Vista - script for multi text replacement
Old 06-16-2009   #11 (permalink)
tonycd
Re: script for multi text replacement
Hi Pegasus
Thanks all. But i really don't know what Paul said. Tony
"Pegasus [MVP]" wrote:
Quote:
> I quote from Paul Randall's reply (which he copied from script56.chm):
> Optional. Number of substring substitutions to perform. If omitted, the
> default value is -1, which means make all possible substitutions. Must be
> used in conjunction with start.
> In other words, *all* matching strings will be replaced. Why don't you give
> it a try?
> "tonycd" <tonycd@xxxxxx> wrote in message
> news:44689407-F42D-4CA9-AC49-0B94B3DF877F@xxxxxx
Quote:
> > Hi Pegasus
> > thanks for your help again. As i mentioned before . i need to replace from
> > "event no." to "event description" from audit logon report. So more than
> > ten
> > "event no." that i need to replace. Would you please help ..Thanks
> > regards
> > Tony
Quote:
> >> Sorry, can't understand "What if i need to replace the text more than
> >> ten" -
> >> please rephrase.
> >> news:69C4CC27-9A58-41F3-830F-3FC5972B4F55@xxxxxx
> >> > Thanks all
> >> > What if i need to replace the text more than ten. Thanks again
> >> > regards
> >> > Tony
> >> >> news:74DABA76-6B73-4153-9926-2726ABF13D41@xxxxxx
> >> >> > Hi
> >> >> > I just copy the script from Microsoft web site that for replace the
> >> >> > text.
> >> >> > But how can i enhance the script for multi - text replacement.
> >> >> > Thanks
> >> >> > i try with this (i put the star in front of script) , but it doesn't
> >> >> > work.
> >> >> > regards
> >> >> > Tony
> >> >> > Const ForReading = 1
> >> >> > Const ForWriting = 2
> >> >> > Set objFSO = CreateObject("Scripting.FileSystemObject")
> >> >> > Set objFile = objFSO.OpenTextFile("C:\Scripts\Text.txt", ForReading)
> >> >> > strText = objFile.ReadAll
> >> >> > objFile.Close
> >> >> > strNewText = Replace(strText, "Jim ", "James ")
> >> >> > ****strNewText = Replace(strText, "abc ", "apple ")
> >> >> > Set objFile = objFSO.OpenTextFile("C:\Scripts\Text.txt", ForWriting)
> >> >> > objFile.WriteLine strNewText
> >> >> > objFile.Close
> >> >> You probably already have file script56.chm on your computer. If not,
> >> >> go
> >> >> to
> >> >> msdn.microsoft.com's download tab and search for and download it, and
> >> >> read
> >> >> up on the replace function.
> >> >> It says that there are potentially more parameters for the replace
> >> >> function:
> >> >> Replace Function
> >> >> See Also
> >> >> Filter Function
> >> >> Requirements
> >> >> Version 2
> >> >> Returns a string in which a specified substring has been replaced with
> >> >> another substring a specified number of times.
> >> >> Replace(expression, find, replacewith[, start[, count[, compare]]])
> >> >> Arguments
> >> >> expression
> >> >> Required. String expression containing substring to replace.
> >> >> find
> >> >> Required. Substring being searched for.
> >> >> replacewith
> >> >> Required. Replacement substring.
> >> >> start
> >> >> Optional. Position within expression where substring search is to
> >> >> begin.
> >> >> If
> >> >> omitted, 1 is assumed. Must be used in conjunction with count.
> >> >> count
> >> >> the
> >> >> be
> >> >> compare
> >> >> Optional. Numeric value indicating the kind of comparison to use when
> >> >> evaluating substrings. See Settings section for values. If omitted,
> >> >> the
> >> >> default value is 0, which means perform a binary comparison.
> >> >> -Paul Randall
Old 06-16-2009   #12 (permalink)
Al Dunbar
"ekkehard.horner" <ekkehard.horner@xxxxxx> wrote in message
news:4a368299$0$31864$9b4e6d93@xxxxxx-online.net...
