"James Whitlow" <jwhitlow.60372693@xxxxxx> wrote in message
news:%23eUaPBF6JHA.1420@xxxxxx
> I am looking for some resource, samples or guidance in reading data from
> Excel spreadsheets saved in XML format using VBScript, but using the
> 'MSXML.DOMDocument' object instead of the 'Excel.Application' object.
> My goal is to do my updating to the table in a nicely formatted Excel
> document instead of a unformatted CSV file, but have the script still work
> on computers that do not have Excel installed.
> I have quite limited experience with working with XML documents, so if
> someone has some simple examples they can post or link to that I could
> analyze and learn from, it would be greatly appreciated. I know almost nothing about XML documents or how that document might include
the Excel formatting. I would suggest groups.google.com; I would suggest
using it to search for msxml.domdocument in the microsoft.public ... xml
groups. One hit I found was
http://groups.google.com/g/85b7fefb/...5fe81604c15951
which might have helpful info.
There are a bunch of English language microsoft.public ... xml groups,
including:
microsoft.public.data.xmlanalysis
microsoft.public.dotnet.xml
microsoft.public.office.xml
microsoft.public.sqlserver.xml
microsoft.public.xml
On the main groups.google.com web page is a place to search for a group.
Enter something like the two words: microsoft xml to help you decide which
groups might be good candidates for crossposting your request. This returns
a nice list of group candidates, as well as some info on how frequently the
groups are used.
Use the search at msdn.microsoft.com, for something like: msxml.domdocument
reference, to find info that will be helpful in scripting the
msxml.domdocument object model.
-Paul Randall
