Vista - How to display a progress window
Old 07-24-2009   #1 (permalink)
Pascal Boivin
Hi
Is it possible to show a window from a VBScript? I would like to show
some status while the script is working. The script is run from WSH on
the command line.
Thanks
Sub BigProcess
Dim I
<Show a progess window> "Starting..."
For I = 1 To 100
Call DoSomething(I)
<Update the progress window> "Done: " & FormatNumber(I) & "%"
Next
<Close the progress window>
End Sub
Old 07-24-2009   #2 (permalink)
MikeB
Re: How to display a progress window
Maybe this will get you started:
<html>
<HEAD>
<TITLE>This is the Application Caption</TITLE>
<HTA:APPLICATION ID="oApp"
APPLICATIONNAME="Splash Screen"
BORDER="thick"
MAXIMIZEBUTTON="yes"
MINIMIZEBUTTON="yes"
CAPTION="YES"
ICON="C:\Program Files\RBTI\RBG7\Samples\Icons\win1.ico"
SHOWINTASKBAR="yes"
SINGLEINSTANCE="yes"
SYSMENU="yes"
WINDOWSTATE="normal">
<SCRIPT>
var cntr = 0;
var ID = 0;
function UpdateTimer()
cntr = cntr - 5000;
function UpdateProg()
//debugger;
//var IDtx;
if (ID <= 9)
document.getElementById('C' + ID.toString()).bgColor="blue";
//IDtx.bgcolor=blue;
ID++;
cntr = cntr-5000;
function init()
cntr = 30000;
UpdateProg();
var UpdateTime = window.setInterval('UpdateProg()',1000);
return;
function Terminate()
window.clearTimeout();
// window.close();
</SCRIPT>
</HEAD>
<body onload="init(); return false;" onUnload="Terminate(); return false;">
<table width="100%" cellpadding="0" cellspacing="0" hspace="0" vspace="0"
height=20>
<tr>
<td width="10%" bgcolor=white id="C0"></td>
<td width="10%" bgcolor=white id="C1"></td>
<td width="10%" bgcolor=white id="C2"></td>
<td width="10%" bgcolor=white id="C3"></td>
<td width="10%" bgcolor=white id="C4"></td>
<td width="10%" bgcolor=white id="C5"></td>
<td width="10%" bgcolor=white id="C6"></td>
<td width="10%" bgcolor=white id="C7"></td>
<td width="10%" bgcolor=white id="C8"></td>
<td width="10%" bgcolor=white id="C9"></td>
</tr>
</table>
</body>
</html>
"Pascal Boivin" <pascal.boivin@xxxxxx> wrote in message
news:xn0gd1c1l88e6w000@xxxxxx
Quote:
> Hi
> the command line.
> Thanks
> Sub BigProcess
> Dim I
> For I = 1 To 100
> Call DoSomething(I)
> Next
> End Sub
Old 07-24-2009   #3 (permalink)
Tom Lavedas
On Jul 24, 12:01*pm, "Pascal Boivin" <pascal.boi...@xxxxxx>
wrote:
Quote:
> Hi
> Is it possible to show a window from a VBScript? *I would like to show
> some status while the script is working. *The script is run from WSH on
> the command line.
> Thanks
> Sub BigProcess
> Dim I
> * <Show a progess window> "Starting..."
> * For I = 1 To 100
> * * Call DoSomething(I)
> * * <Update the progress window> "Done: " & FormatNumber(I) & "%"
> * Next
> * <Close the progress window>
> End Sub
Here's an example I had handy ...
Dim oIE, oPgCtl, i
Set oIE = CreateObject("InternetExplorer.Application")
oPgCtl = ProgressBar(oIE) ' Create control and return object array
' properties can be altered before revealing bar
' For example, ...
