Vista - Forfiles command problem
Old 06-12-2009   #1 (permalink)
Admin
On win 2003 r2 We have an activity to move old files which are 2 year old
from E:\ Accounts directory to external USB drive partition F:\Accounts so
I have used below command to move
E:\Accounts>forfiles /s /m *.* /d -730 /c "cmd /c if @isdir==FALSE move
@path F:\Accounts".The files are moving but what was the folder structure is
there in E:\ Accounts its not creating and moving with same structure in
F:\Accounts simply moving all the files to F:\Accounts the problem is that
its over writing the files and for reference its not good.Please help me.
Old 06-12-2009   #2 (permalink)
Pegasus [MVP]
Re: Forfiles command problem
"Admin" <admin@xxxxxx> wrote in message
news:OD2F$qx6JHA.1432@xxxxxx
Quote:
> Hi,
> so I have used below command to move
> is there in E:\ Accounts its not creating and moving with same structure
> in F:\Accounts simply moving all the files to F:\Accounts the problem is
> that its over writing the files and for reference its not good.Please help
> me.
Nothing to do with VB Scripts - I recommend you repost in
alt.msdos.batch.nt.
Old 06-12-2009   #3 (permalink)
Admin
Could you provide the respective group link?
"Pegasus [MVP]" <news@xxxxxx> wrote in message
news:O1%23WMDy6JHA.1372@xxxxxx
Quote:
>> Hi,
>> help me.
> alt.msdos.batch.nt.
Old 06-12-2009   #4 (permalink)
Pegasus [MVP]
news:eX50AWy6JHA.4116@xxxxxx
Quote:
> Hi,
Google is your friend. Put the link I gave you in my first reply into a
Google search box and see what happens - like so:
"alt.msdos.batch.nt"
Run command problem in vbs VB Script
FORFILES Command VB Script
Re: Problem with Command Interpreter Vista General
Problem with get-command PowerShell
Forfiles question .NET General
