Vista - how to schedule a job or run a script with elevated privleges?
Old 05-27-2009   #1 (permalink)
OldDog
I have a vbScript that checks Vista to insure that BitLocker is
installed. Works great.
However, I need to run this at least once a week on thousands of
computers. My problem
is that it requires elevated privleges to run. Any ideas on how to
Old 05-27-2009   #2 (permalink)
Pegasus [MVP]
Re: how to schedule a job or run a script with elevated privleges?
"OldDog" <mikef2691@xxxxxx> wrote in message
news:9220a8e0-6da9-4f51-8a23-07cba8e034ae@xxxxxx
Quote:
> Hi,
Elevated in comparison to what? If you use the Task Scheduler to run your
job then you can specify the account to be used.
Old 05-27-2009   #3 (permalink)
Richard Mueller [MVP]
Quote:
> Hi,
Some of the issues are discussed in this article:
http://msdn.microsoft.com/en-us/libr...99(VS.85).aspx
Note that UAC access token filtering does not affect domain accounts in the
local Administrators group. I think this means you can use WMI to connect
remotely and perform tasks requiring administrator privileges, as long as
your account is a member of Domain Admins (this group by default is added to
the local Administrators group when the computer is joined to the domain).
You could create a script to run remotely on all computers in an OU (or in a
group or all computers in the domain) in bulk using WMI. Or, such a script
could copy a program (that runs silently) to each computer, run it, and then
delete it.
Other options might be WSUS and Group Policy (perhaps a startup script).
Richard Mueller
MVP Directory Services
Hilltop Lab - http://www.rlmueller.net
Old 05-27-2009   #4 (permalink)
OldDog
On May 27, 5:01*pm, "Richard Mueller [MVP]" <rlmueller-
nos...@xxxxxx> wrote:
Quote:
> "OldDog" <mikef2...@xxxxxx> wrote in message
Quote:
> > Hi,
> your account is a member of Domain Admins (this group by default is addedto
> the local Administrators group when the computer is joined to the domain)..
> delete it.
> Richard Mueller
> Hilltop Lab -http://www.rlmueller.net
Thanks, guys. Vista spooks me.
OldDog
Schedule PowerShell script with Windows Server 2003 PowerShell
script in logon with elevated privileges enables PowerShell
How to schedule a Power Shell script PowerShell
Removing Elevated Privleges Vista security
How to schedule a Powershell script?? PowerShell
