| | IE8 problem with HTA I made the mistake of loading IE8 when I updated an old machine to XP a couple of weeks ago. Now an number of HTAs have failed and I can't figure out how I might be able to get them working again. It's probably a security thing, but here's hoping someone out there is able to shed some light. The problem arises with the use of an IFrame as a drop target for local files. The following approach used to allows dropped files to load in the frame. Then the path to that file could be retrieved with the location.href property in previous version of the mshta - before IE8. <html> <head> <!-- Mimic Internet Explorer 5 --> <meta http-equiv="X-UA-Compatible" content="IE=IE5" > <title>DandD Test</title> <script language=vbScript> sub GetDropPath if MyIFrame.document.readystate = "complete" then display MyIFrame.location.href end if end sub sub Display(sText) document.all.debug.insertAdjacentHTML "afterbegin", sText & "<br>" end sub </script> </head> <body> <iframe name=MyIFrame onreadystatechange=GetDropPath application="yes" style="height:400px;width:400px" src='about:<body title="Drop file here">File goes here</body>'> </iframe> <div id=debug></div> </body> </html> This little example just shows the problem. When run on systems with IE before 8, it displays the dropped content (say text and images - other files if the EditFlags registry setting is hacked) and its URL. Under IE8 it does not let the content load and the URL is always "about:blank", though it acts as if it is loading. I tried setting the compatibility mode to an earlier version, but it has no effect. Anyone got an idea? TIA, Tom Lavedas *********** |
| | Re: IE8 problem with HTA I don't know whether this will help, but you can try it if you don't get your code working. www.jsware.net/jsware/scripts.php5#picview I was making a thumbnail viewer recently for a friend and wanted actual drag-drop functionality for files and folders in an HTA. I decided to just make a small control for the job. (I don't understand why Microsoft never provided drag-drop, since HTAs bypass security restrictions anyway.) The control I ended up making is very basic. You assign an image of any size to it. The image can be designed to make the control into a button, or you can use something like a picture of a bucket, or anything else. The control auto-sizes to any image. When something is dropped an OnDrop event returns the path and whether it's a file or folder. There's also an onClick event and a tooltip property. That's about it. I just wanted something small, simple and flexible that would do the job. Quote: > I made the mistake of loading IE8 when I updated an old machine to XP > a couple of weeks ago. Now an number of HTAs have failed and I can't > figure out how I might be able to get them working again. It's > probably a security thing, but here's hoping someone out there is able > to shed some light. > > The problem arises with the use of an IFrame as a drop target for > local files. The following approach used to allows dropped files to > load in the frame. Then the path to that file could be retrieved with > the location.href property in previous version of the mshta - before > IE8. > > <html> > <head> > <!-- Mimic Internet Explorer 5 --> > <meta http-equiv="X-UA-Compatible" content="IE=IE5" > > <title>DandD Test</title> > > <script language=vbScript> > > sub GetDropPath > if MyIFrame.document.readystate = "complete" then > display MyIFrame.location.href > end if > end sub > > sub Display(sText) > document.all.debug.insertAdjacentHTML "afterbegin", sText & "<br>" > end sub > > </script> > > </head> > <body> > <iframe name=MyIFrame onreadystatechange=GetDropPath > application="yes" style="height:400px;width:400px" > src='about:<body title="Drop file here">File goes here</body>'> > </iframe> > <div id=debug></div> > </body> > </html> > > This little example just shows the problem. When run on systems with > IE before 8, it displays the dropped content (say text and images - > other files if the EditFlags registry setting is hacked) and its URL. > Under IE8 it does not let the content load and the URL is always > "about:blank", though it acts as if it is loading. > > I tried setting the compatibility mode to an earlier version, but it > has no effect. > > Anyone got an idea? > > TIA, > > Tom Lavedas > *********** |
| the problem with ndis.sys Blue Screen of Death problem solved? | Vista General | |||
| Re: Windows Mail Attachement Problem and Adobe Player Problem with IE8 | Vista mail | |||
| Multi-select problem in Windows Explorer BIG PROBLEM!!!!!! | Vista General | |||
| Generic McAfee Problem Message in Vista Problem Reports | Vista performance & maintenance | |||
| Vista Upgrade Problem - Windows Explorer Loop problem | Vista installation & setup | |||
