| | SQL connection issue Hi, Im trying to connect to a SQL server and instance in another domain. I need to authenticate using windows user account in the domain the SQL server is in but constantly get access denied errors. Connection string im using is : strSQLConnString = "Provider=SQLOLEDB.1;Data Source=SQLSERVER1,49168;Persist Security Info=False;Initial Catalog=" & strSQLDatabase & ";User ID=" & strDomain & "\" & strAdminUserName & ";Password=" & strPassword & ";" The error I get is : Login failed for user 'DOMAIN\USERACCOUNT'.. Error code : -2147217843 DOMAIN\USERACCOUNT has been substitutied for my actual domain and user account but you get the idea. Any help please? |
| | Re: SQL connection issue "Bukkake Face" <admin@xxxxxx> wrote in message news:2920a536-55eb-4d92-b471-1252e84c795a@xxxxxx Quote: > Hi, > > Im trying to connect to a SQL server and instance in another domain. > I > need to authenticate using windows user account in the domain the SQL > server is in but constantly get access denied errors. > > > Connection string im using is : > > > strSQLConnString = "Provider=SQLOLEDB.1;Data > Source=SQLSERVER1,49168;Persist Security Info=False;Initial Catalog=" > & strSQLDatabase & ";User ID=" & strDomain & "\" & strAdminUserName & > ";Password=" & strPassword & ";" > > > The error I get is : > > > Login failed for user 'DOMAIN\USERACCOUNT'.. Error code : -2147217843 > > > DOMAIN\USERACCOUNT has been substitutied for my actual domain and > user > account but you get the idea. > > > Any help please? http://www.connectionstrings.com/sql-server For SQL Server 2000 I see SQLOLEDB, but not SQLOLEDB.1. Also, if 49168 is a port number, should the data source be an IP address? I assume you are using the default instance. -- Richard Mueller MVP Directory Services Hilltop Lab - http://www.rlmueller.net -- |
| Connection issue after network connection | Network & Sharing | |||
| Connection Issue | Vista networking & sharing | |||
| Fixed! Remote Desktop Connection (RDC) SLOW/NO Connection Issue | Vista networking & sharing | |||
| Connection issue | Vista mail | |||
