Vista - HELP! fileExist function always return 'FALSE'
Old 06-09-2009   #1 (permalink)
youu917
HI all,
I have a problem when trying to pass a string into the fileExist
function.
the code will get the filename from sql database, and pass into the
fileExist function.
then i use: filename=rs('field')
if fs.fileExist(filename) then
fs.Deletefile(filename)
end
I've tried to write out the filename, it show me a correct path and
filename to the path, whille i changed the filename to string "C:\path
\file" it works fine. however when i use a variable: filename, the
fileExist always return "false"
anyone can tell me how to solve the problem?
thank you.
Old 06-09-2009   #2 (permalink)
Pegasus [MVP]
Re: HELP! fileExist function always return 'FALSE'
<youu917@xxxxxx> wrote in message
news:afee6132-be4f-45c2-ae0d-94447793ef52@xxxxxx
Quote:
> HI all,
> function.
> fileExist function.
> end
> thank you.
Your code fragment looks like pseudo-code, not like the real thing. Is it
supposed to be VB Script? Let's have the actual fragment from your program!
Old 06-09-2009   #3 (permalink)
ekkehard.horner
youu917@xxxxxx schrieb:
Quote:
> HI all,
> function.
> fileExist function.
change this:
> end
to:
filename = rs( "field" )
MsgBox ">" & filename & "<"
If fs.FileExists( filename ) Then
fs.DeleteFile filename
End If
to check for whitespace. If there are leading or trailing blanks, use
filename = Trim( rs( "field" ) )
for other whitespace use (or ask for) a RegExp.
> thank you.
Old 06-09-2009   #4 (permalink)
Todd Vargo
"ekkehard.horner" <ekkehard.horner@xxxxxx> wrote in message
news:4a2e42fc$0$32676$9b4e6d93@xxxxxx-online.net...
Quote:
> > HI all,
> > function.
> > fileExist function.
> change this:
> > end
> to:
> End If
> > thank you.
Interestingly enough, I found that trailing white space does not matter but
leading white space does. Also, it seems the .FileExists method does not
like the filespec to be quoted.
filename = Trim(Replace(filename, Chr(34), ""))
Todd Vargo
(Post questions to group only. Remove "z" to email personal messages)
RegEx to return False if input is invalid. VB Script
Test-Path '' -IsValid does not return False but fails. Is this OK? PowerShell
How to return a specific type from a function PowerShell
return keyword in trap function PowerShell
Info: Can you Type a return from a function. PowerShell
