| | Disconnecting (not disabling) a wifi connection Hi all I need to disconnect (not disable) any wifi connection at shutdown so it will start in an disconnected state at next logon. Is this possible with only vbs+wmi and not using any shell command like devcon.exe? Thanks in advance. Good to be back at these newsgroups, rusga PS: On Win XP Pro. |
| | Re: Disconnecting (not disabling) a wifi connection rusga wrote: Quote: > I need to disconnect (not disable) any wifi connection at shutdown so it > will start in an disconnected state at next logon. > If you don't mind messing with the registry, then you can "disable" your wireless software from initializing upon startup. Here is how it goes (this is from a win98 system, but the principal ought to be the same). For a linksys wireless card, you will find the startup utility in "RunServices", which calls for executing the wireless utility upon startup: [HKLM\Software\Microsoft\Windows\CurrentVersion\RunServices] "WMP54Gv4"="C:\\Program Files\\Linksys Wireless-G PCI Wireless Network Monitor\\WMP54Gv4.exe" Using the PCMag "StartCop" utility to disable this on startup, you get the above entry deleted, and a new entry (with the save value) placed in a new subkey "RunServices-", that is, an almost-the-same registry address, except for the "-" (minus) character at the end. After disabling, the registry looks like this: [HKLM\Software\Microsoft\Windows\CurrentVersion\RunServices-] "WMP54Gv4"="C:\\Program Files\\Linksys Wireless-G PCI Wireless Network Monitor\\WMP54Gv4.exe" In this configuration, the system does NOT run the wireless utility upon startup. To re-enable the wireless upon startup, just reverse the above change. Note that you don't necessarily have to use the "StartCop" approach, you could store your key/value pair anywhere, for example "saveWirelessKeyValue". Obviously your registry entries will be different, and probably your wireless utility too (unless you happen to have exactly the same wireless card as I do). However, I still claim that this technique ought to work, i.e., removing (and restoring) the wireless utility entry in the registry. cheers, jw ____________________________________________________________ You got questions? WE GOT ANSWERS!!! ..(but, no guarantee the answers will be applicable to the questions) |
| | Re: Disconnecting (not disabling) a wifi connection Hi mr_unreliable and thanks for your response. My remarks are inline. On Fri, 10 Jul 2009 17:30:10 +0100, mr_unreliable <kindlyReplyToNewsgroup@xxxxxx> wrote: Quote: > rusga wrote: Quote: >> I need to disconnect (not disable) any wifi connection at shutdown so >> it will start in an disconnected state at next logon. >> > hi Rusga, > > If you don't mind messing with the registry, then you can > "disable" your wireless software from initializing upon > startup. > - I'm not using any manufacturer's software, only the native windows service "Wireless Zero Configuration". Quote: > Here is how it goes (this is from a win98 system, but the > principal ought to be the same). For a linksys wireless > card, you will find the startup utility in "RunServices", > which calls for executing the wireless utility upon startup: > > [HKLM\Software\Microsoft\Windows\CurrentVersion\RunServices] > "WMP54Gv4"="C:\\Program Files\\Linksys Wireless-G PCI Wireless Network > Monitor\\WMP54Gv4.exe" > Quote: > Using the PCMag "StartCop" utility to disable this on > startup, you get the above entry deleted, and a new > entry (with the save value) placed in a new subkey > "RunServices-", that is, an almost-the-same registry > address, except for the "-" (minus) character at the end. > After disabling, the registry looks like this: > > [HKLM\Software\Microsoft\Windows\CurrentVersion\RunServices-] > "WMP54Gv4"="C:\\Program Files\\Linksys Wireless-G PCI Wireless Network > Monitor\\WMP54Gv4.exe" > It uses the same backup+delete approach. Quote: > In this configuration, the system does NOT run the wireless > utility upon startup. To re-enable the wireless upon startup, > just reverse the above change. Note that you don't necessarily > have to use the "StartCop" approach, you could store your > key/value pair anywhere, for example "saveWirelessKeyValue". > Quote: > Obviously your registry entries will be different, and probably > your wireless utility too (unless you happen to have exactly > the same wireless card as I do). > > However, I still claim that this technique ought to work, > i.e., removing (and restoring) the wireless utility entry > in the registry. > > cheers, jw > ____________________________________________________________ > > You got questions? WE GOT ANSWERS!!! ..(but, no guarantee > the answers will be applicable to the questions) You just gave me a new heading on how to try to solve this. Since it's a win service I'll try to tweek it using the registry. A simple stop/start to the service won't work because the service stores the state of the iface somewhere at the time it was shuted down and restores it at startup. So whenever I start the service the iface will imediately connect to where it was connected before (although the iface is in manual mode?!?). I guess MS considers this a MBIMTNTBUT - "Manual But Interrupted Mode That Needs To Be Un-manual'd Temporarily" mode. ;-) This approach by MS might be due to the fact that these portable things tend to standby or even hibernate interrupting process that need to be restored ASAP once "awakened". Anyway, you gave me a nice push on this. Thank you very much, rusga |
| WiFi Connection keeps dropping | Network & Sharing | |||
| WiFi looses connection | Drivers | |||
| VoIP is disconnecting my whole connection. | Network & Sharing | |||
| SP1 WiFi connection keeps getting disconnected | Vista networking & sharing | |||
| Automatic WiFi Connection | Vista networking & sharing | |||
