Vista - Help with a HTA
Old 07-30-2009   #1 (permalink)
OldDog
Help with a HTA
I am trying to build an HTA that will Query an AD Group for it's
Common Name.
I have a list of groups and I would like the HTA to display the list
and then allow me to pick one and then run my query on this list. If I
just put one group name in the Body, it works.
So far I have this:
<html>
<head>
<title>Get ADSPath and OU From AD</title>
<HTA:APPLICATION
ID="objADSPath-OU"
APPLICATIONNAME="Get ADSPath and OU"
SCROLL="off"
SINGLEINSTANCE="yes"
Quote:
</head>
<script language="VBScript">
Sub Window_Onload
self.Focus()
self.ResizeTo 900,600
End Sub
Sub RunScript
On Error Resume Next
Const ADS_SCOPE_SUBTREE = 2
DNC = GetObject("LDAP://RootDSE").Get("defaultNamingContext")
Set objConnection = CreateObject("ADODB.Connection")
Set objCommand = CreateObject("ADODB.Command")
objConnection.Provider = "ADsDSOObject"
objConnection.Open "Active Directory Provider"
Set objCommand.ActiveConnection = objConnection
objCommand.Properties("Page Size") = 1
objCommand.Properties("Searchscope") = ADS_SCOPE_SUBTREE
If Trim(AD_Obj.Value) = "" Then
ADobj = "Administrator" : AD_Obj.Value = "Administrator"
Else
ADobj=Trim(AD_Obj.Value)
End If
objCommand.CommandText = "SELECT Adspath FROM 'LDAP://" & DNC & "'" &
_
" WHERE name='" & ADobj & "'" & " OR sAMAccountName='" & ADobj &
Set objRecordSet = objCommand.Execute
objRecordSet.MoveFirst
If Err <> 0 Then
If Err.Number = 3021 Then
TxtADSPath.Value = Trim(AD_Obj.Value) & " Not Found!!!"
Else
TxtADSPath.Value = Err.Number & " " & Err.Description
End If
txtou.Value = ""
Err.Clear
Exit Sub
End If
arrAD = Split(objRecordSet.Fields("AdsPath").Value, ",")
For i = 0 to Ubound(arrAD)
If InStr(arrAD(i), "OU=") Or InStr(arrAD(i), "LDAP://OU=") Then
iLength = Len(arrAD(i))
leading = iif(InStr(arrAD(i),"LDAP://OU="),10,3)
OULength = iLength - leading
OU = Right(arrAD(i), OULength)
Exit For
End If
Next
txtou.Value = OU
TxtADSPath.Value = objRecordSet.Fields("Adspath").Value
objRecordSet.MoveNext
Msgbox "Done"
End Sub
Function iif(cond,t,f)
If cond Then
iif = t
Else
iif = f
End If
End Function
</script>
<BODY>
AD Object
<input type="text" name="AD_Obj" size="30" value="dl zl crdm in house
marketing"><br>
AD Object
marketing"><br> <-- More Groups
AD Object
<input type="text" name="AD_Obj" size="30" value="dl zl crdm marketing
support"><br> <-- More Groups
<input type="button" value="Get AdsPath & OU" name="GetOUb"
onclick="RunScript"><p>
AdsPath
<input type="text" name="TxtADSPath" size="145" readonly><p>
OU
<input type="text" name="txtOU" size="20" readonly><p>
<input type="BUTTON" name="button1" value="Exit" onclick=self.close>
</BODY>
</html>
Old 07-30-2009   #2 (permalink)
MattW
Re: Help with a HTA
I had a similar issue earlier this week with user names listed in a
txt file, and Richard Mueller was able to provide me with the
following code to help, it should be interchangeable if you change the
Object Category and Class from User to Group.
Quote:
You must read the file of names in a loop, then for each name run the
ADO
query to find the user with the Common Name read from the file. This
involves nested loops. Also, you must concatenate the value of the
variable
strLine into the query string. Otherwise, you are searching for the
user
with Common Name "strLine". I have not tested, but I think the code
below
should work. Watch out for line wrapping:
Option Explicit
Dim strExcelPath, strFilePath, adoConnection, adoCommand, objRootDSE,
strDNSDomain
Dim strFilter, strQuery, adoRecordset, strDN, objExcel, objSheet, k,
objUser, objFSO
Dim objFile, strLine, intIndex
' Check for required arguments.
Const ForReading = 1
' Specify the text file of user names.
strFilePath = "c:\MyFolder\UserList.txt"
' Open the file for read access.
Set objFSO = CreateObject("Scripting.FileSystemObject")
Set objFile = objFSO.OpenTextFile(strFilePath, ForReading)
' Spreadsheet file to be created.
strExcelPath = "c:\myfolder\selectivelist.xls"
' Bind to Excel object.
Set objExcel = CreateObject("Excel.Application")
objExcel.Workbooks.Add
' Bind to worksheet.
Set objSheet = objExcel.ActiveWorkbook.Worksheets(1)
objSheet.Name = "Domain User"
objSheet.Cells(1, 1).Value = "User Distinguished Name"
' Use ADO to search the domain for all users.
Set adoConnection = CreateObject("ADODB.Connection")
Set adoCommand = CreateObject("ADODB.Command")
adoConnection.Provider = "ADsDSOOBject"
adoConnection.Open "Active Directory Provider"
Set adoCommand.ActiveConnection = adoConnection
' Determine the DNS domain from the RootDSE object.