Quote:
> tonycd schrieb:
> To make it easy to experiment with the aspects pointed out by
> the other contributors (and to add an array/loop based approach):
> demo script:
> Dim sSrc : sSrc = "one two three ONE TWO THREE one two three"
> Dim sTrg
<snip>
Quote:
> Dim aRpl( 1, 2 )
> Dim nRpl
> aRpl( 0, 0 ) = "one"
> aRpl( 1, 0 ) = "eins"
> aRpl( 0, 1 ) = "two"
> aRpl( 1, 1 ) = "zwei"
> aRpl( 0, 2 ) = "three"
> aRpl( 1, 2 ) = "drei"
> sTrg = sSrc
> For nRpl = 0 To UBound( aRpl, 2 )
> sTrg = Replace( sTrg, aRpl( 0, nRpl ), aRpl( 1, nRpl ) )
> Next
> WScript.Echo Join( Array( "looped repl, all, honor case", sSrc, sTrg,
> "" ), vbCrLf )
That is a definite improvement over a series of calls to the replace
function. But a dictionary object might be better suited for holding the
strings to be changed from/to than an array:
dim aRpl
ser aRpl = createobject("scripting.dictionary")
aRpl("one") = "eins"
aRpl("two") = "zwei"
aRpl("three") = "drei"
sTrg = sSrc
For each key in aRpl.keys
sTrg = Replace( sTrg, key, aRpl(key))
Next
/Al
<snip>
Old 06-16-2009   #13 (permalink)
Pegasus [MVP]
news:E33E0953-02A5-4E2B-A522-3D41161FD53B@xxxxxx
Quote:
> Hi Pegasus
Which part is it that you do not understand?
Old 06-16-2009   #14 (permalink)
tonycd
Thanks AI Dunbar
Would you please explain more. I really don't understand. Thanks
> > demo script:
> > Dim sTrg
> <snip>
Quote:
> > Dim aRpl( 1, 2 )
> > Dim nRpl
> > sTrg = sSrc
> > Next
> > "" ), vbCrLf )
> dim aRpl
> sTrg = sSrc
> Next
> /Al
> <snip>
Old 06-16-2009   #15 (permalink)
Paul Randall
Hi, Tony
Default securty has been increased with recent OSs and their service packs.
Now when you download help files like script56.chm, WXP very stupidly
displays the left pane properly and displays completely misleading
information in the right pane. There is nothing wrong with the file. The
OS just doesn't trust it. So right click the downloaded script56.chm and
choose properties.
Near the bottom of the properties window, you will probably see a Security
entry that says this file came from another computer and might be blocked to
help
protect this computer, followed by an "Unblock" button. After you click
the Unblock button and choose 'apply', this security info area is grayed out
or is removed. The help file should then open and display properly with no
questions asked.
-Paul Randall
newsEED1B89-C091-466C-90EE-F1D4E3D33F0A@xxxxxx
Quote:
> Thanks All
> I can't retrieve the script56.chm after download. (no contect at the right
> hand side).
> Would i use simple vbs instead as below. Thanks
> dim a
> dim b
> dim c
> document.write(Replace(a,"538","logoff"))
> document.write(Replace(b,"540","logon"))
> document.write(Replace(b,"528","logon"))
> "ekkehard.horner" wrote:
>> demo script:
>> Dim sTrg
>> ' Replace( expression, find, replacewith [, start (1) [, count (-1) [,
>> compare
>> (vbBinaryCompare) ) ] ] ] )
>> sTrg = Replace( sSrc, "one" , "eins" )
>> sTrg = Replace( sTrg, "two" , "zwei" )
>> sTrg = Replace( sTrg, "three", "drei" )
>> WScript.Echo Join( Array( "sequential repl, all, honor case", sSrc,
>> sTrg, "" ), vbCrLf )
>> sTrg = Replace( sSrc, "one" , "eins", 1, -1, vbTextCompare )
>> sTrg = Replace( sTrg, "two" , "zwei", 1, -1, vbTextCompare )
>> sTrg = Replace( sTrg, "three", "drei", 1, -1, vbTextCompare )
>> WScript.Echo Join( Array( "sequential repl, all, ignore case", sSrc,
>> sTrg = Replace( sSrc, "one" , "eins", 1, 1, vbBinaryCompare )
>> sTrg = Replace( sTrg, "two" , "zwei", 1, 1, vbBinaryCompare )
>> sTrg = Replace( sTrg, "three", "drei", 1, 1, vbBinaryCompare )
>> WScript.Echo Join( Array( "sequential repl, just one, ignore case",
