| | script for multi text replacement Hi I just copy the script from Microsoft web site that for replace the text. But how can i enhance the script for multi - text replacement. Thanks i try with this (i put the star in front of script) , but it doesn't work. regards Tony Const ForReading = 1 Const ForWriting = 2 Set objFSO = CreateObject("Scripting.FileSystemObject") Set objFile = objFSO.OpenTextFile("C:\Scripts\Text.txt", ForReading) strText = objFile.ReadAll objFile.Close strNewText = Replace(strText, "Jim ", "James ") ****strNewText = Replace(strText, "abc ", "apple ") Set objFile = objFSO.OpenTextFile("C:\Scripts\Text.txt", ForWriting) objFile.WriteLine strNewText objFile.Close |
| | Re: script for multi text replacement "tonycd" <tonycd@xxxxxx> wrote in message news:74DABA76-6B73-4153-9926-2726ABF13D41@xxxxxx Quote: > Hi > > I just copy the script from Microsoft web site that for replace the text. > But how can i enhance the script for multi - text replacement. Thanks > i try with this (i put the star in front of script) , but it doesn't work. > > regards > Tony > > Const ForReading = 1 > Const ForWriting = 2 > > Set objFSO = CreateObject("Scripting.FileSystemObject") > Set objFile = objFSO.OpenTextFile("C:\Scripts\Text.txt", ForReading) > > strText = objFile.ReadAll > objFile.Close > strNewText = Replace(strText, "Jim ", "James ") > ****strNewText = Replace(strText, "abc ", "apple ") > > Set objFile = objFSO.OpenTextFile("C:\Scripts\Text.txt", ForWriting) > objFile.WriteLine strNewText > objFile.Close > > strNewText = Replace(Replace(strText, "Jim ", "James "), "abc", "apple") or even better: strNewText = Replace(Replace(strText, "Jim ", "James ",1,-1,1),"abc", "apple",1,-1,1) |
| | Re: script for multi text replacement On Jun 15, 6:53*am, tonycd <ton...@xxxxxx> wrote: Quote: > Hi > > I just copy the script from Microsoft web site that for replace the text. > But how can i enhance the script for multi - text replacement. Thanks > i try with this (i put the star in front of script) , but it doesn't work.. > > regards > Tony > > Const ForReading = 1 > Const ForWriting = 2 > > Set objFSO = CreateObject("Scripting.FileSystemObject") > Set objFile = objFSO.OpenTextFile("C:\Scripts\Text.txt", ForReading) > > strText = objFile.ReadAll > objFile.Close > strNewText = Replace(strText, "Jim ", "James ") > ****strNewText = Replace(strText, "abc ", "apple ") > > Set objFile = objFSO.OpenTextFile("C:\Scripts\Text.txt", ForWriting) > objFile.WriteLine strNewText > objFile.Close the version in the variable strText. It was changed and stored in strNewText by the first replacement, so in the second line the correct variable to work against is strNewText, as in ... strNewText = Replace(strText, "Jim ", "James ") ****strNewText = Replace(strNEWText, "abc ", "apple ") Tom Lavedas ************ |
| | Re: script for multi text replacement "tonycd" <tonycd@xxxxxx> wrote in message news:74DABA76-6B73-4153-9926-2726ABF13D41@xxxxxx Quote: > Hi > > I just copy the script from Microsoft web site that for replace the text. > But how can i enhance the script for multi - text replacement. Thanks > i try with this (i put the star in front of script) , but it doesn't work. > > regards > Tony > > Const ForReading = 1 > Const ForWriting = 2 > > Set objFSO = CreateObject("Scripting.FileSystemObject") > Set objFile = objFSO.OpenTextFile("C:\Scripts\Text.txt", ForReading) > > strText = objFile.ReadAll > objFile.Close > strNewText = Replace(strText, "Jim ", "James ") > ****strNewText = Replace(strText, "abc ", "apple ") > > Set objFile = objFSO.OpenTextFile("C:\Scripts\Text.txt", ForWriting) > objFile.WriteLine strNewText > objFile.Close msdn.microsoft.com's download tab and search for and download it, and read up on the replace function. It