Vista - Passing "| find" in command executed with EXEC method does not work
Old 08-04-2009   #1 (permalink)
Steve
If I try to pass "| find" command with psinfo, executed with the EXEC
method I get a syntax error from psinfo. If I take the EXACT command
and run it at the command prompt it works fine. Any thoughts on why
this does not work?
---------------begin code------------------
compName = "SERVER1"
var1 = "c:\catapult\pstools\psinfo applications -s \\" & compName & "
| find /V " & chr(34) & "Security Update" & chr(34) & " | find /V " &
chr(34) & "Update for Windows" & chr(34) & " | find /V " & chr(34) &
"Hotfix" & chr(34)
msgbox var1
var2 = ExecCmd(var1)
wscript.echo var2
Function ExecCmd(Command)
Dim oExec,WshShell, Line
Set WshShell = WScript.CreateObject("WScript.Shell")
Set oExec = WshShell.Exec(Command)
Line = ""
Do while oExec.Status <> 1
If not oExec.StdOut.AtEndOfStream Then
line = line & oExec.StdOut.ReadAll
End If
If not oExec.StdErr.AtEndOfStream Then
line = line & oExec.StdErr.ReadAll
End If
Loop
ExecCmd = Line
End Function
-------------end code-----------------
Thanks in advance,
Steve
Old 08-04-2009   #2 (permalink)
Tom Lavedas
Re: Passing "| find" in command executed with EXEC method does notwork
On Aug 4, 4:18*pm, Steve <collamp...@xxxxxx> wrote:
> method I get a syntax error from psinfo. *If I take the EXACT command
> and run it at the command prompt it works fine. *Any thoughts on why
> this does not work?
> chr(34) & "Update for Windows" *& chr(34) & " | find /V *" & chr(34) &
> "Hotfix" & chr(34)
> msgbox var1
> wscript.echo var2
> * * Dim oExec,WshShell, Line
> * * * * Set WshShell = WScript.CreateObject("WScript.Shell")
> * * * * Set oExec = WshShell.Exec(Command)
> * * * * Line = ""
> * * * * Do while oExec.Status <> 1
> * * * * * * * * If not oExec.StdOut.AtEndOfStream Then
> * * * * * * * * * * * * line = line & oExec.StdOut.ReadAll
> * * * * * * * * End If
> * * * * * * * * If not oExec.StdErr.AtEndOfStream Then
> * * * * * * * * * * * * line = line & oExec.StdErr.ReadAll
> * * * * Loop
> * * * * ExecCmd = Line
> End Function
> Thanks in advance,
> Steve
Piping is supported by the command processor, so it needs to be
invoked directly ...
Set oExec = WshShell.Exec("%comsoec /c " &Command)
Tom Lavedas
Old 08-04-2009   #3 (permalink)
Steve
> > this does not work?
> > "Hotfix" & chr(34)
> > msgbox var1
> > wscript.echo var2
> > * * * * Line = ""
> > * * * * Loop
> > End Function
Quote:
> > Thanks in advance,
> > Steve
> * * * * Set oExec = WshShell.Exec("%comsoec /c " &Command)
> Tom Lavedas
> ***********- Hide quoted text -
> - Show quoted text -
Thanks for the reply Tom. Forgive if this is a n00b question, but
what does "%comsoec /c" refer to in your post?
I appreciate your help.
Steve
Old 08-04-2009   #4 (permalink)
Pegasus [MVP]
Re: Passing "| find" in command executed with EXEC method does not work
"Steve" <collampton@xxxxxx> wrote in message
news:9c0ac0ef-217b-4831-b1da-e6f1ecf9bfde@xxxxxx
> this does not work?
> "Hotfix" & chr(34)
> msgbox var1
> wscript.echo var2
> Line = ""
> End If
> End If
> Loop
> ExecCmd = Line
> End Function
> Thanks in advance,
> Steve
Further to Tom's reply: Running a VB Script program and invoking find.exe
three times is not "nice". VB Script has its own "find" function (instr),
and using it would not only avoid your three pipes but it would also speed
up your script enormously. This may not matter much in this particular case
but it does when you invoke find.exe many times.
Old 08-04-2009   #5 (permalink)
Tom Lavedas
> > > this does not work?
> > > var1 = "c:\catapult\pstools\psinfo applications -s \\" & compName &"
> > > "Hotfix" & chr(34)
> > > msgbox var1
> > > wscript.echo var2
> > > * * * * Line = ""
> > > * * * * * * * * * * * * line = line & oExec..StdOut.ReadAll
> > > * * * * * * * * * * * * line = line & oExec..StdErr.ReadAll
> > > * * * * Loop
> > > End Function
Quote:
Quote:
> > > Thanks in advance,
> > > Steve
Quote:
> > Tom Lavedas
> Thanks for the reply Tom. *Forgive if this is a n00b question, but
> Steve
Well, first I need to apologize. I was in a hurry and introduced two
errors into what I typed. It should not be "%comsoec /c ", but rather
"%comspec% /c ". Sorry for any confusion I caused by my haste.
