Vista - Policie not running exec files
Old 06-10-2009   #1 (permalink)
Omar Rodríguez
Hello,
I have a policie that run a vbs file (logon.vbs), the policie execute all
the commands but not run any exec files, do you have any idea abot how can I
fix it?
These are the lines that I am using:
Set WshShell = WScript.CreateObject("WScript.Shell")
WshShell.Run("""C:\Program Files\CounterPath\eyeBeam 1.5\eyeBeam.exe""")
I can run the script using double click without problems.
Any idea?
Thank you in advance.
Greetings,
Omar Rodríguez
Telecomunications Analyst & Programmer
VoiceTeam
WshShell.Exec workaround VB Script
Exec Method Puzzle VB Script
objshell.exec exit code VB Script
Hyper-V - Backup Exec VSS Warning Virtual Server
Can't exec a program from another Vista security
