| | first time doing vbscript need help pls I have a Windows Script Host (xp pro service pack 3) that delete a file access 2000 without password but I get the message : Impossible read record. Autorization of read not avaiable for "MyTable"(this is my traduction) Code: 80040E09 I put "Everyone" group with full control policy but is just the same! Dim rst Dim strSQL Dim gdbConn strSQL = vbNullString strSQL = strSQL & "Delete from MyTable" ' etc... Call GetDataConnection() Set rst = gdbConn.Execute (strSQL) Set rst = Nothing Call CloseDataConnection() '=========================== Function GetDataConnection() '=========================== Dim strConn Set gdbConn = Nothing Set gdbConn = CreateObject("ADODB.Connection") gdbConn.Provider="Microsoft.Jet.OLEDB.4.0" strConn = "C:\Cancella\MyMDB.mdb" On Error Resume Next gdbConn.Open strConn If err.number <> 0 Then Msgbox err.description, vbExclamation+vbOkOnly, "Database Connection Error" End If Set GetDataConnection = gdbConn blnConnect = True End Function '======================== Sub CloseDataConnection() '======================== If Not(gdbConn Is Nothing) Then gdbConn.Close Set gdbConn = Nothing End If End Sub |
| | Re: first time doing vbscript need help pls "franco monte" <montefm@xxxxxx> wrote in message news:2dfff34e-8b4d-4d48-b09b-979e2c56ae0e@xxxxxx Quote: >I have a Windows Script Host (xp pro service pack 3) that delete a > file access 2000 without password but I get the message : > Impossible read record. Autorization of read not avaiable for > "MyTable"(this is my traduction) > Code: 80040E09 > I put "Everyone" group with full control policy but is just the same! > > > Dim rst > Dim strSQL > Dim gdbConn > strSQL = vbNullString > strSQL = strSQL & "Delete from MyTable" ' etc... > Call GetDataConnection() > Set rst = gdbConn.Execute (strSQL) > Set rst = Nothing > Call CloseDataConnection() > > '=========================== > Function GetDataConnection() > '=========================== > Dim strConn > > Set gdbConn = Nothing > Set gdbConn = CreateObject("ADODB.Connection") > gdbConn.Provider="Microsoft.Jet.OLEDB.4.0" > strConn = "C:\Cancella\MyMDB.mdb" > On Error Resume Next > gdbConn.Open strConn > If err.number <> 0 Then > Msgbox err.description, vbExclamation+vbOkOnly, "Database Connection > Error" > End If > > Set GetDataConnection = gdbConn > blnConnect = True > End Function > > '======================== > Sub CloseDataConnection() > '======================== > If Not(gdbConn Is Nothing) Then > gdbConn.Close > Set gdbConn = Nothing > End If > End Sub specify "Data Source=" in the connection string. I don't know if this will help in your case. For example: ========== ' Connection string for MS Access database. strConnect = "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" _ & "C:\Cancella\MyMDB.mdb" ' Connect to MS Access database. Set adoCommand = CreateObject("ADODB.Command") adoCommand.ActiveConnection = strConnect ' Modify table MyTable. adoCommand.CommandText = "DELETE FROM MyTable WHERE ..." adoCommand.Execute ========= Otherwise, you may lack permissions. You error message seems to indicate this. Can you open the database in MS Access by double-clicking on the *.mdb file? If so, can you modify the table? -- Richard Mueller MVP Directory Services Hilltop Lab - http://www.rlmueller.net -- |
| How to do No hang up VBScript (nohup for VBScript) | VB Script | |||
| Windows System Time and Desktop time not matching up | Vista General | |||
| Changing the time zone changes the appointment time in calendar | .NET General | |||
| Internet Time Synchronization Incorrect - Showing Standard Time | PowerShell | |||
| Demo of getting/setting time from an RFC867 time source | PowerShell | |||
