Vista - Script to clean up Flash Player old files
Old 07-08-2009   #1 (permalink)
Rich
All my users Application Data folders are redirected to a file server.
Everyone has Flash installed in their IE, so when I do a robocopy every night
I end up copying all these pointless files back and forth between servers,
which makes the log files painfully hard to review when there are problems.
Is there a way in vbscript to have it delete all the files and folders under
the randomly generated name folders, as shown below. I substituted UserName
in the path below for what could really be one of a couple hundred user
names. The 6RS7BM4P could be any random grouping of letters and numbers also
from what I can tell.
d:\UserName\Application Data\Macromedia\Flash Player\
Player\#SharedObjects\
Player\#SharedObjects\6RS7BM4P\
Player\#SharedObjects\6RS7BM4P\anthropologie.com\
Player\#SharedObjects\6RS7BM4P\as1.suitesmart.com\
Player\#SharedObjects\6RS7BM4P\as1.suitesmart.com\_f5e.swf\
Player\#SharedObjects\6RS7BM4P\bannerfarm.ace.advertising.com\
Player\#SharedObjects\6RS7BM4P\bin.clearspring.com\
Player\#SharedObjects\6RS7BM4P\blip.tv\
Player\#SharedObjects\6RS7BM4P\cdn.widgetserver.com\
Player\#SharedObjects\6RS7BM4P\cdn1.eyewonder.com\
Player\#SharedObjects\6RS7BM4P\cdn4.specificclick.net\
Player\#SharedObjects\6RS7BM4P\cdn4.specificclick.net\img\
Player\#SharedObjects\6RS7BM4P\core.videoegg.com\
Player\#SharedObjects\6RS7BM4P\core.videoegg.com\#com\
Player\#SharedObjects\6RS7BM4P\core.videoegg.com\#com\videoegg\
Player\#SharedObjects\6RS7BM4P\core.videoegg.com\#ve\
Player\#SharedObjects\6RS7BM4P\farm.sproutbuilder.com\
Old 07-08-2009   #2 (permalink)
Pegasus [MVP]
Re: Script to clean up Flash Player old files
"Rich" <richjone@xxxxxx> wrote in message
news:FA8C7048-5E64-4B7E-8CC5-6EEDC83FA09C@xxxxxx
> night
> problems.
> under
> UserName
> also
Since you're already using robocopy.exe (which is a console command), it
would make sense to use other console commands to clean our your folders,
e.g. like so:
@echo off
set Folder=d:\UserName\Application Data\Macromedia\Flash
for /d %%a in ("%Folder%\*.*") do (
echo rd /s /q "%%a"
echo md "%%a"
robocopy ... ... ...
Remove the words "echo" in lines 4 and 5 to activate the batch file.
Old 07-08-2009   #3 (permalink)
Rich
Is there a smooth way to have it fill in the UserName in the path with the
actual names of the folders under the root level of d: ? or would i just
have to redo that little piece of code and hardcode the username in each time.
when i go into D, i have the following folders as example
Al
Bob
Charles
Derrick
Eric
etc etc...
> > night
> > problems.
> > under
> > UserName
> > also
> e.g. like so:
> @echo off
> echo rd /s /q "%%a"
> echo md "%%a"
Old 07-08-2009   #4 (permalink)
Pegasus [MVP]
news:82372F9E-F6DC-48DE-97D3-47E4126860BB@xxxxxx
> time.
> Al
> Bob
> Charles
> Derrick
> Eric
> etc etc...
Simple - you call the existing program once for each name, using exactly the
same code as you already have:
@echo off
for /d %%a in (d:\*.*) do call :Sub %%a
goto :eof
:Sub
set Folder=d:\%*\Application Data\Macromedia\Flash Player\#SharedObjects
for /d %%b in ("%Folder%\*.*") do (
echo rd /s /q "%%b"
echo md "%%b"
Old 07-08-2009   #5 (permalink)
mayayana
I delete the Macromedia folder itself whenever I see it.
As far as I know that folder is only for "super cookies" --
unauthorized, undisclosed large volume storage of data
by a website on the client machine.
But I don't actually have Flash installed myself, so I've
never investigated whether there could ever, possibly,
be something useful in those folders.
night
problems.
under
UserName
also
Old 07-09-2009   #6 (permalink)
Rich
Thanks Pegasus. I will give this a try! You're a genius.
> > time.
> > Al
> > Bob
> > Charles
> > Derrick
> > Eric
> > etc etc...
> @echo off
> goto :eof
> :Sub
> echo rd /s /q "%%b"
> echo md "%%b"
Old 07-09-2009   #7 (permalink)
Rich
Pretty nifty, it deletes the folder and all its subfolders, then recreates an
empty one with the same name.
I had to change the one line to read this though in order to get it to work,
does that sound right? i think it might have been getting the d: twice to
start off the value of the Folder variable.
set Folder=%*\Application Data\Macromedia\Flash Player\#SharedObjects
> > time.
> > Al
> > Bob
> > Charles
> > Derrick
> > Eric
> > etc etc...
> @echo off
> goto :eof
> :Sub
> echo rd /s /q "%%b"
> echo md "%%b"
Old 07-09-2009   #8 (permalink)
Pegasus [MVP]
Thanks for the feedback, and yes, your correction was approppriate - it
corrected an oversight on my part. You should also consider putting the
"robocopy" command into the main routine, just above the "goto :eof" line.
news:C5870350-E8B9-4D27-A705-E7038F985B30@xxxxxx
> an
> work,
>> > the
>> > just
>> > each
>> > time.
>> > Al
>> > Bob
>> > Charles
>> > Derrick
>> > Eric
>> > etc etc...
>> the
>> @echo off
>> goto :eof
>> :Sub
>> echo rd /s /q "%%b"
>> echo md "%%b"
Old 07-13-2009   #9 (permalink)
VISTA home prem 32bit SP2 --- XP Pro SP3 32bit
Old 07-13-2009   #10 (permalink)
Rich
very cool, thanks! even though i deleted the folders with this script, that
tool showed a bunch of stuff still stored. any idea where all those files or
data that tool shows is actually stored? in a file somewhere, the registry?
"pacinitaly" wrote:
Quote:
> 'Adobe - Flash Player : Settings Manager - Website Storage Settings
> panel'
> (http://www.macromedia.com/support/do...manager07.html)
> pacinitaly
> SpellCherkers aren't worth a shirt
Solved Clean your flash player stored stuff General Discussion
Install flash player (done! ) then java script..where..how?? Vista General
VBS SCRIPT to clean OLD FILE VB Script
[ann] add Flash to your script... VB Script
FLASH PLAYER Vista General
