| | VBScript vs VBA for Outlook Project I'm doing a feasibility study to determine the if it makes sense to use automation to pull mailbox stats for our department. I've done several VBA projects so I'm familiar with VBA. I've spun up on CDO and written some code to pull sample data to see what we can do with it. The test code goes through 3000 mailitems in an EAS archive and dumps the values for 3 mapi and 10 outlook fields from each into Excel. If I can get the stats my manager wants, I'll use an ODBC connection to dump the data directly to a database table, essentially using VBA as the ETL language. (Does this sound strange at all?) The question is, can I accomplish the same thing with VBscript, or are there solid reasons to stick with VBA? For instance I'm using on error handling to test if the mapi field exists: On Error Resume Next Set CdoObjField = oMessage.Fields.Item(&H10820040) If Err <> 0 Then aryCdoActionDate(i) = Empty aryCdoActionFlag(i) = Empty Err.Clear From what I've read, VBScript can't do that, but there may be an alternate code, no? I'm also using arrays to store the data before dumping it to a spreadsheet. The code could just as easily write directly to the spreadsheet, and there doesn't seem to be a performance hit either way. Finally, I know how to access ODBC from VBA, and wonder if VBScript can do the same? Any comments are appreciated Thanks, Jake |
| | Re: VBScript vs VBA for Outlook Project Vbscript's error handling is not as flexible as VBA (it does manage "on error resume next", but can't do "on error goto...") If you have Excel and you're already familiar with VBA, it's hard to think of an argument to switch to vbscript, unless you just want the challenge of a different environment. Tim "JakeK" <JakeK@xxxxxx> wrote in message news:F4639782-D789-429A-8478-79746A8E3E96@xxxxxx Quote: > I'm doing a feasibility study to determine the if it makes sense to use > automation to pull mailbox stats for our department. I've done several > VBA > projects so I'm familiar with VBA. I've spun up on CDO and written some > code > to pull sample data to see what we can do with it. > > The test code goes through 3000 mailitems in an EAS archive and dumps the > values for 3 mapi and 10 outlook fields from each into Excel. If I can > get > the stats my manager wants, I'll use an ODBC connection to dump the data > directly to a database table, essentially using VBA as the ETL language. > (Does this sound strange at all?) > > The question is, can I accomplish the same thing with VBscript, or are > there > solid reasons to stick with VBA? For instance I'm using on error handling > to > test if the mapi field exists: > > On Error Resume Next > Set CdoObjField = oMessage.Fields.Item(&H10820040) > If Err <> 0 Then > aryCdoActionDate(i) = Empty > aryCdoActionFlag(i) = Empty > Err.Clear > > From what I've read, VBScript can't do that, but there may be an alternate > code, no? > > I'm also using arrays to store the data before dumping it to a > spreadsheet. > The code could just as easily write directly to the spreadsheet, and there > doesn't seem to be a performance hit either way. Finally, I know how to > access ODBC from VBA, and wonder if VBScript can do the same? > > Any comments are appreciated > > Thanks, > Jake |
| | Re: VBScript vs VBA for Outlook Project "JakeK" <JakeK@xxxxxx> wrote in message news:F4639782-D789-429A-8478-79746A8E3E96@xxxxxx Quote: > I'm doing a feasibility study to determine the if it makes sense to use > automation to pull mailbox stats for our department. I've done several > VBA > projects so I'm familiar with VBA. I've spun up on CDO and written some > code > to pull sample data to see what we can do with it. > > The test code goes through 3000 mailitems in an EAS archive and dumps the > values for 3 mapi and 10 outlook fields from each into Excel. If I can > get > the stats my manager wants, I'll use an ODBC connection to dump the data > directly to a database table, essentially using VBA as the ETL language. > (Does this sound strange at all?) > > The question is, can I accomplish the same thing with VBscript, or are > there > solid reasons to stick with VBA? For instance I'm using on error handling > to > test if the mapi field exists: > > On Error Resume Next > Set CdoObjField = oMessage.Fields.Item(&H10820040) > If Err <> 0 Then > aryCdoActionDate(i) = Empty > aryCdoActionFlag(i) = Empty > Err.Clear > > From what I've read, VBScript can't do that, but there may be an alternate > code, no? > > I'm also using arrays to store the data before dumping it to a > spreadsheet. > The code could just as easily write directly to the spreadsheet, and there > doesn't seem to be a performance hit either way. Finally, I know how to > access ODBC from VBA, and wonder if VBScript can do the same? > > Any comments are appreciated > > Thanks, > Jake write to MS Excel, write to databases, etc. in VBScript all the time. As noted, VBScript supports the Err object, "On Error Resume Next", and "On Error GoTo 0". You can connect to Excel with ODBC or Jet drivers and ADODB objects, but I use the Excel.Application object. You may be able to copy your code to a text file with *.vbs extension and run it as is. I run administrative scripts at a command prompt with the cscript host. This way I see all error messages and can redirect the output to a text file. An simple example VBScript program that writes to Excel: http://www.rlmueller.net/Write%20to%20Excel.htm And an old program I used to manage my Outlook inbox: http://www.rlmueller.net/DeleteSpam.htm An example VBScript program to create an Access table and add a record: ========== ' Specify path and file name. strPath = "C:\Scripts\MyDatabases" ' Connection string for MS Access database. strConnect = "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" _ & strPath & "\MyApplication.mdb" ' Connect to MS Access database. Set adoCommand = CreateObject("ADODB.Command") adoCommand.ActiveConnection = strConnect ' Drop table Customers if it exists. adoCommand.CommandText = "DROP TABLE Customers" On Error Resume Next adoCommand.Execute On Error GoTo 0 ' Create table Customers. adoCommand.CommandText = "CREATE TABLE Customers " _ & "(" _ & "CustomerID Integer NOT NULL, " _ & "CustomerName VARCHAR(30) NOT NULL, " _ & "CONSTRAINT CustomerID_pk " _ & "PRIMARY KEY (CustomerID)" _ & ")" adoCommand.Execute ' Add a record to table Customers. adoCommand.CommandText = "INSERT INTO Customers " _ & "(CustomerID, CustomerName) " _ & "VALUES(2031, 'ACME Industrial')" adoCommand.Execute -- Richard Mueller MVP Directory Services Hilltop Lab - http://www.rlmueller.net -- |
