| | #11 (permalink) |
| | Re: Help with vbs script For the purpose of the academic discussion, mayayana I tested both of your suggestions. Neither works in this case. I beleive your code to be fully sound, the problem appears to be within Windows 7 not allowing access to these keys. |
| | #12 (permalink) |
| | Re: Help with vbs script Quote: > For the purpose of the academic discussion, mayayana I tested both of > your suggestions. Neither works in this case. I beleive your code to > be fully sound, the problem appears to be within Windows 7 not allowing > access to these keys. but actually I'm not surprised. I installed the 32-bit version. So the problem is probably with the 64-bit Registry rather than with any permission issues. Which might also explain what you're seeing. If it were a permissions problem you should be able to read all of HKLM, I think, but write to none of it. But with a 64-bit problem you might very well have the parent key present without the child key you're looking for, or vice versa, even though that result appears wrong. The Win64 Registry is a very funky thing. As I understand it, there are really two Registries, for all practical purposes. The 64-bit Registry is seen by 64-bit processes, while any 32-bit program gets silently dumped into the new "Wow6432Node" key, which is essentially the 32-bit Registry. So there can be both 32-bit and 64-bit programs running, and they're both actually accessing a different Registry! (One Registry tree in structure, but two Registries in practice.) With the API there seems to be a way for 32-bit software to override that problem. There's some info. here: http://msdn.microsoft.com/en-us/libr...29(VS.85).aspx Also, there's apparently a way using WMI to switch between 32-bit and 64-bit Registries, if desired. I don't have anything 64-bit to try it on, but it looks like it may be feasible to write a WMI test, running in a 32-bit process, that checks the keys of both Registries.... though it looks like a clunky solution: http://msdn.microsoft.com/en-us/libr...67(VS.85).aspx It's unfortunate that MS hasn't updated WScript.Shell for the 64-bit Registry, but word is that while WSH will be supported for the life of Win7, at least, no further updates are planned. |
| | #13 (permalink) |
| | Re: Help with vbs script Regretfully neither link seems to resolve the issue of reading these keys on Windows 7 x64, however I don't want to hijack the OPs thread. I'll continue to investigate and share results when I've made progress. |
| Logon Script Causing Laptops To Hang - Problems in script? | VB Script | |||
| problem passing args to script 'There is no script engine for file extenstion' | VB Script | |||
| Include another script, keep variables in included script? | PowerShell | |||
| Script file has 'OS Handle' error when run from script | PowerShell | |||
| Can you drag-n-drop a file on top of a PS script to run the script? | PowerShell | |||