says that there are potentially more parameters for the replace function: Replace Function See Also Filter Function Requirements Version 2 Returns a string in which a specified substring has been replaced with another substring a specified number of times. Replace(expression, find, replacewith[, start[, count[, compare]]]) Arguments expression Required. String expression containing substring to replace. find Required. Substring being searched for. replacewith Required. Replacement substring. start Optional. Position within expression where substring search is to begin. If omitted, 1 is assumed. Must be used in conjunction with count. count Optional. Number of substring substitutions to perform. If omitted, the default value is -1, which means make all possible substitutions. Must be used in conjunction with start. compare Optional. Numeric value indicating the kind of comparison to use when evaluating substrings. See Settings section for values. If omitted, the default value is 0, which means perform a binary comparison. -Paul Randall |
| | Re: script for multi text replacement Thanks all What if i need to replace the text more than ten. Thanks again regards Tony "Paul Randall" wrote: Quote: > > "tonycd" <tonycd@xxxxxx> wrote in message > news:74DABA76-6B73-4153-9926-2726ABF13D41@xxxxxx Quote: > > Hi > > > > I just copy the script from Microsoft web site that for replace the text. > > But how can i enhance the script for multi - text replacement. Thanks > > i try with this (i put the star in front of script) , but it doesn't work. > > > > regards > > Tony > > > > Const ForReading = 1 > > Const ForWriting = 2 > > > > Set objFSO = CreateObject("Scripting.FileSystemObject") > > Set objFile = objFSO.OpenTextFile("C:\Scripts\Text.txt", ForReading) > > > > strText = objFile.ReadAll > > objFile.Close > > strNewText = Replace(strText, "Jim ", "James ") > > ****strNewText = Replace(strText, "abc ", "apple ") > > > > Set objFile = objFSO.OpenTextFile("C:\Scripts\Text.txt", ForWriting) > > objFile.WriteLine strNewText > > objFile.Close > You probably already have file script56.chm on your computer. If not, go to > msdn.microsoft.com's download tab and search for and download it, and read > up on the replace function. > > It says that there are potentially more parameters for the replace function: > Replace Function > See Also > Filter Function > Requirements > Version 2 > Returns a string in which a specified substring has been replaced with > another substring a specified number of times. > > Replace(expression, find, replacewith[, start[, count[, compare]]]) > Arguments > expression > Required. String expression containing substring to replace. > find > Required. Substring being searched for. > replacewith > Required. Replacement substring. > start > Optional. Position within expression where substring search is to begin. If > omitted, 1 is assumed. Must be used in conjunction with count. > count > Optional. Number of substring substitutions to perform. If omitted, the > default value is -1, which means make all possible substitutions. Must be > used in conjunction with start. > compare > Optional. Numeric value indicating the kind of comparison to use when > evaluating substrings. See Settings section for values. If omitted, the > default value is 0, which means perform a binary comparison. > > -Paul Randall > > > |
| | #6 (permalink) |
