Vista - boolean localization problem
Old 06-04-2009   #1 (permalink)
Heinz
I have found that on different languages the boolean value may differ (not
the value itself - but its string representation...)
For example the "IPEnabled" boolean value (see
http://msdn.microsoft.com/en-us/libr...17(VS.85).aspx ) :
On an english Windows installation the boolean value for "IPenabled" will
be given as a string : "true" / "false"
On a french Windows it will be "vrai" / "faux" ... and on a German Windows
"wahr" / "falsch" .... etc.
Is there a way to get a boolean value language independent (from the WMI
classes), so for example -1 / 0 instead of language dependent strings ?
Thank you
Old 06-04-2009   #2 (permalink)
ekkehard.horner
Re: boolean localization problem
Heinz schrieb:
Quote:
> Hi,
> Thank you
A boolean value is either True or False. The language specific
text representations are created when you cast/convert the boolean
value to a string
Quote:
Quote:
>> wscript.echo cstr(true)
Wahr
if you cast it - implicitly or explicitly - to a number, you'll get
0 resp. -1
Quote:
Quote:
>> wscript.echo True, False, CInt( True ), cInt( False )
-1 0 -1 0
As the strings are correct for informing a user and you don't need
conversions to use booleans in expression, I wonder why this is
a problem for you (just interested).
Old 06-04-2009   #3 (permalink)
Alex K. Angelopoulos
Heinz,
It really is a boolean. What you're seeing is an artifact of using MsgBox
for output display. MsgBox coerces certain data types to localized strings.
If you're worried about localization issues, I would avoid using MsgBox
unless really needed for actual _choices_ to be made. Instead, use
WScript.Echo.
If you do need to use MsgBox - or InputBox, it has the same issues - for
getting feedback from a user, coerce the value to an integer before
displaying it. The value will then be rendered as a number.
Demo code:
dim x: x = True
' The following shows the type name, vartype, and normal representation of
x:
' Boolean 11 -1
WScript.Echo "from WScript.Echo:", TypeName(x), VarType(x), x
' The following shows the localized string value for x:
MsgBox x
' which is equivalent to this:
WScript.Echo CStr(x)
' Since MsgBox is mangling it, no boolean coercion will help, no matter how
ridiculous:
MsgBox CBool(CBool(CBool(CBool(x))))
' This, however, does work: just turn it into an integer
MsgBox CInt(x)
' Note the same issues happen with InputBox:
InputBox "This is x as converted by InputBox automatically: " & x
InputBox "This is x pre-coerced to integer: " & CInt(x)
"Heinz" <no@xxxxxx> wrote in message
news:eyE5izO5JHA.1432@xxxxxx
Quote:
> Hi,
> Thank you
Old 06-04-2009   #4 (permalink)
ekkehard.horner
Alex K. Angelopoulos schrieb:
Quote:
> Heinz,
> MsgBox for output display. MsgBox coerces certain data types to
> localized strings.
I would avoid words like "artifact", "coerce", or "mangling". All
display functions dutifully convert the data to be shown to a (localized)
text representation (probably by using CStr() internally).
> WScript.Echo.
WScript.Echo behaves exactly like MsgBox; so why the "instead"? When
communicating with a user, using "True", "Wahr", or "vrai", ... seems
appropriate to me. That's why I don't like the next proposal at all.
Old 06-04-2009   #5 (permalink)
"ekkehard.horner" <ekkehard.horner@xxxxxx> wrote in message
news:4a27a45b$0$32663$9b4e6d93@xxxxxx-online.net...
Quote:
>> Heinz,
>> strings.
OK, artifact is a _bad_ word here; but not coerce. MsgBox really is coercing
the value to a string from what I can tell.
>> WScript.Echo.
Exactly?
x=true
WScript.Echo x
The reason I recommended the coercion wasn't because it's "always better",
but because Heinz wanted output that was in the form of -1/0 - and that gets
it for him.
