Vista Tutorial - wshell.run path building help
Old 07-01-2009   #1 (permalink)
Gavaskar
Guest
Hello
I'm trying to run a program, lets use mspaint as an example.
I've got mspaint in the folder path
c:\Program Files\Company Name\Version-001\mspaint.exe
c:\Program Files\Company Name\Version-002\mspaint.exe
c:\Program Files\Company Name\Version-003\mspaint.exe
When I run the script, I query the file mspaint.exe for the version number,
so I know which one to execute, and I assign that version ID to a variable
VersionString.
The returned string will be "Version-001" or "Version-002" or "Version-003"
My problem is when I do a wshShell.run I'm having problems with the white
spaces and adding the variable.
Mypath = """c:\Program Files\Company Name\""" & VersionString &
"\mspaint.exe", 3, False
wshshell.run Mypath, 3, False
I always get a error message that it can not find the specified file
Any Ideas?
Old 07-01-2009   #2 (permalink)
James Whitlow
Guest
Re: wshell.run path building help
"Gavaskar" <nospam@xxxxxx> wrote in message
news:%23JEIlgo%23JHA.4900@xxxxxx
Quote:
> Hello
> number, so I know which one to execute, and I assign that version ID to a
> variable VersionString.
> "Version-003"
Change your 'Mypath' live to look like this:
Mypath = """c:\Program Files\Company Name\" & VersionString & _
"\mspaint.exe"""
You just needed to move the closing quotes for the command to the end of
'mspaint.exe' and remove the ',3, False' since that is part of your 'Run'
command and not part of the variable assignment.
Old 07-01-2009   #3 (permalink)
ekkehard.horner
Guest
Gavaskar schrieb:
Quote:
> Hello
> VersionString.
(1) The trailing '3, False' surely is a copy & paste artefact
(2) If you WScript.Echo Mypath it will look like
"c:\Program Files\Company Name\"Version-003\mspaint.exe
(3) So
Mypath = """c:\Program Files\Company Name\" & VersionString & "\mspaint.exe"""
> Any Ideas?
Old 07-01-2009   #4 (permalink)
Gavaskar
Guest
Re: wshell.run path building help - THANKYOU -
"James Whitlow" <jwhitlow.60372693@xxxxxx> wrote in message
news:eZnAFto%23JHA.3768@xxxxxx
Quote:
>> Hello
>> "Version-003"
> "\mspaint.exe"""
Building a PC Gaming
Building your own Rig General Discussion
BUG? (Test-Path $path -IsValid) and empty $path PowerShell
BUG/ANNOYANCE: PoSH autocompletes the full path rather than a minimal path PowerShell