| | Re: script for multi text replacement Sorry, can't understand "What if i need to replace the text more than ten" - please rephrase. "tonycd" <tonycd@xxxxxx> wrote in message news:69C4CC27-9A58-41F3-830F-3FC5972B4F55@xxxxxx Quote: > Thanks all > > What if i need to replace the text more than ten. Thanks again > regards > Tony > > "Paul Randall" wrote: > Quote: >> >> "tonycd" <tonycd@xxxxxx> wrote in message >> news:74DABA76-6B73-4153-9926-2726ABF13D41@xxxxxx Quote: >> > Hi >> > >> > I just copy the script from Microsoft web site that for replace the >> > text. >> > But how can i enhance the script for multi - text replacement. Thanks >> > i try with this (i put the star in front of script) , but it doesn't >> > work. >> > >> > regards >> > Tony >> > >> > Const ForReading = 1 >> > Const ForWriting = 2 >> > >> > Set objFSO = CreateObject("Scripting.FileSystemObject") >> > Set objFile = objFSO.OpenTextFile("C:\Scripts\Text.txt", ForReading) >> > >> > strText = objFile.ReadAll >> > objFile.Close >> > strNewText = Replace(strText, "Jim ", "James ") >> > ****strNewText = Replace(strText, "abc ", "apple ") >> > >> > Set objFile = objFSO.OpenTextFile("C:\Scripts\Text.txt", ForWriting) >> > objFile.WriteLine strNewText >> > objFile.Close >> You probably already have file script56.chm on your computer. If not, go >> to >> msdn.microsoft.com's download tab and search for and download it, and >> read >> up on the replace function. >> >> It says that there are potentially more parameters for the replace >> function: >> Replace Function >> See Also >> Filter Function >> Requirements >> Version 2 >> Returns a string in which a specified substring has been replaced with >> another substring a specified number of times. >> >> Replace(expression, find, replacewith[, start[, count[, compare]]]) >> Arguments >> expression >> Required. String expression containing substring to replace. >> find >> Required. Substring being searched for. >> replacewith >> Required. Replacement substring. >> start >> Optional. Position within expression where substring search is to begin. >> If >> omitted, 1 is assumed. Must be used in conjunction with count. >> count >> Optional. Number of substring substitutions to perform. If omitted, the >> default value is -1, which means make all possible substitutions. Must be >> used in conjunction with start. >> compare >> Optional. Numeric value indicating the kind of comparison to use when >> evaluating substrings. See Settings section for values. If omitted, the >> default value is 0, which means perform a binary comparison. >> >> -Paul Randall >> >> >> |
| | #7 (permalink) |
| | Re: script for multi text replacement Hi Pegasus thanks for your help again. As i mentioned before . i need to replace from "event no." to "event description" from audit logon report. So more than ten "event no." that i need to replace. Would you please help ..Thanks regards Tony "Pegasus [MVP]" wrote: Quote: > Sorry, can't understand "What if i need to replace the text more than ten" - > please rephrase. > > > "tonycd" <tonycd@xxxxxx> wrote in message > news:69C4CC27-9A58-41F3-830F-3FC5972B4F55@xxxxxx Quote: > > Thanks all > > > > What if i need to replace the text more than ten. Thanks again > > regards > > Tony > > > > "Paul Randall" wrote: > > Quote: > >> > >> "tonycd" <tonycd@xxxxxx> wrote in message > >> news:74DABA76-6B73-4153-9926-2726ABF13D41@xxxxxx > >> > Hi > >> > > >> > I just copy the script from Microsoft web site that for replace the > >> > text. > >> > But how can i enhance the script for multi - text replacement. Thanks > >> > i try with this (i put the star in front of script) , but it doesn't > >> > work. > >> > > >> > regards > >> > Tony > >> > > >> > Const ForReading = 1 > >> > Const ForWriting = 2 > >> > > >> > Set objFSO = CreateObject("Scripting.FileSystemObject") > >> > Set objFile = objFSO.OpenTextFile("C:\Scripts\Text.txt", ForReading) > >> > > >> > strText = objFile.ReadAll > >> > objFile.Close > >> > strNewText = Replace(strText, "Jim ", "James ") > >> > ****strNewText = Replace(strText, "abc ", "apple ") > >> > > >> > Set objFile = objFSO.OpenTextFile("C:\Scripts\Text.txt", ForWriting) > >> > objFile.WriteLine strNewText > >> > objFile.Close > >> > >> You probably already have file script56.chm on your computer. If not, go > >> to > >> msdn.microsoft.com's download tab and search for and download it, and > >> read > >> up on the replace function. > >> > >> It says that there are potentially more parameters for the replace > >> function: > >> Replace Function > >> See Also > >> Filter Function > >> Requirements > >> Version 2 > >> Returns a string in which a specified substring has been replaced with > >> another substring a specified number of times. > >> > >> Replace(expression, find, replacewith[, start[, count[, compare]]]) > >> Arguments > >> expression > >> Required. String expression containing substring to replace. > >> find > >> Required. Substring being searched for. > >> replacewith > >> Required. Replacement substring. > >> start > >> Optional. Position within expression where substring search is to begin. > >> If > >> omitted, 1 is assumed. Must be used in conjunction with count. > >> count > >> Optional. Number of substring substitutions to perform. If omitted, the > >> default value is -1, which means make all possible substitutions. Must be > >> used in conjunction with start. > >> compare > >> Optional. Numeric value indicating the kind of comparison to use when > >> evaluating substrings. See Settings section for values. If omitted, the > >> default value is 0, which means perform a binary comparison. > >> > >> -Paul Randall > >> > >> > >> > > |
| | #8 (permalink) |
| | Re: script for multi text replacement I quote from Paul Randall's reply (which he copied from script56.chm): ================ Optional. Number of substring substitutions to perform. If omitted, the default value is -1, which means make all possible substitutions. Must be used in conjunction with start. ================ In other words, *all* matching strings will be replaced. Why don't you give it a try? "tonycd" <tonycd@xxxxxx> wrote in message news:44689407-F42D-4CA9-AC49-0B94B3DF877F@xxxxxx Quote: > Hi Pegasus > > thanks for your help again. As i mentioned before . i need to replace from > "event no." to "event description" from audit logon report. So more than > ten > "event no." that i need to replace. Would you please help ..Thanks > > regards > Tony > > "Pegasus [MVP]" wrote: > Quote: >> Sorry, can't understand "What if i need to replace the text more than >> ten" - >> please rephrase. >> >> >> "tonycd" <tonycd@xxxxxx> wrote in message >> news:69C4CC27-9A58-41F3-830F-3FC5972B4F55@xxxxxx Quote: >> > Thanks all >> > >> > What if i need to replace the text more than ten. Thanks again >> > regards >> > Tony >> > >> > "Paul Randall" wrote: >> > >> >> >> >> "tonycd" <tonycd@xxxxxx> wrote in message >> >> news:74DABA76-6B73-4153-9926-2726ABF13D41@xxxxxx >> >> > Hi >> >> > >> >> > I just copy the script from Microsoft web site that for replace the >> >> > text. >> >> > But how can i enhance the script for multi - text replacement. >> >> > Thanks >> >> > i try with this (i put the star in front of script) , but it doesn't >> >> > work. >> >> > >> >> > regards >> >> > Tony >> >> > >> >> > Const ForReading = 1 >> >> > Const ForWriting = 2 >> >> > >> >> > Set objFSO = CreateObject("Scripting.FileSystemObject") >> >> > Set objFile = objFSO.OpenTextFile("C:\Scripts\Text.txt", ForReading) >> >> > >> >> > strText = objFile.ReadAll >> >> > objFile.Close >> >> > strNewText = Replace(strText, "Jim ", "James ") >> >> > ****strNewText = Replace(strText, "abc ", "apple ") >> >> > >> >> > Set objFile = objFSO.OpenTextFile("C:\Scripts\Text.txt", ForWriting) >> >> > objFile.WriteLine strNewText >> >> > objFile.Close >> >> >> >> You probably already have file script56.chm on your computer. If