Vista - how to calculate the system uptime
Old 06-08-2009   #1 (permalink)
Heinz
Hello,
I need a script that will calculate the system uptime.
I can get the LastRebootTime of a machine in "YYYYMMDDDHHMMSS" format using
the last "lastboottime" property from the Win32_OperatingSystem class.
My idea was to basically do something like "now() - lastbootime" using
DateDiff....
But it seems that it is not so easy to write some code to calculate the
uptime, because of different date\time formats used in different languages
For example
USA : 4/26/2009 9:36:04 PM
UK : 4/26/2009 21:36:04
France : 26/4/2009 21:36:04
Germany : 26.4.2009 21:36:04
etc.
I would need the calculate the uptime for all machines in minutes,
independent from local time setups
But with all the combinations of "." and "/" "AM/PM" and 24h formats I
keeping getting wrong results....
Maybe it would help if I could find out what date\time setup is used, for
example reading the settings from Controlpanel\RegionalSetting... so that I
could adapt the StringToDate() function in my code...?
Perfect would be solution that works with Win2000 and XP
This is the code that I am currently using (works for US... but not
neccessarily for other regional date\time settings...)
strComputer = "."
Set objWMIService = GetObject("winmgmts:{impersonationLevel=impersonate}!\\"
& strComputer & "\root\cimv2")
set colSettings = objWMIService.ExecQuery ("SELECT * FROM
Win32_OperatingSystem")
For Each objOperatingSystem in colSettings
str_LastBootupTime = objOperatingSystem.LastBootUpTime
' YYYYMMDDHHMMSS.milliseconds"
str_LastBootupTime = left (str_LastBootupTime,
instr(str_LastBootupTime,".")-1) ' remove milliseconds
date_LastBootupTime = StringToDate(str_LastBootupTime)
SystemUptime = DateDiff("n", date_lastBootUpTime, Now) 'difference
in Minutes
wscript.echo "Uptime in minutes=" & SystemUptime
next
Function StringToDate(LastBootUpTime)
'** Converts LastBootUpTime "YYYYMMDDHHMMSS" to "MM/DD/YYYY HH:MM:SS"
'** returns : DateTime format of "MM/DD/YYYY HH:MM:SS AM/PM"
StringToDate = _
CDate(Mid(LastBootUpTime, 5, 2) & "/" & _
Mid(LastBootUpTime, 7, 2) & "/" & _
Left(LastBootUpTime, 4) & " " & _
Mid (LastBootUpTime, 9, 2) & ":" & _
Mid(LastBootUpTime, 11, 2) & ":" & _
Mid(LastBootUpTime, 13, 2))
End Function
thank you
Heinz
Old 06-08-2009   #2 (permalink)
Pegasus [MVP]
Re: how to calculate the system uptime
"Heinz" <no@xxxxxx> wrote in message
news:%23EAAK5E6JHA.3640@xxxxxx
Quote:
> Hello,
> using the last "lastboottime" property from the Win32_OperatingSystem
> class.
> using DateDiff....
> For example
> etc.
> I keeping getting wrong results....
> I could adapt the StringToDate() function in my code...?
> strComputer = "."
> Set objWMIService =
> GetObject("winmgmts:{impersonationLevel=impersonate}!\\" & strComputer &
> "\root\cimv2")
> str_LastBootupTime = objOperatingSystem.LastBootUpTime '
> in Minutes
> next
> StringToDate = _
> End Function
> thank you
> Heinz
The problem occurs because you're using WMI to obtain the most recent boot
time and the inbuilt now() function to get the System Time. You can avoid
the issue by using WMI for both, e.g. like so:
strComputer = "."
Set objWMIService = GetObject("winmgmts:\\" & strComputer & "\root\cimv2")
Set colItems = objWMIService.ExecQuery("Select * From Win32_LocalTime")
For Each objItem in colItems
Wscript.Echo "Month: " & objItem.Month
Wscript.Echo "Day: " & objItem.Day
Wscript.Echo "Year: " & objItem.Year
Wscript.Echo "Hour: " & objItem.Hour
Wscript.Echo "Minute: " & objItem.Minute
Wscript.Echo "Second: " & objItem.Second
Next
(Code courtesy of the Scripting Guy)
Old 06-08-2009   #3 (permalink)
Heinz
"Pegasus [MVP]" <news@xxxxxx> schrieb im Newsbeitrag
news:ePzGnOF6JHA.3592@xxxxxx
Quote:
>> Hello,
>> class.
>> DateDiff....
>> languages
>> For example
>> etc.
>> strComputer = "."
>> Set objWMIService =
>> "\root\cimv2")
>> 'difference in Minutes
>> next
>> HH:MM:SS"
>> StringToDate = _
>> End Function
>> thank you
>> Heinz
> strComputer = "."
> Next
thank you for this interessting hint - I will try to puzzle it together :-)
thx
Heinz
Solved System Uptime Software
Longest System Uptime Overclocking & Cooling
Re: system health and uptime VB Script
Uptime Vista performance & maintenance
Uptime for the System Tutorials