That is the environment variable generated by the system to point to
the correct location for the command processor - usually cmd.exe,
these days. If you drop to a command prompt and type SET COMS followed
by the Enter key, you will see what is stored in the variable. It is
almost always C:\Windows\system32\cmd.exe, but it doesn't have to be.
For example, I have an upgraded Win2K machine at home that returns C:
\WinNT\system32\cmd.exe. Still, if the PATH statement points to the
%SystemRoot%\system32 location, a simple call to CMD.EXE will
suffice. I make it a habit to use the COMSPEC variable just to be
that much more certain I get the result I expect.
Tom Lavedas
Old 08-04-2009   #6 (permalink)
Steve
On Aug 4, 4:49*pm, "Pegasus [MVP]" <n...@xxxxxx> wrote:
Quote:
> "Steve" <collamp...@xxxxxx> wrote in message
> > this does not work?
> > "Hotfix" & chr(34)
> > msgbox var1
> > wscript.echo var2
> > * *Dim oExec,WshShell, Line
> > Line = ""
> > End If
> > End If
> > Loop
> > ExecCmd = Line
> > End Function
Quote:
> > Thanks in advance,
> > Steve
> but it does when you invoke find.exe many times.- Hide quoted text -
lol...sometimes it's not easy being a hack.
OK, I will try to rework my approach using a "nicer" method. :-)
Thanks,
Steve
Old 08-04-2009   #7 (permalink)
Steve
On Aug 4, 4:59*pm, Tom Lavedas <tglba...@xxxxxx> wrote:
> > > > this does not work?
> > > > var1 = "c:\catapult\pstools\psinfo applications -s \\" & compName& "
> > > > | find /V " & chr(34) & "Security Update" & chr(34) & " | find /V "&
> > > > "Hotfix" & chr(34)
> > > > msgbox var1
> > > > wscript.echo var2
> > > > * * * * Line = ""
> > > > * * * * Loop
> > > > End Function
Quote:
Quote:
> > > > Thanks in advance,
> > > > Steve
Quote:
Quote:
Quote:
> > > Tom Lavedas
Quote:
> > Steve
> Well, first I need to apologize. *I was in a hurry and introduced two
> errors into what I typed. *It should not be "%comsoec /c ", but rather
> "%comspec% /c ". *Sorry for any confusion I caused by my haste.
> by the Enter key, you will see what is stored in the variable. *It is
> \WinNT\system32\cmd.exe. *Still, if the PATH statement points to the
> suffice. *I make it a habit to use the COMSPEC variable just to be
> Tom Lavedas
No problem at all, and thanks so much for the help. This is really
good info!
I've gotten two good pointers so hopefully I can make progress now.
Thanks again,
Steve
Old 08-05-2009   #8 (permalink)
Steve
On Aug 4, 5:02*pm, Steve <collamp...@xxxxxx> wrote:
Quote:
> > > > > this does not work?
> > > > > | find /V " & chr(34) & "Security Update" & chr(34) & " | find /V" &
> > > > > "Hotfix" & chr(34)
> > > > > msgbox var1
> > > > > wscript.echo var2
> > > > > * * * * Line = ""
> > > > > * * * * * * * * If not oExec.StdOut.AtEndOfStreamThen
> > > > > * * * * * * * * If not oExec.StdErr.AtEndOfStreamThen
> > > > > * * * * Loop
> > > > > End Function
Quote:
Quote:
> > > > > Thanks in advance,
> > > > > Steve
Quote:
Quote:
Quote:
> > > > Tom Lavedas
Quote:
Quote:
Quote:
Quote:
> > > Steve
Quote:
> > Tom Lavedas
> No problem at all, and thanks so much for the help. *This is really
> good info!
> Thanks again,
> Steve- Hide quoted text -
Thanks again Tom and Pegasus. I used both of your suggestions
("%comspec% /c " in my EXEC statement and nested IF logic with InStr
statements instead of piping to FIND.EXE) and have a faster running,
functional script.
User executed "System Shutdown (1115)" General Discussion
"Extensible Authentication Protocol" service gives "The system cannot find the file specified" error Vista networking & sharing
Command lines like "http://..." does not work anymore! Vista General
Microsoft exec: Future versions of Windows to be "fundamentally redesigned" Vista General
DOS AUTOEXEC.BAT "PATH" Command Doesn't Work Vista General