not, >> >> go >> >> to >> >> msdn.microsoft.com's download tab and search for and download it, and >> >> read >> >> up on the replace function. >> >> >> >> It says that there are potentially more parameters for the replace >> >> function: >> >> Replace Function >> >> See Also >> >> Filter Function >> >> Requirements >> >> Version 2 >> >> Returns a string in which a specified substring has been replaced with >> >> another substring a specified number of times. >> >> >> >> Replace(expression, find, replacewith[, start[, count[, compare]]]) >> >> Arguments >> >> expression >> >> Required. String expression containing substring to replace. >> >> find >> >> Required. Substring being searched for. >> >> replacewith >> >> Required. Replacement substring. >> >> start >> >> Optional. Position within expression where substring search is to >> >> begin. >> >> If >> >> omitted, 1 is assumed. Must be used in conjunction with count. >> >> count >> >> Optional. Number of substring substitutions to perform. If omitted, >> >> the >> >> default value is -1, which means make all possible substitutions. Must >> >> be >> >> used in conjunction with start. >> >> compare >> >> Optional. Numeric value indicating the kind of comparison to use when >> >> evaluating substrings. See Settings section for values. If omitted, >> >> the >> >> default value is 0, which means perform a binary comparison. >> >> >> >> -Paul Randall >> >> >> >> >> >> >> >> |
| | #9 (permalink) |
| | Re: script for multi text replacement tonycd schrieb: [...] Quote: > But how can i enhance the script for multi - text replacement. To make it easy to experiment with the aspects pointed out by the other contributors (and to add an array/loop based approach): demo script: Dim sSrc : sSrc = "one two three ONE TWO THREE one two three" Dim sTrg ' Replace( expression, find, replacewith [, start (1) [, count (-1) [, compare (vbBinaryCompare) ) ] ] ] ) sTrg = Replace( sSrc, "one" , "eins" ) sTrg = Replace( sTrg, "two" , "zwei" ) sTrg = Replace( sTrg, "three", "drei" ) WScript.Echo Join( Array( "sequential repl, all, honor case", sSrc, sTrg, "" ), vbCrLf ) sTrg = Replace( sSrc, "one" , "eins", 1, -1, vbTextCompare ) sTrg = Replace( sTrg, "two" , "zwei", 1, -1, vbTextCompare ) sTrg = Replace( sTrg, "three", "drei", 1, -1, vbTextCompare ) WScript.Echo Join( Array( "sequential repl, all, ignore case", sSrc, sTrg, "" ), vbCrLf ) sTrg = Replace( sSrc, "one" , "eins", 1, 1, vbBinaryCompare ) sTrg = Replace( sTrg, "two" , "zwei", 1, 1, vbBinaryCompare ) sTrg = Replace( sTrg, "three", "drei", 1, 1, vbBinaryCompare ) WScript.Echo Join( Array( "sequential repl, just one, ignore case", sSrc, sTrg, "" ), vbCrLf ) sTrg = Replace( Replace( Replace( sSrc, "one", "eins" ), "two", "zwei" ), "three", "drei" ) WScript.Echo Join( Array( "nested repl, all, honor case", sSrc, sTrg, "" ), vbCrLf ) sTrg = Replace( Replace( Replace( sSrc, "one", "eins", 1, 2, vbTextCompare ), "two", "zwei", 1, 2, vbTextCompare ), "three", "drei", 1, 2, vbTextCompare ) WScript.Echo Join( Array( "nested repl, just two, ignore case", sSrc, sTrg, "" ), vbCrLf ) Dim aRpl( 1, 2 ) Dim nRpl aRpl( 0, 0 ) = "one" aRpl( 1, 0 ) = "eins" aRpl( 0, 1 ) = "two" aRpl( 1, 1 ) = "zwei" aRpl( 0, 2 ) = "three" aRpl( 1, 2 ) = "drei" sTrg = sSrc For nRpl = 0 To UBound( aRpl, 2 ) sTrg = Replace( sTrg, aRpl( 0, nRpl ), aRpl( 1, nRpl ) ) Next WScript.Echo Join( Array( "looped repl, all, honor case", sSrc, sTrg, "" ), vbCrLf ) sTrg = sSrc For nRpl = 0 To UBound( aRpl, 2 ) sTrg = Replace( sTrg, aRpl( 0, nRpl ), aRpl( 1, nRpl ), 1, -1, vbTextCompare ) Next WScript.Echo Join( Array( "looped repl, all, ignore case", sSrc, sTrg, "" ), vbCrLf ) sTrg = replaceAll( sSrc, aRpl ) WScript.Echo Join( Array( "repl func, all, honor case", sSrc, sTrg, "" ), vbCrLf ) sTrg = replaceAllP( sSrc, aRpl, 2, vbTextCompare ) WScript.Echo Join( Array( "repl func parm, just two, ignore case", sSrc, sTrg, "" ), vbCrLf ) sTrg = Replace( sSrc, "one" , "eins", 5, -1, vbTextCompare ) WScript.Echo Join( Array( "one repl, all, ignore case, starting at 5", sSrc, sTrg, "" ), vbCrLf ) Function replaceAll( sSrc, aRpl ) replaceAll = sSrc Dim nRpl For nRpl = 0 To UBound( aRpl, 2 ) replaceAll = Replace( replaceAll, aRpl( 0, nRpl ), aRpl( 1, nRpl ) ) Next End Function Function replaceAllP( sSrc, aRpl, nCount, vbComp ) replaceAllP = sSrc Dim nRpl For nRpl = 0 To UBound( aRpl, 2 ) replaceAllP = Replace( replaceAllP, aRpl( 0, nRpl ), aRpl( 1, nRpl ), 1, nCount, vbComp ) Next End Function output: === replDemo04: Replace Demo (04) ============================= sequential repl, all, honor case one two three ONE TWO THREE one two three eins zwei drei ONE TWO THREE eins zwei drei sequential repl, all, ignore case one two three ONE TWO THREE one two three eins zwei drei eins zwei drei eins zwei drei sequential repl, just one, ignore case one two three ONE TWO THREE one two three eins zwei drei ONE TWO THREE one two three nested repl, all, honor case one two three ONE TWO THREE one two three eins zwei drei ONE TWO THREE eins zwei drei nested repl, just two, ignore case one two three ONE TWO THREE one two three eins zwei drei eins zwei drei one two three looped repl, all, honor case one two three ONE TWO THREE one two three eins zwei drei ONE TWO THREE eins zwei drei looped repl, all, ignore case one two three ONE TWO THREE one two three eins zwei drei eins zwei drei eins zwei drei repl func, all, honor case one two three ONE TWO THREE one two three eins zwei drei ONE TWO THREE eins zwei drei repl func parm, just two, ignore case one two three ONE TWO THREE one two three eins zwei drei eins zwei drei one two three one repl, all, ignore case, starting at 5 one two three ONE TWO THREE one two three two three eins TWO THREE eins two three === replDemo04: 0 done (00:00:00) ============================= The last test case is included to show that using the start parameter should be avoided in multi-text replacements. |
| | #10 (permalink) |
| | Re: script for multi text replacement Thanks All I can't retrieve the script56.chm after download. (no contect at the right hand side). Would i use simple vbs instead as below. Thanks dim a dim b dim c document.write(Replace(a,"538","logoff")) document.write(Replace(b,"540","logon")) document.write(Replace(b,"528","logon")) "ekkehard.horner" wrote: Quote: > tonycd schrieb: > [...] Quote: > > But how can i enhance the script for multi - text replacement. > To make it easy to experiment with the aspects pointed out by > the other contributors (and to add an array/loop based approach): > > demo script: > > Dim sSrc : sSrc = "one two three ONE TWO THREE one two three" > Dim sTrg > > ' Replace( expression, find, replacewith [, start (1) [, count (-1) [, compare > (vbBinaryCompare) ) ] ] ] ) > > sTrg = Replace( sSrc, "one" , "eins" ) > sTrg = Replace( sTrg, "two" , "zwei" ) > sTrg = Replace( sTrg, "three", "drei" ) > WScript.Echo Join( Array( "sequential repl, all, honor case", sSrc, sTrg, "" ), vbCrLf ) > > sTrg = Replace( sSrc, "one" , "eins", 1, -1, vbTextCompare ) > sTrg = Replace( sTrg, "two" , "zwei", 1, -1, vbTextCompare ) > sTrg = Replace( sTrg, "three", "drei", 1, -1, vbTextCompare ) > WScript.Echo Join( Array( "sequential repl, all, ignore case", sSrc, sTrg, "" ), vbCrLf ) > > sTrg = Replace( sSrc, "one" , "eins", 1, 1, vbBinaryCompare ) > sTrg = Replace( sTrg, "two" , "zwei", 1, 1, vbBinaryCompare ) > sTrg = Replace( sTrg, "three", "drei", 1, 1, vbBinaryCompare ) > WScript.Echo Join( Array( "sequential repl, just one, ignore case", sSrc, sTrg, "" ), > vbCrLf ) > > sTrg = Replace( Replace( Replace( sSrc, "one", "eins" ), "two", "zwei" ), "three", "drei" ) > WScript.Echo Join( Array( "nested repl, all, honor case", sSrc, sTrg, "" ), vbCrLf ) > > sTrg = Replace( Replace( Replace( sSrc, "one", "eins", 1, 2, vbTextCompare ), "two", > "zwei", 1, 2, vbTextCompare ), "three", "drei", 1, 2, vbTextCompare ) > WScript.Echo Join( Array( "nested repl, just two, ignore case", sSrc, sTrg, "" ), vbCrLf ) > > Dim aRpl( 1, 2 ) > Dim nRpl > aRpl( 0, 0 ) = "one" > aRpl( 1, 0 ) = "eins" > aRpl( 0, 1 ) = "two" > aRpl( 1, 1 ) = "zwei" > aRpl( 0, 2 ) = "three" > aRpl( 1, 2 ) = "drei" > > sTrg = sSrc > For nRpl = 0 To UBound( aRpl, 2 ) > sTrg = Replace( sTrg, aRpl( 0, nRpl ), aRpl( 1, nRpl ) ) > Next > WScript.Echo Join( Array( "looped repl, all, honor case", sSrc, sTrg, "" ), vbCrLf ) > > sTrg = sSrc > For nRpl = 0 To UBound( aRpl, 2 ) > sTrg = Replace( sTrg, aRpl( 0, nRpl ), aRpl( 1, nRpl ), 1, -1, vbTextCompare ) > Next > WScript.Echo Join( Array( "looped repl, all, ignore case", sSrc, sTrg, "" ), vbCrLf ) > > sTrg = replaceAll( sSrc, aRpl ) > WScript.Echo Join( Array( "repl func, all, honor case", sSrc, sTrg, "" ), vbCrLf ) > > sTrg = replaceAllP( sSrc, aRpl, 2, vbTextCompare ) > WScript.Echo Join( Array( "repl func parm, just two, ignore case", sSrc, sTrg, "" ), > vbCrLf ) > > sTrg = Replace( sSrc, "one" , "eins", 5, -1, vbTextCompare ) > WScript.Echo Join( Array( "one repl, all, ignore case, starting at 5", sSrc, sTrg, "" > ), vbCrLf ) > > Function replaceAll( sSrc, aRpl ) > replaceAll = sSrc > Dim nRpl > For nRpl = 0 To UBound( aRpl, 2 ) > replaceAll = Replace( replaceAll, aRpl( 0, nRpl ), aRpl( 1, nRpl ) ) > Next > End Function > > Function replaceAllP( sSrc, aRpl, nCount, vbComp ) > replaceAllP = sSrc > Dim nRpl > For nRpl = 0 To UBound( aRpl, 2 ) > replaceAllP = Replace( replaceAllP, aRpl( 0, nRpl ), aRpl( 1, nRpl ), 1, nCount, > vbComp ) > Next > End Function > > output: > > === replDemo04: Replace Demo (04) ============================= > sequential repl, all, honor case > one two three ONE TWO THREE one two three > eins zwei drei ONE TWO THREE eins zwei drei > > sequential repl, all, ignore case > one two three ONE TWO THREE one two three > eins zwei drei eins zwei drei eins zwei drei > > sequential repl, just one, ignore case > one two three ONE TWO THREE one two three > eins zwei drei ONE TWO THREE one two three > > nested repl, all, honor case > one two three ONE TWO THREE one two three > eins zwei drei ONE TWO THREE eins zwei drei > > nested repl, just two, ignore case > one two three ONE TWO THREE one two three > eins zwei drei eins zwei drei one two three > > looped repl, all, honor case > one two three ONE TWO THREE one two three > eins zwei drei ONE TWO THREE eins zwei drei > > looped repl, all, ignore case > one two three ONE TWO THREE one two three > eins zwei drei eins zwei drei eins zwei drei > > repl func, all, honor case > one two three ONE TWO THREE one two three > eins zwei drei ONE TWO THREE eins zwei drei > > repl func parm, just two, ignore case > one two three ONE TWO THREE one two three > eins zwei drei eins zwei drei one two three > > one repl, all, ignore case, starting at 5 > one two three ONE TWO THREE one two three > two three eins TWO THREE eins two three > > === replDemo04: 0 done (00:00:00) ============================= > > The last test case is included to show that using the start > parameter should be avoided in multi-text replacements. > > |
| Vista Logon Script Replacement | VB Script | |||
| VB Script that searches a file for different text, with an append. | VB Script | |||
| output .ps1 script to text file | PowerShell | |||
| Multi-line text becomes a one-liner | PowerShell | |||
| Multi-task in script | PowerShell | |||