Old 06-04-2009   #6 (permalink)
Heinz
"ekkehard.horner" <ekkehard.horner@xxxxxx> schrieb im Newsbeitrag
news:4a279578$0$32676$9b4e6d93@xxxxxx-online.net...
Quote:
> Heinz schrieb:
Quote:
>> Hi,
>> (not the value itself - but its string representation...)
>> will be given as a string : "true" / "false"
>> Windows "wahr" / "falsch" .... etc.
>> strings ?
>> Thank you
> value to a string
Quote:
> Wahr
> 0 resp. -1
Quote:
> -1 0 -1 0
the problem is (or was) that I write the result of a boolean variable like
"IPEnabled" to a textfile - so in the textfile I get either
true","false" - "wahr","falsch" - "vrai","faux" etc.
The problem starts when I read this textfile into an application and try to
determine whether this boolean was true or false...
But CInt(boolean) does the trick - instead of a text it writes "-1" or
"0" to the textfile (ok... this is a string, too.... but it is not language
dependent and I can convert it to a number :-)
Actually it is easy... seems that I had not enough breakfast coffee this
moring :-)
thank your for the help
Old 06-04-2009   #7 (permalink)
ekkehard.horner
Quote:
>>> Heinz,
>>> localized strings.
> coercing the value to a string from what I can tell.
My preference - "convert" - is based based on wishful thinking (see below),
but I still think, MsgBox does the right thing without unduly force to
represent a boolean by a (localized) "True" or "False".
Quote:
Quote:
>>> MsgBox unless really needed for actual _choices_ to be made. Instead,
>>> use WScript.Echo.
> Exactly?
> x=true
> WScript.Echo x
You are right. Having written tons of lines like
WScript.Echo Result, Expected, CStr( Result = Expected )
I should have known better. So I have to take back my "All display
functions ..." statement also. Some functions/subs - notably
WScript.Echo - misbehave.
Thanks for pointing out my mistake.
> better", but because Heinz wanted output that was in the form of -1/0 -
> and that gets it for him.
Quote:
>>> for getting feedback from a user, coerce the value to an integer
>>> before displaying it. The value will then be rendered as a number.
Old 06-04-2009   #8 (permalink)
Inline - you can sort of recant your mistake ; )
news:4a27b378$0$32674$9b4e6d93@xxxxxx-online.net...
>>>> Heinz,
>>>> localized strings.
>>> (localized)
> below),
Good point, actually. Probably the best word is "render" - nothing happens
to the underlying data, it's simply being rendered as a localized string -
like dates.
Quote:
>>>> use WScript.Echo.
>> Exactly?
>> x=true
>> WScript.Echo x
I changed my mind while you were posting. People tend to use WScript.Echo
like MsgBox, stringing together multiple elements with & - which gives us
the same behavior, two-state value rendered as a localized string
representation:
WScript.Echo true & vbNullString
Old 06-09-2009   #9 (permalink)
ekkehard.horner
Quote:
>> Heinz schrieb:
Quote:
>>> Hi,
or possibly to a boolean
Don't mention it; thank *you* for the feedback.
Old 06-09-2009   #10 (permalink)
ekkehard.horner
>>>>> Heinz,
>>>>> localized strings.
>>>> (localized)
>> below),
> happens to the underlying data, it's simply being rendered as a
> localized string - like dates.
I agree.
Quote:
>>>>> Instead, use WScript.Echo.
>>> Exactly?
>>> x=true
>>> WScript.Echo x
> WScript.Echo like MsgBox, stringing together multiple elements with & -
> which gives us the same behavior, two-state value rendered as a
> localized string representation:
So it's the concatenation that triggers the rendering. That means
you'll have to think about that when using Join too.
Thanks again for setting me straight.
When and how to set a boolean variable to true? .NET General
Boolean searchs in Photo Gallery? Vista file management
Is possible to Boolean filters like author AND NOT in Win Pictures Vista music pictures video
Any possibility for boolean operators in message rules? Vista mail