oPgCtl(0).max = 250
oIE.Visible = 1 ' Reveals the progress bar
' For example, write an initial message to Message Area
oPgCtl(1).innerHTML = "<font size=+1><b>Running ...</b></font>"
' Simulate a proccess delay & update progress bar
With oPgCtl(0) ' Progress bar
For i=.min to .max step 10 ' step changes progress bar increment
.value = CSng(i)
Wscript.sleep 100 ' process goes here
Next
End With
' For example, write closing message to Message Area
oPgCtl(1).innerHTML = "<font size=+1><b>Maximum reached: " _
& oPgCtl(0).value & "</b></font>"
wsh.sleep 2000 ' wait 2 seconds - just for demo
oIE.quit
' Requires "InternetExplorer.Application" object (oIE) input
' Returns two element array:
' element 0 is the Progress Bar control object - 5 properties
' .focus, .value, .min, .max, .appearance & .borderstyle
' element 1 is a message area to receive progress text (HTML)
Function ProgressBar(oIE)
Dim oPgCtl, h, w
With oIE
.RegisterAsDropTarget = False
.Resizable = 0 : addressbar = 0 : menubar = 0 : .toolbar = 0
.statusbar = 0
'.FullScreen = True ' removes "chrome", but don't use with IE7+
.Navigate "about:blank"
Do Until .ReadyState = 4 : WScript.Sleep 50 : Loop
.document.open
.document.write _
"<html><head><title>Progress</title></head>" _
& "<body bgcolor=silver scroll=no" _
& " style='border-Styleutset;border-Width:3px'><center>" _
& "<table bgcolor=lightskyblue width=100% height=100%>" _
& "<tr valign=middle><td align=center>Progress: &nbsp; <object "_
& "classid=""clsid:35053A22-8589-11D1-B16A-00C0F0283628"" " _
& "id=PrgBar height=20 width=500></object>" _
& "</td></tr><tr><td align=center id=amsg>&nbsp;" _
& "</td></tr></table></center></body></html>"
.document.close
.document.parentWindow.status = "Working"
with .document.parentwindow.screen
h = .availheight
w = .availwidth
end with
.height = h\8 : .width = 3 * (w\4)
.top = h\10 : .left = w\10
Set oPgCtl = .document.applets("PrgBar")
End with
' Bring progress bar to the front
CreateObject("Wscript.Shell").Appactivate "Progress"
With oPgCtl ' defaults - can be changed
.focus
.min = 0
.max = 100
.appearance = 1 'OR 0
.borderstyle = 0 'OR 1
End With
' Return references to the Progress Bar Control and the Message Area
Progressbar = Array(oPgCtl, oIE.document.all.amsg)
End Function
Old 07-24-2009   #4 (permalink)
Reventlov
Il giorno Fri, 24 Jul 2009 12:01:50 -0400, "Pascal Boivin"
>the command line.
In the command line you could put a colon every n files/data/arrays processed. Just to
show that something is happening.
My favourite method is as follows, but so far nobody in the newsgroup seemed to appreciate
it. Notice that your processing will start a lot before Merlin starts to prepare the magic
potion.
' File: Processing.vbs 22.1.2009
' Autore: Giovanni Cenati
'reventlov at katamail com
Dim Agent, Merlin,n,animation
Set Agent = CreateObject("Agent.Control.2")
Agent.Connected = true
Agent.Characters.Load "merlin", _
"c:\windows\msagent\chars\merlin.acs"
Set Merlin = Agent.Characters("merlin")
Merlin.Left = 0
Merlin.Top = 0
Merlin.Show
Merlin.MoveTo 220,240
merlin.play "domagic1"
merlin.play "domagic2"
merlin.play "confused"
merlin.play "announce" ' these conclude automatically
merlin.play "processing" 'this must be concluded with the stop method
msgbox "The actions are queued and the script arrives here before they are concluded.
Click OK to stop processing."
merlin.stop
merlin.play "read"
merlin.play "write"
merlin.play "search"
Merlin.Speak "Hello"
merlin.play "congratulate"
merlin.think "I think it works...."
merlin.listen true
merlin.play "wave"
Merlin.Hide
'This waits until all the actions are concluded (waits the Hide method)
'If you remove the sleep loop, the script does not wait for all
'the actions to be completed.
Do While Merlin.Visible: WScript.Sleep 10 : Loop
Agent.connected = false
Set Merlin = Nothing
Set Agent = Nothing
Giovanni Cenati (Bergamo, Italy)
Write to "Reventlov" at katamail com
http://digilander.libero.it/Cenati (Esempi e programmi in VbScript)
Old 07-24-2009   #5 (permalink)
Reventlov
>the command line.
Another method uses an IE window.
I'm very happy tonight because Mayayana solved my problem with vbs drag and drop registry
entries.
