| | After script is complete, wait 15 minutes, then run again Thanks in advance, experts. I have a script that I would like to, whent he script has finished, it waits for 5 or 10 or 15 minutes, then runs it again, without setting up a scheduled task or processes - just built into the script somehow. Is that possible? Also, in a separate post I asked this question, but I'll add it here just in case. Is there a way to attempt moving a file, if there is an error it logs the error in a text file (already setup), but only attempts moving the file, or only logs the error a certain number of times, as to not fill the log with the same error multiple times? |
| | Re: After script is complete, wait 15 minutes, then run again "Robert Jacobs" <robertjacobsit@xxxxxx> wrote in message news:e1032554-0282-4a05-bd75-415c7048190b@xxxxxx Quote: > Thanks in advance, experts. > > I have a script that I would like to, whent he script has finished, it > waits for 5 or 10 or 15 minutes, then runs it again, without setting > up a scheduled task or processes - just built into the script > somehow. Is that possible? > > Also, in a separate post I asked this question, but I'll add it here > just in case. Is there a way to attempt moving a file, if there is an > error it logs the error in a text file (already setup), but only > attempts moving the file, or only logs the error a certain number of > times, as to not fill the log with the same error multiple times? Do MyScript wscript.sleep 5 * 60 * 1000 Loop sub MyScript {Your code goes here} end sub Your script will obviously run forever or until you break out of it. |
| | Re: After script is complete, wait 15 minutes, then run again On Jul 22, 11:13*am, "Pegasus [MVP]" <n...@xxxxxx> wrote: Quote: > "Robert Jacobs" <robertjacob...@xxxxxx> wrote in message > > news:e1032554-0282-4a05-bd75-415c7048190b@xxxxxx > Quote: > > Thanks in advance, experts. Quote: > > I have a script that I would like to, whent he script has finished, it > > waits for 5 or 10 or 15 minutes, then runs it again, without setting > > up a scheduled task or processes - just built into the script > > somehow. *Is that possible? Quote: > > Also, in a separate post I asked this question, but I'll add it here > > just in case. *Is there a way to attempt moving a file, if there is an > > error it logs the error in a text file (already setup), but only > > attempts moving the file, or only logs the error a certain number of > > times, as to not fill the log with the same error multiple times? > Here is the generic answer: > > Do > * * MyScript > * * wscript.sleep 5 * 60 * 1000 > Loop > > sub MyScript > * * {Your code goes here} > end sub > > Your script will obviously run forever or until you break out of it. |
| | Re: After script is complete, wait 15 minutes, then run again "Robert Jacobs" <robertjacobsit@xxxxxx> wrote in message news:f81615ca-5278-4649-92c4-85430337a88f@xxxxxx Thank you very much for your reply. I appreciate it. ========= Thanks for the feedback. |
| | Re: After script is complete, wait 15 minutes, then run again On Wed, 22 Jul 2009 19:27:10 GMT, Robert Jacobs wrote: Quote: > I mentioned that I didn't want to use a scheduled task, but thanks for > your reply. Pegasus' version worked just fine. -- I seem to have obtained a second shadow. |
| Script not waiting for previous command to complete | PowerShell | |||
| Script producing ""Not enough storage is available to complete..." | VB Script | |||
| Vista Offline Files Consuming 100% CPU for 2 minutes every few minutes | Vista General | |||
| Vista -- Completed print jobs wait in queue 2 minutes before clear | Vista print fax & scan | |||
| A click takes minutes to operate clicks too close cause long wait | Vista hardware & devices | |||
