption & vbTab & "(v." & objSoftware.Version & ") " & " to
version " & strUpgrade
objFile.WriteLine "------------------------------------"
Else
objFile.WriteLine "Upgrade failed - Error #" & errReturn
End If
End If
End Sub
Sub Cleanup
objFile.Close
Set objFile = Nothing
Set objFSO = Nothing
Set objShell = Nothing
Set objWMIService = Nothing
End Sub
Quote:
> > Hi All,
> > it
> > problem.
> > CODE:
> > Dim objFSO
> > Dim objOutFile
> > Else
> > End If
> > strComputer = "."
> > End If
> > End If
> > ' Launch upgrades
> > strUpgrade
> > Else
> > End if
> > End If
> > <> "9.1.1" Then
> > End If
> > End If
> > strUpgrade
> > Else
> > End If
> > Next
> > End If
> [05]
> [08]
> [11] Else
> [13] End If
> [14]
> [19]
> [22] CheckAcrobat
> [23] LaunchUpgrades
> [24] Upgrade91
> [25] Next
> [26] End If
> [43] End If
> [44] End If
> [45] End Sub
> & strUpgrade
> [56] Else
> [58] End If
> [59] End Sub
> [63] Sub Upgrade91
> [66] End If
> [67]
> <> "9.1.1" Then
> [80] End If
> [81] End If
> [82]
> & strUpgrade
> [87] Else
> [89] End If
> [90] End Sub
Old 05-23-2009   #4 (permalink)
Pegasus [MVP]
news:EC35CF38-8A1D-429A-A82D-93D375BFC506@xxxxxx
I can see that you picked up my suggestion about giving your code a proper
structure. Unfortunately you chose to ignore my suggestion of indenting the
code, which would increase readability considerably. As a result you stepped
into a trap by adding one "endif" statement too many. You also invoke the
"UpgradeAdobe" subroutine twice, which is probably not what you intended.
About code indentation: This is your way of writing code -
CheckAcrobat
CheckReader
Next
Cleanup
End If
and this is my way:
CheckAcrobat
CheckReader
Next
Cleanup
End If
IMHO, code indentation gives you visual clues about the structure of the
code. Your way doesn't and it can lead to mistakes.
Old 05-25-2009   #5 (permalink)
Al Dunbar
"Pegasus [MVP]" <news@xxxxxx> wrote in message
news:u7dsNd82JHA.6004@xxxxxx
> the code, which would increase readability considerably. As a result you
> stepped into a trap by adding one "endif" statement too many. You also
> invoke the "UpgradeAdobe" subroutine twice, which is probably not what you
> intended.
> CheckAcrobat
> CheckReader
> Next
> Cleanup
> End If
> and this is my way:
> CheckAcrobat
> CheckReader
> Next
> Cleanup
> End If
Excellent advice, and certainly applicable to the OP's particular problem. I
would recommend indenting even the outermost elements, i.e.:
CheckAcrobat
CheckReader
Next
Cleanup
End If
This will make non-indented comment lines stand out a mile, and make
linewrapping more obvious when including code in a ng post.
There are a few other equally simple techniques that, when combined with
consistent indenting, can make code much easier to read and maintain:
- vertical white space (i.e. blank lines). These should be used to break
script into "paragraphs" of code.
- add comments that define the intent of the code rather than describing
what the code does, i.e. this:
' next item
count = count + 1
not this:
' add one to the counter:
count = count + 1
- avoid mixing executable statements and comments on one line.
- use meaningful variable names, and don't use one variable for two
different purposes.
/Al
Old 06-01-2009   #6 (permalink)
Petr Danes
My two cents worth on all this:
Lyngsie, I don't know if you picked up on it, but there is a HUGE difference
between
ELSEIF
and
ELSE IF (Extra spaces added to make the point clear)
This will work:
IF X then
Foo
ELSEIF Y then
Bar
END IF
This will not:
IF X then
Foo
ELSE IF Y then
Bar
END IF
The END IF is paired with the -second- IF, not the first IF, as it is in my
first example, and so the entire construct is unfinished, from the
interpreter's point of view. That's probably why you got your 'Unexpected
Next' error - the interpreter was looking for the closing END IF and
encountered the NEXT instead. The proper way to complete the second example
is like this:
IF X then
Foo
ELSE IF Y then
Bar
END IF
END IF
or better yet, from a formatting standpoint:
IF X then
Foo
ELSE
IF Y then
Bar
END IF
END IF
The first IF (with X) is paired with the second END IF, the second IF (with
Y) is paired with the first END IF. I didn't examine your initial script
very thoroughly, but am reacting to Pegasus' comment about having changed
such constructs in your script.
And obviously, proper indentation will help you keep track of such things,
as other responders here have pointed out.
Pete
"Al Dunbar" <alandrub@xxxxxx> píše v diskusním příspěvku
news:uJe89ba3JHA.1420@xxxxxx
>> proper structure. Unfortunately you chose to ignore my suggestion of
>> indenting the code, which would increase readability considerably. As a
>> result you stepped into a trap by adding one "endif" statement too many.
>> You also invoke the "UpgradeAdobe" subroutine twice, which is probably
>> CheckAcrobat
>> CheckReader
>> Next
>> Cleanup
>> End If
>> and this is my way:
>> CheckAcrobat
>> CheckReader
>> Next
>> Cleanup
>> End If
> I would recommend indenting even the outermost elements, i.e.:
> CheckAcrobat
> CheckReader
> Next
> Cleanup
> End If
> ' next item
> count = count + 1
> not this:
> count = count + 1
> different purposes.
> /Al
Anno 1404 "save/load" problem and using "runas.exe" Gaming
Vista "Sleep" and "Hibernate" problem General Discussion
Unwanted Multiple contacts in "To","CC","BCC" of email send catago Vista mail
New Problem - "From" Address format in "Microsoft Communities" Live Mail
Vista not wotking with "My Computer" or "Control Panel", "Screen Saver" Vista General
Š Designer Media Ltd