>> sSrc, sTrg, "" ),
>> vbCrLf )
>> sTrg = Replace( Replace( Replace( sSrc, "one", "eins" ), "two",
>> "zwei" ), "three", "drei" )
>> WScript.Echo Join( Array( "nested repl, all, honor case", sSrc, sTrg,
>> "" ), vbCrLf )
>> sTrg = Replace( Replace( Replace( sSrc, "one", "eins", 1, 2,
>> vbTextCompare ), "two",
>> "zwei", 1, 2, vbTextCompare ), "three", "drei", 1, 2, vbTextCompare )
>> WScript.Echo Join( Array( "nested repl, just two, ignore case", sSrc,
>> Dim aRpl( 1, 2 )
>> Dim nRpl
>> sTrg = sSrc
>> Next
>> "" ), vbCrLf )
>> sTrg = sSrc
>> sTrg = Replace( sTrg, aRpl( 0, nRpl ), aRpl( 1, nRpl ), 1, -1,
>> vbTextCompare )
>> Next
>> WScript.Echo Join( Array( "looped repl, all, ignore case", sSrc, sTrg,
>> "" ), vbCrLf )
>> sTrg = replaceAll( sSrc, aRpl )
>> WScript.Echo Join( Array( "repl func, all, honor case", sSrc, sTrg,
>> "" ), vbCrLf )
>> sTrg = replaceAllP( sSrc, aRpl, 2, vbTextCompare )
>> WScript.Echo Join( Array( "repl func parm, just two, ignore case",
>> sSrc, sTrg, "" ),
>> vbCrLf )
>> sTrg = Replace( sSrc, "one" , "eins", 5, -1, vbTextCompare )
>> WScript.Echo Join( Array( "one repl, all, ignore case, starting at 5",
>> sSrc, sTrg, ""
>> ), vbCrLf )
>> Function replaceAll( sSrc, aRpl )
>> replaceAll = sSrc
>> Dim nRpl
>> replaceAll = Replace( replaceAll, aRpl( 0, nRpl ), aRpl( 1,
>> nRpl ) )
>> Next
>> End Function
>> Function replaceAllP( sSrc, aRpl, nCount, vbComp )
>> replaceAllP = sSrc
>> Dim nRpl
>> replaceAllP = Replace( replaceAllP, aRpl( 0, nRpl ), aRpl( 1,
>> nRpl ), 1, nCount,
>> vbComp )
>> Next
>> End Function
>> output:
>> === replDemo04: Replace Demo (04) =============================
>> eins zwei drei ONE TWO THREE eins zwei drei
>> eins zwei drei eins zwei drei eins zwei drei
>> eins zwei drei ONE TWO THREE one two three
>> eins zwei drei eins zwei drei one two three
>> two three eins TWO THREE eins two three
>> === replDemo04: 0 done (00:00:00) =============================
>> The last test case is included to show that using the start
>> parameter should be avoided in multi-text replacements.
Old 06-17-2009   #16 (permalink)
Al Dunbar
news:492FF849-8C13-4951-A9CE-4F9BD19D3624@xxxxxx
Quote:
> Thanks AI Dunbar
You're welcome.
The dictionary object is described in script56.chm and at the script center.
I'd suggest you read up n it and ask specific questions about its use here.
/Al
>> > demo script:
>> > Dim sTrg
>> <snip>
Quote:
>> > Dim aRpl( 1, 2 )
>> > Dim nRpl
>> > sTrg = sSrc
>> > Next
>> > "" ), vbCrLf )
>> dim aRpl
>> sTrg = sSrc
>> Next
>> /Al
>> <snip>
Old 06-21-2009   #17 (permalink)
tonycd
Thanks all. I put the replacement script inside the loop (someone taught me)
and it works.
regards
Tony
Quote:
> Hi, Tony
> choose properties.
> help
> questions asked.
> -Paul Randall
Quote:
> > Thanks All
> > hand side).
> > dim a
> > dim b
> > dim c
> >> demo script:
> >> Dim sTrg
> >> compare
> >> sSrc, sTrg, "" ),
> >> vbCrLf )
> >> "" ), vbCrLf )
> >> Dim aRpl( 1, 2 )
> >> Dim nRpl
> >> sTrg = sSrc
> >> Next
> >> "" ), vbCrLf )
> >> sTrg = sSrc
> >> vbTextCompare )
> >> Next
> >> "" ), vbCrLf )
> >> "" ), vbCrLf )
> >> sSrc, sTrg, "" ),
> >> vbCrLf )
> >> sSrc, sTrg, ""
> >> ), vbCrLf )
> >> replaceAll = sSrc
> >> Dim nRpl
> >> nRpl ) )
> >> Next
> >> End Function
> >> replaceAllP = sSrc
> >> Dim nRpl
> >> nRpl ), 1, nCount,
> >> vbComp )
> >> Next
> >> End Function
> >> output:
Vista Logon Script Replacement VB Script
VB Script that searches a file for different text, with an append. VB Script
output .ps1 script to text file PowerShell
Multi-line text becomes a one-liner PowerShell
Multi-task in script PowerShell
