Vista Tutorial - Help with vbs script
Old 06-15-2009   #1 (permalink)
אמיר עטרי
Guest
Hello all
I am trying to write a vbs script.
The purpose of the script is to check if a GUID number is exist on the
registry.
if not, to install the an application and if Yes, to end.
Example:
If
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{388E4B09-3E71-4649-8921-F44A3A2954A7}
exsit then END
if not, install the application (in this case office VSTO).
Thank you very much for your help
Amir
Old 06-15-2009   #2 (permalink)
Pegasus [MVP]
Guest
Re: Help with vbs script
"???? ????" <@discussions.microsoft.com> wrote in message
news:2EEC4EC6-8D6B-4F5C-BBB4-B86CB1A2D0F4@xxxxxx
Quote:
> Hello all
> registry.
> Example:
> If
> exsit then END
> Amir
Since the installation of Office VSTO is most likely invoked via an
executable file, it would be simpler to run the whole process in batch file,
e.g. like so:
@echo off
if exist c:\installed.reg del c:\installed.reg
regedit /e c:\installed.reg
if exist c:\installed.reg (
goto :eof
e:\setup.exe [this is the Office VSTO installation program]
Old 06-15-2009   #3 (permalink)
אמיר עטרי
Guest
Hi there,
Thank you for your answer.
When you wrote: "if exist c:\installed.reg del c:\installed.reg"
Should i create first the installed.reg file and put it in c:\installed?
Should it contain the path to the guid?
Thanks gain.
Amir
Quote:
> > Hello all
> > registry.
> > Example:
> > If
> > exsit then END
> > Amir
> e.g. like so:
> @echo off
> goto :eof
Old 06-15-2009   #4 (permalink)
Pegasus [MVP]
Guest
No, you don't prepare anything. Just run the batch file as it is.
news:867DCF22-9F10-458F-BADC-B422CE30D9D7@xxxxxx
Quote:
> Hi there,
> Thanks gain.
> Amir
Quote:
>> > Hello all
>> > registry.
>> > Example:
>> > If
>> > exsit then END
>> > Amir
>> file,
>> e.g. like so:
>> @echo off
>> goto :eof
Old 07-01-2009   #5 (permalink)
Mark D. MacLachlan
Guest
Take a look at this Hey Scripting Guy:
http://www.microsoft.com/technet/scr...nda/oct04/hey1
029.mspx
One thing to mention though is that in my testing it does nto seem to
work on Windows 7. Not sure about Vista. I beleive this is a bug.
Hope that helps,
Mark D. MacLachlan
Old 07-01-2009   #6 (permalink)
PaulM
Guest
Are you talking about this script??
Const HKEY_LOCAL_MACHINE = &H80000002
strComputer = "."
Set objRegistry = GetObject("winmgmts:\\" & _
strComputer & "\root\default:StdRegProv")
strKeyPath = "SOFTWARE\Microsoft\Windows NT\CurrentVersion"
strValueName = "SystemRoot"
objRegistry.GetStringValue
HKEY_LOCAL_MACHINE,strKeyPath,strValueName,strValue
If IsNull(strValue) Then
Wscript.Echo "The registry key does not exist."
Else
Wscript.Echo "The registry key exists."
End If
It works fine in Windows 7.
Windows XP and Vista Tweaks
www.paulsxp.com
Windows XP and Vista Help Forum
www.paulsxp.com/forum
Live Computer Help and Chat
www.paulsxp.com/livesupport.html
"Mark D. MacLachlan" <markdmac@xxxxxx> wrote in message
news:e1iRgom#JHA.1376@xxxxxx
> 029.mspx
> Hope that helps,
> Mark D. MacLachlan
Old 07-02-2009   #7 (permalink)
Mark D. MacLachlan
Guest
Yes, I am indeed talking about that script. I agree it does work fine
for most registry reads, however it does not work (on my Windows 7 x64
system) when trying to read an Uninstall key down at the curly braces
level.
I am able to successfully read up to
SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall however trying to
read a value past that point failes. I would be greatful for someone
else to verify my findings by trying to read a path such as
90120000-002A-0000-1000-0000000FF1CE}
That is the path to the "Microsoft Office Office 64-bit Components
2007".
Code I am trying is:
Code:
strComputer = "."
strKeyPath = "SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall"
strValueName = "{90120000-002A-0000-1000-0000000FF1CE}"
Else
End If
The OP is trying to read such a value, so I think this script will
serve them well on an older OS but not Windows 7 unless someone can
confirm the problem is just on my side.
Regards,
Mark D. MacLachlan
Old 07-02-2009   #8 (permalink)
PaulM
Guest
I tried your script on windows 7, and you are right.
I added the key and the script run it said ,"The registry key does exists"
ever if the key is there.
www.paulsxp.com
news:eT5vAU1#JHA.1252@xxxxxx
> level.
> 2007".
Code:
> strComputer = "."
> Else
> End If
> Regards,
> Mark D. MacLachlan
Old 07-02-2009   #9 (permalink)
mayayana
Guest
A couple of other possibilities.... I haven't tried
these specifically on Win7, though:
If the check is local you can use WScript.Shell, which
is simpler than WMI:
Function Exists(RegPath)
Dim r
On Error Resume Next
r = SH.RegRead(RegPath) '--SH here is WScript.Shell object.
If Hex(Err.number) = "80070002" Then
Exists = False
Else
Exists = True
End If
End Function
If you have to use WMI it's awkward, but one way
is to call EnumKey on the parent key. If that succeeds
and the sought after key name is in the returned
array, then the key exists. Something like this:
Dim HKLM, Path, iRet, Reg, AKeys, sKey, i2, sErr
HKLM = &H80000002
sKey = "{388E4B09-3E71-4649-8921-F44A3A2954A7}"
Set Reg = GetObject("winMgMts:root\default:StdRegProv")
iRet = Reg.EnumKey(HKLM, Path, AKeys)
Select Case iRet
Case 0
If UBound(AKeys) = -1 Then
sErr = "no subkeys" 'no subkeys
Else
' There are subkeys to be checked.
End If
Case 2
sErr = "path invalid" '-- invalid key Path
Case -2147217405
sErr = "access denied" '-- access denied H80041003
Case Else
sErr = "Error number: " & iRet '-- some other error.
End Select
If Len(sErr) = 0 Then
For i2 = 0 to UBound(AKeys)
If UCase(AKeys(i2)) = UCase(sKey) Then
MsgBox "key exists"
Set Reg = Nothing
WScript.quit
End If
Next
End If
Set Reg = Nothing
MsgBox "Key does not exist. " & sErr
Old 07-03-2009   #10 (permalink)
Mark D. MacLachlan
Guest
> exists" ever if the key is there.
Thanks for confirming Paul. It is really strange how it will work
prior to that point but not further down the tree.
Logon Script Causing Laptops To Hang - Problems in script? VB Script
problem passing args to script 'There is no script engine for file extenstion' VB Script
Include another script, keep variables in included script? PowerShell
Script file has 'OS Handle' error when run from script PowerShell
Can you drag-n-drop a file on top of a PS script to run the script? PowerShell
Designer Media Ltd
