Vista Tutorial - Delete Folders using WMI
Old 06-29-2009   #1 (permalink)
Babu VT
Guest
I'm trying to clean "$NTUninstall..." folders from remote machines and found
the below snippet useful.Unfortunately it isn't deleting any folders.Can
someone point me where is the fault... I can't use FSO objects since I need
to delete folders in multiple machines where C$ shares might not be
available.
strComputer ="."
Set objWMIService = GetObject("winmgmts:\\" & strComputer & "\root\cimv2")
strQueryString1 = "Select * from Win32_Directory where Name = '" &
OSRootDir & "'"
Set colSubfolders = objWMIService.ExecQuery (strQueryString1)
For Each objFolder in colSubfolders
If Instr( UCase(objFolder.Name), "$NTUNINSTALL" ) > 0 then
strReport = strReport & "Deleted :" & strcomputer & ":" & objFolder.Name
& " uninstall folder" & vbCrLf
objFolder.delete
End If
Next
Old 06-29-2009   #2 (permalink)
Pegasus [MVP]
Guest
Re: Delete Folders using WMI
"Babu VT" <babuvt@xxxxxx> wrote in message
news:uFeetFN%23JHA.1248@xxxxxx
Quote:
> Hi,
> found the below snippet useful.Unfortunately it isn't deleting any
> folders.Can someone point me where is the fault... I can't use FSO objects
> since I need to delete folders in multiple machines where C$ shares might
> not be available.
> strComputer ="."
> OSRootDir & "'"
> objFolder.delete
> End If
> Next
You need to assign a value to OSRootDir, e.g. "c:\\Windows". Alternatively
this Scripting Guy item might help:
How Can I Delete a Folder and All Its Subfolders?
http://www.microsoft.com/technet/scr...5/hey0405.mspx
Old 06-30-2009   #3 (permalink)
Mark D. MacLachlan
Guest
Babu VT wrote:
Quote:
> Hi,
> and found the below snippet useful.Unfortunately it isn't deleting
> any folders.Can someone point me where is the fault... I can't use
> FSO objects since I need to delete folders in multiple machines where
> C$ shares might not be available.
> strComputer ="."
> "\root\cimv2") strQueryString1 = "Select * from Win32_Directory where
> Name = '" & OSRootDir & "'" Set colSubfolders =
> objWMIService.ExecQuery (strQueryString1) For Each objFolder in
> colSubfolders If Instr( UCase(objFolder.Name), "$NTUNINSTALL" ) > 0
> then strReport = strReport & "Deleted :" & strcomputer & ":" &
> objFolder.Name & " uninstall folder" & vbCrLf objFolder.delete
> End If
> Next
Rather than just deleting the uninstalls, I prefer to check the age of
the folders just to be sure it is safe to remove them. That is why I
wrote the following which will only delete the folders if they are more
than 2 weeks old.
Code:
' NAME: CleanHotfixUninstalls.vbs
' AUTHOR: Mark D. MacLachlan , The Spider's Parlor
' URL   : http://www.thespidersparlor.com
' COPYRIGHT (c) 2008 All rights reserved
' DATE  : 05/07/2008
' COMMENT:
' This script will enumerate Uninstall folders under the Windows
directory
' and delete them if they are more than two weeks old
'    THIS CODE AND INFORMATION IS PROVIDED "AS IS" WITHOUT WARRANTY OF
'    ANY KIND, EITHER EXPRESSED OR IMPLIED, INCLUDING BUT NOT LIMITED TO
'    THE IMPLIED WARRANTIES OF MERCHANTABILITY AND/OR FITNESS FOR A
'    PARTICULAR PURPOSE.
'    IN NO EVENT SHALL THE SPIDER'S PARLOR AND/OR ITS RESPECTIVE
SUPPLIERS
'    BE LIABLE FOR ANY SPECIAL, INDIRECT OR CONSEQUENTIAL DAMAGES OR ANY
'    DAMAGES WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS,
'    WHETHER IN AN ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS
'    ACTION, ARISING OUT OF OR IN CONNECTION WITH THE USE OR PERFORMANCE
'    OF THIS CODE OR INFORMATION.
Dim fso, WshShell
Dim oFolder, oSubFolder
Set fso = CreateObject("Scripting.FileSystemObject")
Set WshShell=CreateObject("WScript.Shell")
WinDir = WshShell.ExpandEnvironmentStrings("%WinDir%")
Path = WinDir
Set oFolder = fso.GetFolder(Path)
Set colSubfolders = oFolder.Subfolders
For Each oSubfolder in colSubfolders
If Left(oSubFolder.Name,1) = "$" Then
If Right(oSubFolder.Name,1) = "$" Then
'If DateDiff("d", oSubFolder.DateCreated,Now) > 14 Then
fso.DeleteFolder(oSubFolder)
'End If
End If
End If
Next
Set oSubFolder = Nothing
Set oFolder = Nothing
Set fso = Nothing
Old 07-01-2009   #4 (permalink)
Mark D. MacLachlan
Guest
Just realized the posted version had the two week check commented out.
Code:
' DATE  : 05/07/2008
' COMMENT:
directory
SUPPLIERS
Dim fso, WshShell
Path = WinDir
End If
End If
End If
Next
Set fso = Nothing
Old 07-02-2009   #5 (permalink)
Mark D. MacLachlan
Guest
Sorry for the repost, but I noticed I had the date checks commented out
on the previously posted version.
Code:
' DATE  : 05/07/2008
' COMMENT:
directory
SUPPLIERS
Dim fso, WshShell
Path = WinDir
End If
End If
End If
Next
Set fso = Nothing
Can't delete folders Vista mail
is there a way to delete all the IE folders Network & Sharing
Cannot delete folders Vista General
Folders won't delete Vista file management