| | Re: VBScript vs VBA for Outlook Project Hi VBA is very focused on it's host applications and classes as a subset of VB and therefore mostly suited for this task. VBS is much more all-purpose, open and above all redistributable. I allmost consider it a "no strings attached" programming technology from MS. Rather rare. Hope it will stay that way for a long time. idle, rusga On Fri, 10 Jul 2009 23:24:01 +0100, JakeK <JakeK@xxxxxx> wrote: Quote: > I'm doing a feasibility study to determine the if it makes sense to use > automation to pull mailbox stats for our department. I've done several > VBA > projects so I'm familiar with VBA. I've spun up on CDO and written some > code > to pull sample data to see what we can do with it. > > The test code goes through 3000 mailitems in an EAS archive and dumps the > values for 3 mapi and 10 outlook fields from each into Excel. If I can > get > the stats my manager wants, I'll use an ODBC connection to dump the data > directly to a database table, essentially using VBA as the ETL language. > (Does this sound strange at all?) > > The question is, can I accomplish the same thing with VBscript, or are > there > solid reasons to stick with VBA? For instance I'm using on error > handling to > test if the mapi field exists: > > On Error Resume Next > Set CdoObjField = oMessage.Fields.Item(&H10820040) > If Err <> 0 Then > aryCdoActionDate(i) = Empty > aryCdoActionFlag(i) = Empty > Err.Clear > > From what I've read, VBScript can't do that, but there may be an > alternate > code, no? > > I'm also using arrays to store the data before dumping it to a > spreadsheet. > The code could just as easily write directly to the spreadsheet, and > there > doesn't seem to be a performance hit either way. Finally, I know how to > access ODBC from VBA, and wonder if VBScript can do the same? > > Any comments are appreciated > > Thanks, > Jake |
| | Re: VBScript vs VBA for Outlook Project Thanks Tim - That confirms my first impressions. "Tim Williams" wrote: Quote: > Vbscript's error handling is not as flexible as VBA (it does manage "on > error resume next", but can't do "on error goto...") > If you have Excel and you're already familiar with VBA, it's hard to think > of an argument to switch to vbscript, unless you just want the challenge of > a different environment. > > Tim |
| | #6 (permalink) |
| | Re: VBScript vs VBA for Outlook Project Richard, I reviewed the code below and your online examples. It looks like VBS could be made do a lot of the tasks, if we keep the code design simple and leave the data analysis for the DB application. Your suggestion about running the code at a command prompt is an especially helpful idea - I can test the ODBC TD connector if and when we get to that point. It will also help me to get familiar with scripting in general. Thanks. Jake Katz "Richard Mueller [MVP]" wrote: Quote: > > I don't use VBA, so I can't really compare. However, I read from Outlook, > write to MS Excel, write to databases, etc. in VBScript all the time. As > noted, VBScript supports the Err object, "On Error Resume Next", and "On > Error GoTo 0". You can connect to Excel with ODBC or Jet drivers and ADODB > objects, but I use the Excel.Application object. You may be able to copy > your code to a text file with *.vbs extension and run it as is. I run > administrative scripts at a command prompt with the cscript host. This way I > see all error messages and can redirect the output to a text file. > > An simple example VBScript program that writes to Excel: > > http://www.rlmueller.net/Write%20to%20Excel.htm > > And an old program I used to manage my Outlook inbox: > > http://www.rlmueller.net/DeleteSpam.htm > > An example VBScript program to create an Access table and add a record: > ========== > ' Specify path and file name. > strPath = "C:\Scripts\MyDatabases" > > ' Connection string for MS Access database. > strConnect = "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" _ > & strPath & "\MyApplication.mdb" > > ' Connect to MS Access database. > Set adoCommand = CreateObject("ADODB.Command") > adoCommand.ActiveConnection = strConnect > > ' Drop table Customers if it exists. > adoCommand.CommandText = "DROP TABLE Customers" > On Error Resume Next > adoCommand.Execute > On Error GoTo 0 > > ' Create table Customers. > adoCommand.CommandText = "CREATE TABLE Customers " _ > & "(" _ > & "CustomerID Integer NOT NULL, " _ > & "CustomerName VARCHAR(30) NOT NULL, " _ > & "CONSTRAINT CustomerID_pk " _ > & "PRIMARY KEY (CustomerID)" _ > & ")" > adoCommand.Execute > > ' Add a record to table Customers. > adoCommand.CommandText = "INSERT INTO Customers " _ > & "(CustomerID, CustomerName) " _ > & "VALUES(2031, 'ACME Industrial')" > adoCommand.Execute > > -- > Richard Mueller > MVP Directory Services > Hilltop Lab - http://www.rlmueller.net > -- > > > |
| Problem with VBScript, Outlook and line jumps | VB Script | |||
| Copy & paste from IE/FF into a new Outlook email via VBScript | VB Script | |||
| vbscript with outlook pst | VB Script | |||
| Re: vbscript - outlook address book issue | VB Script | |||
| In any project, Can't we refer classes directly, (without addingphysically in the project)? | .NET General | |||
