Vista - Re: HELP: 5.01 - 5 = 9.9????
Old 06-11-2009   #1 (permalink)
ekkehard.horner
PadovaBoy (ovvero Giovanni) schrieb:
Quote:
> Hi at all.
> I have a "curious" problem with Asp classic (vbscript engine) in IIS6 (ms
> server 2003) ad IIS7 (ms vista):
> This is the test:
> dim a,b
> a = CDbl(5.01)
> b = CDbl(5.00)
> Response.Write a & " - "&b&" = "& ( a - b) & "<br>"
> c = CDbl ( a - b) 'another try..
> Response.Write c & "<br>"
> The results are:
> 5,01 - 5 = 9,99999999999979E-03
> Why? At my home 5.01 - 5 = 0.01 not 9,9...
> Tnx for any suggestions..
Two problems:
(1) the computer's numbers are different from the mathematical concept
of numbers. See (e.g.)
http://en.wikipedia.org/wiki/Floating_point
for the how and why. In your case the exact result 0.01 is approximated
by 9,99999999999979 * 10 ^ -3.
(2) use FormatNumber if you want to display numbers to the user
Quote:
Quote:
>> a = 5.01 : b = 5.0
>> wscript.echo typename(a), typename(b), a, b, a-b, formatnumber(a-b,6)
Double Double 5,01 5 9,99999999999979E-03 0,010000
Quote:
Quote:
>> wscript.echo 9.9 * 10 ^-3
0,0099
Quote:
Quote:
>> quit