'*** Crea una finestra che funge da output ***
Dim myIE, IEWindow
Set myIE = CreateObject("InternetExplorer.Application")
myIE.Navigate "about:blank"
myIE.ToolBar = False:myIE.StatusBar = False:myIE.Resizable = False
Do
Loop While myIE.Busy
myIE.Width = 500:myIE.Height=500
myIE.Left = 50:myIE.Top = 50
myIE.Visible = True
myIE.document.writeln("<html><title>" & Title & "</title>"&_
"<body><div id='cont'></div></body></html>")
'myIE.Document.title= Title
Set IEWindow = myIE.Document.All("cont")
IEWindow.INNERHTML = "<h1>This is only the beginning"
wscript.sleep 3000 'processing here
IEWindow.INNERHTML = "<h1>Somethin happened"
Old 07-25-2009   #6 (permalink)
Tom Lavedas
On Jul 24, 4:24*pm, no...@xxxxxx (Reventlov) wrote:
> >the command line.
> potion.
> ' File: * *Processing.vbs 22.1.2009
> ' Autore: *Giovanni Cenati
> * "c:\windows\msagent\chars\merlin.acs"
> Merlin.Left = 0
> Merlin.Top = 0
> Merlin.Show
> merlin.stop
> merlin.play "read"
> merlin.play "write"
> merlin.listen true
> merlin.play "wave"
> Merlin.Hide
> Set Agent = Nothing
> Write to "Reventlov" at katamail comhttp://digilander.libero.it/Cenati(Esempi e programmi in VbScript)
I love it. I've looked at MSAgents in the bast, but never could get
into them. For one thing, I feel their canned actions take too long,
so they can easily slow thing down - as your script illustrates -
though yours lays it on pretty thick ;-)
One small quibble I have is that I found the hard coding of the
SystemRoot to be problematic. The machine I am on was upgraded from
Win2K to XP so that its SystemRoot folder is not named Windows, but
rather the older WINNT. So, in cases like this, it's best to do
something like this instead ...
sSystemRoot = CreateObject("Wscript.shell")_
.Environment("PROCESS")("SYSTEMROOT")
sSystemRoot & "\msagent\chars\merlin.acs"
You also failed to mention the other 'official' MSAgent charaters
available for free download here: www.microsoft.com/products/msagent/main.aspx.
A google search will turn up a number of other places to get
characters.
Thanks for the chuckle,
Tom Lavedas
Old 07-27-2009   #7 (permalink)
Pascal Boivin
That's what I was looking for. Thanks!
Old 07-27-2009   #8 (permalink)
mayayana
Be sure you test that on any system where
you might be using it. The OBJECT tag references
a progress bar control from mscomctl.ocx. That
file comes with VB6. (It may also come with some
or all versions of MS Office. I don't know.) The
file requires a license. In other words, Tom Lavedas
has installed something that gives him a license to
use the Microsoft "common controls", so the progress
bar control works for him. But on PCs where that is not
the case the bar won't work. The file mscomctl.ocx
itself may not even be present.
With any commercial ActiveX controls -- including
those from Microsoft -- using them
will give you extra options but at the same time
limited support. If you want to use the "fancy" version
you might want to also have an IE-only version around
for scripts that need to run elsewhere than on your
own PC or controlled local network. On the other hand,
if you want a fancy version and don't mind needing to
install a control, there are also other options for various
types of progress bars.
Old 07-27-2009   #9 (permalink)
Tom Lavedas
On Jul 27, 9:36*am, "mayayana" <mayaXXy...@xxxxxx> wrote:
Quote:
> * *Be sure you test that on any system where
> * *With any commercial ActiveX controls -- including
Yes, you are exactly right, as I found out this weekend on a home
machine that does NOT have the necessary license rights. I had failed
to realize that fact when I found that sample in my archive of bits
and pieces (it's not something I actually use). I had thought it was
just a standard (but little used) IE control. As I recall, I adapted
it from a posting I saw in a news group, somewhere. I guess I need to
document that stuff better.
Tom Lavedas
Old 07-27-2009   #10 (permalink)
mayayana
Quote:
That stuff is like a child seeing a Christmas tree
with gifts, but through a window. There are so many
controls on the typical system but very few that
don't need a license. The only ones I can think of
offhand, other than 3rd-party controls that have to
be installed, are the basic IE controls and maybe a
couple of Active Desktop odds and ends like webvw.dll.
The IE controls were discontinued after Win98 1st,
I think: iemenu.ocx, ielabel.ocx, ietimer.ocx
They weren't all that great, anyway, but it's a shame
that they were removed. iemenu.ocx could show a
system menu.
Webvw.dll can be used to render thumbnails, but IE
with width and height spec-ed in an IMG tag does
just as well.
Progress window does not show Live Mail
No progress window in Send/Receive Live Mail
show progress window checking mail Live Mail
progress window Live Mail
Copying progress window disappeared Vista General