Set objRootDSE = GetObject("LDAP://RootDSE")
strDNSDomain = objRootDSE.Get("defaultNamingContext")
adoCommand.Properties("Page Size") = 100
adoCommand.Properties("Timeout") = 30
adoCommand.Properties("Cache Results") = False
k = 2
' Read the text file of names.
Do Until objFile.AtEndOfStream
strLine = Trim(objFile.ReadLine)
' Skip blank lines.
If (strLine <> "") Then
strFilter = "(&(objectCategory=person)(objectClass=user)(cn="
strLine & "))"
strQuery = "<LDAP://" & strDNSDomain & ">;" & strFilter _
& ";distinguishedName;subtree"
adoCommand.CommandText = strQuery
' Enumerate all users. Write each user's Distinguished Name to
the
' spreadsheet.
Set adoRecordset = adoCommand.Execute
Do Until adoRecordset.EOF
strDN = adoRecordset.Fields("distinguishedName").Value
' Escape any forward slash characters, "/", with the
backslash
' escape character. All other characters that should be
escaped
are.
strDN = Replace(strDN, "/", "\/")
objSheet.Cells(k, 1).Value = strDN
k = k + 1
adoRecordset.MoveNext
Loop
adoRecordset.Close
End If
Loop
' Format the spreadsheet.
objSheet.Range("A1:A1").Font.Bold = True
objSheet.Select
objExcel.Columns(1).ColumnWidth = 80
' Save the spreadsheet.
objExcel.ActiveWorkbook.SaveAs strExcelPath
objExcel.ActiveWorkbook.Close
' Quit Excel.
objExcel.Application.Quit
' Clean up.
adoConnection.Close
objFile.Close
Set objFile = Nothing
Set objFSO = Nothing
Set objUser = Nothing
Set adoConnection = Nothing
Set adoCommand = Nothing
Set objRootDSE = Nothing
Set adoRecordset = Nothing
Set objSheet = Nothing
Set objExcel = Nothing
Wscript.Echo "Done"
Old 07-30-2009   #3 (permalink)
OldDog
Re: Help with a HTA
> ADO
> variable
> user
> below
> Option Explicit
> strDNSDomain
> objUser, objFSO
> k = 2
> * * strLine = Trim(objFile.ReadLine)
> * * ' Skip blank lines.
> * * If (strLine <> "") Then
> * * * * strFilter = "(&(objectCategory=person)(objectClass=user)(cn="
> strLine & "))"
> * * * * strQuery = "<LDAP://" & strDNSDomain & ">;" & strFilter_
> * * * * * * & ";distinguishedName;subtree"
> * * * * adoCommand.CommandText = strQuery
> * * * * ' Enumerate all users. Write each user's Distinguished Name to
> the
> * * * * ' spreadsheet.
> * * * * Set adoRecordset = adoCommand.Execute
> * * * * Do Until adoRecordset.EOF
> * * * * * * strDN = adoRecordset.Fields("distinguishedName").Value
> * * * * * * ' Escape any forward slash characters, "/", with the
> backslash
> * * * * * * ' escape character. All other characters that should be
> escaped
> are.
> * * * * * * strDN = Replace(strDN, "/", "\/")
> * * * * * * objSheet.Cells(k, 1).Value = strDN
> * * * * * * k = k + 1
> * * * * * * adoRecordset.MoveNext
> * * * * Loop
> * * * * adoRecordset.Close
> * * End If
> Loop
> objSheet.Select
> ' Quit Excel.
> ' Clean up.
> adoConnection.Close
> objFile.Close
> Wscript.Echo "Done"
Thank you, I did figure the HTA part out.
I found this on the Microsoft site:
'<------ HTA------>
<SCRIPT LANGUAGE="VBScript">
Sub RunScript
If ComputerOption(0).Checked Then
strComputer = ComputerOption(0).Value
End If
If ComputerOption(1).Checked Then
strComputer = ComputerOption(1).Value
End If
If ComputerOption(2).Checked Then
strComputer = ComputerOption(2).Value
End If
If ComputerOption(3).Checked Then
strComputer = ComputerOption(3).Value
End If
If strComputer = "" Then
Exit Sub
End If
Set objWMIService = GetObject _
("winmgmts:\\" & strComputer & "\root\cimv2")
Set colItems = objWMIService.ExecQuery _
("Select * From Win32_OperatingSystem")
For Each objItem in colItems
Msgbox objItem.Caption
Next
End Sub
Sub CancelScript
Self.Close()
End Sub
</SCRIPT>
<BODY>
<input type="radio" name="ComputerOption" value="atl-ws-01">CRESCJ1-
L8<BR>
<input type="radio" name="ComputerOption" value="atl-ws-02">ELIASD1-
D3<BR>
<input type="radio" name="ComputerOption" value="atl-ws-03">FANNIK1-
D2<BR>
<input type="radio" name="ComputerOption" value="atl-ws-04">FELKIM1-
D10<P>
<input id=runbutton class="button" type="button" value="Run Script"
name="ok_button"
onClick="RunScript">
&nbsp;&nbsp;&nbsp;
<input id=runbutton class="button" type="button" value="Cancel"
name="cancel_button"
onClick="CancelScript">
</BODY>
<----- End HTA------>
